Home > Message Board > Home Video > Satellite TV > Archive through September 05, 2007 > Dish pointing help
Author Thread: Dish pointing help
Username: Imnycusa
Post Number: 88
A friend has Echo8 currently pointing at 207.6 degrees (bearing) & 51.5 degrees (elevation). In order to point the same dish at Echo3, it needs to be at 126.7 degrees (bearing) & 39.3 degrees (elevation). Looking from behind the dish towards the LNB, I think it should be rotated right to achieve the desired 126.7 degrees. Is this right? Please advise. Thanks.
Username: Banti
Post Number: 113
yes echo 8 should be the right from echo 3 thats how i have it.
Home > Message Board > Home Video > Satellite TV > Archive through September 05, 2007 > Dish pointing help [ « Previous ] [ Next » ]
