Thread: Pansat 2500a |
Bronze Member Username: Laurad
Post Number: 17 Registered: Aug-07
| Posted on Sunday, September 02, 2007 - 01:58 pm: |
I am totally confused, I have added in new keys several time, turned off autoroll and tuto tp check date,time turn set off an on gone into parental control with pin go Nag 2, Set is not doing anything, still no picture now no roll, just no scramble or no channel.Do I need echo 7, do I need just Nag2, Dish on in auto roll. Help I have several keys for 2500A Panset, which one is correct seems there is a new one everyday. Help |
Silver Member Username: Asharfi
Post Number: 760 Registered: Aug-06
| Posted on Sunday, September 02, 2007 - 04:14 pm: |
Hey, Now, you can easily convert your Pansat 2500 to Pansat 2700 via serial port. Soon, there will be NO files for Pansat 2500 and other clones. So, please convert your Pansat 2500 to Pansat 2700 via serial port and you'll have much better machine. The autoroll will work, and you'll get some new cool features. |
Silver Member Username: Banti
Post Number: 111 Registered: Jul-06
| Posted on Monday, September 03, 2007 - 09:41 am: |
how do u convert it will that make it clone? please give me full dirrections. thanks |
Post Number: 18 Registered: Aug-07
| Posted on Monday, September 03, 2007 - 10:20 am: |
I too also need info on how to change the 2500a to 2700, please advise where infor is located Thanks |
Silver Member Username: Viruscauser
Leesburg,
Georgia
Post Number: 136 Registered: Mar-07
| Posted on Monday, September 03, 2007 - 11:36 am: |
You'll find the conversion files and instructions from here: http://www.d*stester.com/download.php?file=2964 (insert "s" where I've put a "*") This site does not allow messages with that name. Download and unzip the contents into a new directory on your computer then read and follow the instructions carefully. |
Post Number: 19 Registered: Aug-07
| Posted on Monday, September 03, 2007 - 03:32 pm: |
Tried to download file 2964, unable to open . I keep getting a page from MSN on space saving and how to download files safely, the download goes into doc file. Is this file located anywhere. |
Leesburg,
Georgia
Post Number: 141 Registered: Mar-07
| Posted on Monday, September 03, 2007 - 04:07 pm: |
That just means you don't have winrar that you need to open this file. Google "winrar" and install that free prog on your comp. |
