Thread: C-Band FTA |
Silver Member Username: Ajdarwin
Post Number: 232 Registered: May-06
| Posted on Friday, August 31, 2007 - 10:35 pm: |
I was wondering if any of the FTA machines will do C-band. I thought my Flu did, but after checking, it doesn't appear to. Any ideas out there concerning options. This would be in addition to Ku band FTA. |
Post Number: 233 Registered: May-06
| Posted on Friday, August 31, 2007 - 11:00 pm: |
I guess no one uses their FTA receiver for C-Band. I have read more and have found at least some of the FTA receivers will work on C-Band. I have a Flu, and wonder if another bin, more updated than on the manufacturer's website would have the C-Band satellites listed. |
Silver Member Username: Hardrockstriker
Post Number: 976 Registered: Apr-06
| Posted on Saturday, September 01, 2007 - 01:24 am: |
Joe, not much support for BUD technology these days - it's a bit of an albatross. Too bad because the signal reception is crystal clear, storm or no storm. |
Gold Member Username: Tapeman
New York City in-HD,
NY
Post Number: 1308 Registered: Oct-06
| Posted on Saturday, September 01, 2007 - 09:57 am: |
satelliteguys-us www.satelliteguys.us |
Silver Member Username: Flatulant_kitty
Post Number: 335 Registered: Jul-06
| Posted on Saturday, September 01, 2007 - 11:14 am: |
Most these things will do C/BAND. From what ive seen/heard/read you need a C/BAND receiver to slave power to the C/BAND lnb.These Irds wont run the old stuff.It's a lot of work for the little you get. |
Bronze Member Username: Tdti1
Post Number: 30 Registered: Mar-05
| Posted on Saturday, September 01, 2007 - 01:17 pm: |
Slaving a dvb (fta) receiver to a 4dtv or a old analog ird is well worth it, I use a Pansat 2500a and it works fine. If you have a big dish upgrading to 4dtv is a great investment if you want to sub at great prices, the 4dtv is in high demand right now so it is hard to find a new 4dtv, most places have a back order list, if your dish is c-band only upgrade to c/ku and just slave a dvb receiver and you will have the best system on the block, if you have not done this upgrade 10 years ago then I would do it now if I was you  |
Post Number: 234 Registered: May-06
| Posted on Saturday, September 01, 2007 - 09:23 pm: |
Thanks, I have done a little more research on my own. I have a Panasonic C-Band receiver, with RF remote, with two more C-Band receivers of various makes, and I am hooking up my FLU to the system. I have found a great use for the Gtools found on the FLU homesite. I can put C band sats and TP's on the FLU and it will pick up great. I think you are right about having the best system around. Lots of options. Of course this is for FTA, not FTV. |
Post Number: 235 Registered: May-06
| Posted on Saturday, September 01, 2007 - 09:31 pm: |
If DN does finally cut off the FTV people, they may find this a good choice, once they want to just go legit altogether. Most of what I like is free, adult film is not really something I desire, and most movies are out on DVD by the time it hits PPV. I can rent for a dollar, or wait five or six weeks and buy it used for four or five dollars and stay completely legit. It is great to have so many options and not fear a letter from anyone. |
Post Number: 31 Registered: Mar-05
| Posted on Sunday, September 02, 2007 - 02:11 pm: |
Ya I use my 4dtv for HBO and Showtime, the HD is super!, I am a big boxing fan and I sub per year so it's a good deal, everything else I watch is free on dvb and 4dtv also has many free channels, so you have c/ku on the dish? if not I would upgrade if I was you, it is well worth it. Norsat makes good lnb's, I have the 8115 for c-band and 4106a for ku on a corotor wideband feed, I got the wideband to hit NSS-806, works great. |
New member Username: Packet_storm
Post Number: 5 Registered: Aug-07
| Posted on Tuesday, September 04, 2007 - 06:55 pm: |
There is a lot of good stuff left in C-band. Plus if you take your circular lnb's and attached them to the bud you get no rain faded that alone is worth it's weight in gold. |
