Thread: Convert back to 2500/FLU here...Success or Failure? Post here |
New member Username: Teevee4me
Post Number: 5 Registered: Aug-07
| Posted on Sunday, August 26, 2007 - 11:13 pm: |
I know it's early in the game, but we need to know how! |
Silver Member Username: Viruscauser
Leesburg,
Georgia
Post Number: 110 Registered: Mar-07
| Posted on Monday, August 27, 2007 - 12:49 am: |
A-1.2 OK. |
Gold Member Username: Nydas
Post Number: 3455 Registered: Jun-06
| Posted on Monday, August 27, 2007 - 01:07 pm: |
Abby: I have noted with satisfaction your good experience with 2500-2700 conversion. I could not understand the post above. If one has to can one revert to 2500, and if so, what is the procedure? Thanks in advance. |
Silver Member Username: Asharfi
Post Number: 686 Registered: Aug-06
| Posted on Monday, August 27, 2007 - 06:39 pm: |
Hey, Nalin! Okay, now this is a little stupid, but who cares .... I know that you know A LOT about FTA than me ... but ... it looks like you need help with FLU - Pansat 2700 conversion .... am i rigt? .... I have posted the procedure  |
Post Number: 687 Registered: Aug-06
| Posted on Monday, August 27, 2007 - 06:45 pm: |
And oh yes, You can convert your 2500 converted box back from 2700 box to 2500 again without the use of jtag |
Platinum Member Username: Lklives
Post Number: 11478 Registered: Jan-06
| Posted on Monday, August 27, 2007 - 07:21 pm: |
Nalin does NOT know FTA...she never has...thats what myself and PRFRMNJ have always been saying...all she does is copy/paste others posts...and then posts WRONG BOGUS info, whenever she does NOT do a copy/paste...and she has NEVER TESTED anything in her life! AV...U know much more than nalin...about FTA! nalin just owns (maybe) an old Pantec (NOT Pansat) 2500 ...a really cheap POS clone...the FLU is a cadillac compared to her pantec...I don't think she even owns a FTA receiver...but is just a rat, mole, DN autority here, monitoring this site... |
Leesburg,
Georgia
Post Number: 111 Registered: Mar-07
| Posted on Monday, August 27, 2007 - 07:57 pm: |
Nalin, I couldn't say "A-1 OK" because there are a couple of bugs in the new bin thus a grage of A-1.2 OK. ;>) Seriously, it was very easy to do and the old 2500 box works as if I put a turbo into it. |
Leesburg,
Georgia
Post Number: 112 Registered: Mar-07
| Posted on Monday, August 27, 2007 - 08:00 pm: |
*grage = grade |
Post Number: 3472 Registered: Jun-06
| Posted on Monday, August 27, 2007 - 08:58 pm: |
AV and Abby: Thanks for your informative posts. I have my old Pansat 2500 clone with a close relative and two others of old friends have Pansat 2500 clones. I was about to suggest conversion to 2700 but thought I should check out your experience with reverse conversion, i.e. back from 2700 to 2500. I will suggest the conversion after reading your reassurances today. |
Post Number: 688 Registered: Aug-06
| Posted on Tuesday, August 28, 2007 - 10:38 am: |
Okay, I also have 2 Pansat 2500 clones (both FLUs), and I converted both of them to Pansat 2700. But, I'm NOT gonna convert them back to Pansat 2500 because I happy with what I have right now. I don't know about your friends, but if you wanna convert your Pansat 2500 clone to Pansat 2700, go ahead! Some good people are telling Pansat 2500 and clone users to change their unit because BL will close the service for those receivers. That's why ... we got two new VS Xtremes, but my old ones are still working fine, with NO autoroll problem. So, for the FLU - Pansat 2700 conversion, please visit http://forum.ecoustics.com/bbs/messages/2/382668.html. That's my own thread and I posted the file and my own procedure ... so far ... getting GOOD feedback. ... LK also posted his conversion procedure ... so just pick one and follow it .... good luck  |
Post Number: 3491 Registered: Jun-06
| Posted on Tuesday, August 28, 2007 - 11:25 am: |
Part of the notes from zip file: 2700 to 2500 via serial port.zip Steps to Convert Back: 1.) With 2700 to 2500 Loader Converter.exe(included) load Boot60.bin(included) to box and do not touch box when done it will reboot to nightrider and this is ok. 2.) Now open Blacklist Updater v1.4.exe(included) and load X-85BL_070812_294T_api.bin(included) 3.) Let the box reboot on its own and it should show "ON" in the display window. 4.) Now hook back up tp TV and it should have defaulted you into the menu at English. Hit "OK" and then you are back to a 2500 again. |
Bronze Member Username: Vrbanja
Post Number: 11 Registered: Aug-07
| Posted on Sunday, September 02, 2007 - 09:08 pm: |
what loader did u guys use to load b75 to convert pansat 2500 to pansat 2700 i used fortecstar STB 4,O and its not working |
Post Number: 11577 Registered: Jan-06
| Posted on Sunday, September 02, 2007 - 11:04 pm: |
osman...U must be really stupid and lazy.....Go subscribe... Thread: FLU - Pansat 2700 Converting Procedure AV Silver Member Username: Asharfi Post Number: 677 Registered: Aug-06 Posted on Saturday, August 25, 2007 - 03:42 am: -------------------------------------------------------------------------------- Okay, I'm posting all the files that you will need to convert your Fortec STAR Lifetime Ultra to a Pansat 2700. Also, I'm posting my own procedure file, just in case if you need it. Intructions File: http://www.hostclip.com/dl/775787b6b672d70f20c297c2341e2805 Fortec STAR Loader: http://www.hostclip.com/dl/4cb2e296e51bf8421bdc9dd1c8f5546e Boot File and Flash File: http://www.hostclip.com/dl/c1a4e8562278fce5384795ae70ede4a5 Please download all the 3 files and follow the intructions. You'll see the procedure I used and I'm sure you'll NOT have any problems, if you use my procedure. It's easy to understand, and I explained everything step-by-step. |
Post Number: 11578 Registered: Jan-06
| Posted on Sunday, September 02, 2007 - 11:07 pm: |
and the FLU is the subject here....and its converting BACK to the FLU....NOT converting TO the 2700... U must be dazed and lost! SUBJECT OF THIS THREAD...."Convert back to 2500/FLU here"... |
Post Number: 13 Registered: Aug-07
| Posted on Sunday, September 02, 2007 - 11:52 pm: |
hahahaha smart azzzz i dont know much obout tv sat like u do but i do have a life too if i ask for help i dont think that i m stupid and lazy u fu.k |
Leesburg,
Georgia
Post Number: 132 Registered: Mar-07
| Posted on Monday, September 03, 2007 - 12:09 am: |
osman try using BL loader 1.4. That should work fine. |
Post Number: 11585 Registered: Jan-06
| Posted on Monday, September 03, 2007 - 02:23 pm: |
osman...your life must be no better than mine , because U are HERE too...except I've got the edge on U cause I already know this stuff...U don't!...and I am retired, healthy, fairly young, and financially well, and don't need to work or go to school, like U ...so I KNOW my life is actually MUCH BETTER than yours is now or ever will be!.... BTW...if U could READ, U wouldn't need to be posting...suggestion for ya...STAY IN SCHOOL...learn to READ... and I don't "think" U're stupid and lazy....I KNOW U ARE!....hehehe |
Post Number: 3573 Registered: Jun-06
| Posted on Monday, September 03, 2007 - 03:18 pm: |
LK is a retired ex-army person. She was thrown out of army because of severe mental conditions and addiction she acquired in Afghanistan. Currently she is an untreated paranoid psychomaniac and has a bit of drinking habit too. |
Bronze Member Username: Laurad
Post Number: 20 Registered: Aug-07
| Posted on Monday, September 03, 2007 - 03:40 pm: |
Not able to get download for conversion from Pansat2500A to 2700. I have tried everything that has been suggested, and I'm sure the Pansat is going to blow up any min. Should I convert and if so what download with instructions should I use. Confused. |
Silver Member Username: Wakenbake
Post Number: 337 Registered: Mar-06
| Posted on Monday, September 03, 2007 - 03:58 pm: |
have you tried this: http://forum.ecoustics.com/bbs/messages/2/382668.html |
New member Username: Joe_sceptical
New York
United States
Post Number: 3 Registered: Aug-07
| Posted on Monday, September 03, 2007 - 08:57 pm: |
works great |
