Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2004 > To find out if site is D*ve owned
Author Thread: To find out if site is D*ve owned
4thewinner
Go here to check if domane is safe. http://www.betterwhois.com./
If its daves it'll tell you
Crazy PPL
How the Hell do you figure a whois search will tell you if dave owns a site??? It will give you the srver domain & such, but it will not say "OH NO Dave Site" that is just ridiculous!!
4thewinner
Just learn to read.
Crazy PPL
No you need to learn what you are doing!!!
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2004 > To find out if site is D*ve owned [ « Previous ] [ Next » ]
