Thread: Jtagging |
| Posted on Wednesday, May 19, 2004 - 04:52 pm: |
does anyone know how to jtag i can't get mine to work |
New member Username: Dilatedpeoples
Post Number: 7 Registered: Apr-04
| Posted on Thursday, May 20, 2004 - 12:21 am: |
What is the problem you are having?? NO read?? Can you put up a pic of your Jtag |
| Posted on Thursday, May 20, 2004 - 07:01 am: |
the jtag is hooked up correctly this i'm for sure when i hit detect iget 0xffffff or 0x00000 the tag i have is bought from greendish quad mode |
Post Number: 8 Registered: Apr-04
| Posted on Thursday, May 20, 2004 - 09:48 am: |
Sounds like your not hitting the pins right on |
| Posted on Thursday, May 20, 2004 - 10:07 am: |
the tag has 7 top pins and 3 bottom pins do you think if i took wires of from pogo pins and connected straight to board i would get a read |
Post Number: 9 Registered: Apr-04
| Posted on Thursday, May 20, 2004 - 11:22 am: |
I would think so, you just need to know which go to which pin on the TSOP |
StandswithSolderingIron Unregistered guest |
| Posted on Saturday, May 22, 2004 - 10:31 am: |
Make sure you IRD is plugged in but not turned on. What type of Jtag do you have - a build-your-own? or a solderless type? Does your IRD have an open port for JTAG? Heres a JTag tutorial http://www.bellexpress.vu/jtag_ht.html#boxkeys good luck |
| Posted on Saturday, May 22, 2004 - 04:02 pm: |
i have an unbuttered universal jtag 3100 .010 ird jtag slot on bottom of ird and sorry my jtag has only 2 pins on bottom of jtag not 3 and 7 pins on top i've gone to bell.vu and can't get any good help |
