Thread: Archive through August 18, 2007 |
Gold Member Username: Tetuscosmicus
Post Number: 1244 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 08:31 pm: |
AN CAMBIADO LAS KEYS... ESAS SON LAS DE RECIENSALIDAS DEL HORNO.. SALUDOS RAZZAAAAAA |
Post Number: 1245 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 08:39 pm: |
SEÑORES EN CAMBIO DE YAVES SI NO LES FUNCIONA BIEN CUANDO LAS PONGAN?????? FIJENSE EN LA PAREJA ''D5´´ NO ME FUNCIONO ..ME FUNCIONO CAMBIANDO A ´´´5D´´ÓJO...CREO QUE SU RECIVIDOR LES VA MARCAR LA DIFERENCIA... SALUDOS RAZZAAAAA.....SUERTE A TODOS.... |
Post Number: 1246 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 08:42 pm: |
EN EL PRIMER PAR LES VA MARCAR ..10.. LO QUE SERIA= ''D0''CON LO QUE VA A TRABAJAR LA CAJITA...Y DESPUES LO QUE LES RECOMIENDO ARRIBA.... SALUDOS RAZAAAAAA... |
Post Number: 1247 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 08:44 pm: |
MUCHAS GRACIAS JORGE LUIS ERES LO MAXIMO...SALUDOS.. |
Bronze Member Username: Curda
Post Number: 14 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 08:45 pm: |
Viewsat extreme....no trabaja con esas keys....ya lo hice y nada |
Post Number: 1249 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 08:47 pm: |
Dish Network (0101) (Last Update: Fri. Aug 17, 2007 8:14 PM EST) 86: BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 96: D0 47 36 5D 5B F2 27 66 56 D0 96 C8 3F 85 AF D9 New Bell ExpressVu (0901) (Last Update: Fri. Aug 17, 2007 7:09 PM EST) 86: 3B 28 3A 23 67 AE EF 00 C0 D2 EE 21 FD EA 62 08 New 96: 49 41 B4 61 3E C1 01 77 7B FC 3D 76 19 DF C6 29 |
Post Number: 1251 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 08:50 pm: |
JOSE M GARCIA PON ATENCION ALO QUE POSTIE ARRIBA YO TAMBIEN NO PODIA Y SOLUCIONE EL PROBLEMA CUIDADOSAMENTE...OJO.. SALUDOS.... |
Post Number: 15 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 08:52 pm: |
Gracias....intento y dejo saber...Gracias |
Bronze Member Username: Chabliz
Corozal,
Puerto Rico
Post Number: 37 Registered: May-06
| Posted on Friday, August 17, 2007 - 08:53 pm: |
AUXILIO!!! Estoy tan furiosa!! Tengo una skyview500 = clone de pansat El primo de mi esposo me envio "el bin" y despues de correrselo se murio!!! no prende no hace nada! Ahora busco la info y me doy cuenta que me dio el bin de una pansat no de un clone!! Hay algo que pueda acer?? |
Silver Member Username: Nadadesat
Post Number: 358 Registered: Jun-07
| Posted on Friday, August 17, 2007 - 08:54 pm: |
atmega 128 empinada. atmega 256 empinada. coolsa*t 7000 y al parecer otros empinados. |
Post Number: 360 Registered: Jun-07
| Posted on Friday, August 17, 2007 - 08:57 pm: |
Chabliz por eso hay que leer, mis condolencias. |
Post Number: 16 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 08:59 pm: |
Hetor...eso a que te refieres es para un Viewsat Extreme?...no entiendo el 86 y el 96 |
Bronze Member Username: Jpchavarria
Post Number: 78 Registered: Feb-07
| Posted on Friday, August 17, 2007 - 09:00 pm: |
alguien me puede decir si hay bin con autorol para el skyview |
Post Number: 361 Registered: Jun-07
los foros cierran, ojo quien sigue? |
Corozal,
Puerto Rico
Post Number: 39 Registered: May-06
| Posted on Friday, August 17, 2007 - 09:01 pm: |
gracias por el animo! |
Post Number: 1252 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 09:02 pm: |
CHABLIZ SI ES CLON DE PANSAT...DEBE DE SER 2500A.. CORRELE EL BIN ANTERIOR EL 293t ... Y PONLE LAS KEYS A LA MANO??????? Y SI NO TIENES ESE CLON AVERIGUA BIEN PARA NO COMETER ERROR...TE DIGO ESTO PORQUE EL BIN SUPUESTAMENTE NUEVO YA NO SIRVIO PARA NADA A MI ME PASO EN FORTEC CLON DE PANSAT 2500 LE PUSE OTRA VES EL 293t Y CAMINA BIEN SOLO QUE CON LA MANO LAS YAVES... SALUDOS Y SUERTE.... |
Bronze Member Username: Jalisco
Post Number: 90 Registered: Oct-06
| Posted on Friday, August 17, 2007 - 09:05 pm: |
que tal raza.una pregunta, tengo un viewsat con sistema de directv plato de 23 con 2 lnb 1 para el 119 otro para el 101.con un 4-way multiswitch 950-1450 mhz sms-4/4 rp20.no logro agarrar el 101,alguien me ayude please. |
Gold Member Username: Juancho
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1348 Registered: Dec-06
| Posted on Friday, August 17, 2007 - 09:06 pm: |
chabliz. jtag , si no se ve nada de nada |
Post Number: 1253 Registered: Nov-06
JOSE M. GARCIA ABLO DE LAS KEYS DE DISH EL 00 Y EL O1....O SEA COMO DICES TU 86 O EL 96 QUE BIENE SIENDO LO MISMO LAS KEYS NUEVAS DEL MOMENTO SON... 01 DO 47 36 D5 5B F2 27 66 56 D0 96 C8 3F 85 AF D9 ME COMPRENDES??????????? SALUDOS Y SUERTE....... |
Post Number: 17 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 09:07 pm: |
Hetor....ya me fije....cambie a 5D y funciono!!!!....Muchas Gracias RAZAAAAAAAAAA....!!! |
Corozal,
Puerto Rico
Post Number: 40 Registered: May-06
| Posted on Friday, August 17, 2007 - 09:08 pm: |
Gracias hetor, pero intente correrselo y me dice que no puede! es que la caja ni siquiera prende! como puedo acerlo? |
Post Number: 362 Registered: Jun-07
| Posted on Friday, August 17, 2007 - 09:11 pm: |
Bueno mientras pasa el traka traka, me voy con los iluminati, saludos amigos. |
Post Number: 18 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 09:13 pm: |
01 DO 47 36 5D 5B F2 27 66 56 D0 96 C8 3F 85 AF D9 Viewsat extreme funciona de maravilla con esta llave...GRACIAS HETOR |
Corozal,
Puerto Rico
Post Number: 41 Registered: May-06
| Posted on Friday, August 17, 2007 - 09:14 pm: |
Juan, como hago jtag? donde lo consigo?? Estoy tan furiosa! pero conmigo misma por no asegurarme primero! siempre he tenido mucho cuidado y cai como tonta esta vez! |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1349 Registered: Dec-06
| Posted on Friday, August 17, 2007 - 09:17 pm: |
usa diseqc sw con estos mhz, fijate en la diferencia |
Post Number: 19 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 09:19 pm: |
Dss-keys.com esta down...alguien sabe porque?...mucho trafico? |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1350 Registered: Dec-06
| Posted on Friday, August 17, 2007 - 09:22 pm: |
Chabliz, visita a PRFRMNJ en ftabins.net. el te facilitara las instrucciones y todo, pero tambien tienes que conseguir el cable para el jtag, una pregunta , no se ve ni siquiera una lucecita. |
Corozal,
Puerto Rico
Post Number: 42 Registered: May-06
| Posted on Friday, August 17, 2007 - 09:27 pm: |
no hace nada! cuando termino decia "on" y luego se apago! y ya no prendio mas! gracias por tu ayuda, voy a verificarlo! |
Post Number: 1254 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 09:29 pm: |
5D CLARO ESTE ES EL PROBLEMA NO 5D MUCHO OJO... |
Corozal,
Puerto Rico
Post Number: 43 Registered: May-06
| Posted on Friday, August 17, 2007 - 09:34 pm: |
no es mi dia! jeje! cada sitio que encuentro que me habla sobre el jtag a una skyview 500x esta down! incluso el que me dices! tendre que esperar a mañana!! de todas formas gracias! |
Silver Member Username: Delgado258376
Monterrey
Post Number: 194 Registered: Aug-06
| Posted on Friday, August 17, 2007 - 09:35 pm: |
Al querer instalar el VSKey2.5 me marca esto: Component 'msinet.ocx' or of its dependencies not correctly registered: a file is missing or invalid. Ayuda por favor.. |
Post Number: 1255 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 09:36 pm: |
PERDON NO D5 JEJEJE... |
Silver Member Username: Dwarf
Post Number: 212 Registered: Jun-06
| Posted on Friday, August 17, 2007 - 09:39 pm: |
Hola Gachos, Alguien puede por favor contestar mi pregunta anterior? Buenas tardes, Tengo Pansat 2700A y quisiera saber si alguien ya la tiene la experiencia del funcionamiento del Bin 208. Muchas gracias y saludos |
Silver Member Username: Mrrasec
Post Number: 228 Registered: Jul-06
| Posted on Friday, August 17, 2007 - 09:40 pm: |
jose,seguro es el trafico. alguien sabe por que el bin de pansat 3500sd dice "no card" ? hay que cargarlo con el cable ,o no es apto para flash card? |
Post Number: 20 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 09:41 pm: |
Te copie....5D....Muchas Gracias.....ya estoy viendo TV..... |
Post Number: 363 Registered: Jun-07
| Posted on Friday, August 17, 2007 - 09:42 pm: |
chino saludos al rato te veo. |
New member Username: Fta_command
Post Number: 1 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 09:48 pm: |
Pansat 2700A - funcionando el Bin 208. |
Silver Member Username: Miami1130
Post Number: 158 Registered: Jul-06
| Posted on Friday, August 17, 2007 - 09:49 pm: |
el bin 208, por un amigo me dijo q le estaba trabajando bien. |
New member Username: Calonsor
| Posted on Friday, August 17, 2007 - 09:54 pm: |
Hola a todos, Por fa, alguien que me pueda decir como le hago con los canales que no tiene audio, se los agradecería mucho. |
Post Number: 213 Registered: Jun-06
| Posted on Friday, August 17, 2007 - 09:55 pm: |
FTA Commander y Alejandro Miami, Muchas gracias señores, un abrazo. |
Post Number: 159 Registered: Jul-06
| Posted on Friday, August 17, 2007 - 09:58 pm: |
el 293 rolea bien las llaves esepto los primeros digitos de ambas llaves .pero la tabla no trabaja sale 7 en 00 y el 7 es f pero la corecta es b.y en la 01 sale 1 q es 9 pero la corecta es D. A ALGUIEN LE ESTA SUCEDIENDO LO MISMO?GRACIAS |
Bronze Member Username: Albertson
Post Number: 46 Registered: Jul-07
Miguel Angel. Lee el post 67 de hector castro. encontraras la respuesta. Al |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1351 Registered: Dec-06
| Posted on Friday, August 17, 2007 - 10:24 pm: |
compa moi. recuerdo que le hicistes jtag a un skyview500 clone del pansat2500, le puedes ayudar a chabliz sobre la informacion de como ha*cerle el jtag a ese clone?. |
Post Number: 1256 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 10:46 pm: |
Dish Network (0101) (Last Update: Fri. Aug 17, 2007 10:27 PM EST) Key 00/86: 01 E1 DE 05 5F F9 0E 84 AE FA AE 47 8D 49 B3 AC New Key 01/96: D0 47 36 5D 5B F2 27 66 56 D0 96 C8 3F 85 AF D9 Bell ExpressVu (0901) (Last Update: Fri. Aug 17, 2007 7:09 PM EST) 86: 3B 28 3A 23 67 AE EF 00 C0 D2 EE 21 FD EA 62 08 New 96: 49 41 B4 61 3E C1 01 77 7B FC 3D 76 19 DF C6 29 |
Post Number: 79 Registered: Feb-07
Alguien sabe algo del bin nuevo para mvidea es el mvideafs4000-144beta070815.zip por favor si alguien lo probo me diga si funciona |
New member Username: Rsolisv
Monterrey ,
Nuevo Leon
Mexico
Post Number: 3 Registered: Dec-06
| Posted on Friday, August 17, 2007 - 11:08 pm: |
puedo meter las claves a un viewsat vs2000 ultra, por favor orientenme , yo antes tenia un pansat 2500A y no tenia problemas y esta es la primera vez que se me cae el sistema ..gracias por su ayuda |
Bronze Member Username: Drr77
Post Number: 40 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 11:20 pm: |
00; 01E1DE055FF90E84 AEFAAE478D49B3AC 01; D047365D5BF22766 56D096C83F85AFD9 |
Silver Member Username: Ricky_nauta
Post Number: 183 Registered: Aug-06
| Posted on Friday, August 17, 2007 - 11:22 pm: |
savoy Silver Member Username: Mrrasec Post Number: 228 Registered: Jul-06 "alguien sabe por que el bin de pansat 3500sd dice "no card" ? hay que cargarlo con el cable ,o no es apto para flash card?" Tú lo has dicho Savoy. Debe ser transferido vía cable. (...y por cierto, hasta ahora está funcionando muy bien) } |
Post Number: 1257 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 11:23 pm: |
MI FORTEC CLON DE PANSAT 2500 MARCHANDO MUY BIEN CON ESTAS KEYS.... SALUDOS RAZAAAAAAAA... |
Post Number: 21 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 11:24 pm: |
Ricardo Solis...esto es para un VS extreme...no se si funcione en el vs tuyo...prueba a ver How to enter keys manually on VS Platinum/Extreme... (Turn autoroll off in menu option before you entered the keys) Menu==>Installation==>0000==>Code==>Nagra==>Right arrow until you see DISH provider ID (01 01 00) and it should be look like this: 00. xx xx xx xx xx xx xx xx (Don't touch this line) 08. xx xx xx xx xx xx xx xx 09. xx xx xx xx xx xx xx xx 88. xx xx xx xx xx xx xx xx 89. xx xx xx xx xx xx xx xx Keys 00 go to line 08 & 09 (Don't change the 08 and 09 number) Keys 01 go to line 88 & 89 (Don't change the 88 and 89 number) (Press OK to save change on each line when you finished enter the keys. |
Post Number: 41 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 11:26 pm: |
para la pregunta del bin 325 q dice no card, eh visto en otros foros q dicen ,q si se puede cargar con la sd card. no se en realidad usese vajo su propio riesgo |
New member Username: Pirujo
Villa union,
Coahuila
Mexico
Post Number: 3 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 11:27 pm: |
alguien que me ayude tengo un REX-1 y en la pantalla para poner las llaves solo me aparecen 12 digitos como le hago para poner los 32 que utiliza |
Post Number: 1258 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 11:29 pm: |
----RICARDO SOLIS V....---- TALVES TE SIRVE ESTA INFORMACION SALUDOS Y SUERTE.... COMO PONER KEYS EN VEWSAT How to change keys Viewsat Ultra How to change keys Viewsat Ultra 1 .PRESS MENU 2 .USER SETTING 3 .ENTER PIN CODE 4 .SCROLL DOWN -------- CODE MENU 5 .CAS -------- NAGRA 6 .PROVIDE ID BEV- 08 01 00 OR DISH- 09 01 00 7 .SCROLL DOWN 8 .USE FOR NUMBERS NUMBER SIGN AND FOR LETTERS USE F1, F2, F3, F4, LAST AND COLOR BUTTON ( LAST ) ( TEXT ) F1 = A F2 = B F3 = C F4 = D LAST = E TEXT = F KEYS BEV : 08 09 88 89 KEYS DISH : 00 08 09 88 89 9 . EXIT 10. SAVE CHANGES AND WATCH YOUR TV |
Post Number: 1260 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 11:32 pm: |
RICARDO OTRA QUE TE PUEDE SERVIR POR SI LAS DUDAS.... ==EL VIEWSAT CON NIGHT RIDER== Help !!!!! Tengo un Viewsat Extreme y despues de que le cargue el bin de Fabrica 2061 no arranco mas. Lo conecto y se queda en 4 "guiones" y de ahi no pasa. He tratado de cargar otros bin 2067,2068,etc. pero siempre me sale un error cuando intento cargar el BIN. Hay algo que pueda intentar para recuperar mi Receiver? Gracias Carlos guerrero. esto trabaja en Reciver que solamente tienen 4 rayitas de luces ( llamado el VS night rider) trata lo siguiente......... 1) apaga tu unidad ( desconectale la plug) y dejalo apagado desde 5 minutos hasta 5 horas.. 2) Open Loader 2.......................... 3) conecta tu Vs con el switch de atras apagado. 4) Open el Loader y Hit transfer <pc-stb>.. 5) enciende el reciver con el switch de atras. 6) load tu canal lista y el ultimo bin y disfruta de nuevo tu tv... |
Bronze Member Username: Calin
Post Number: 61 Registered: Jun-06
| Posted on Friday, August 17, 2007 - 11:33 pm: |
Gerardo: alguna actualizacion de Windows esta perdida, hagale un update (me imagino que tiene Windows Xp legal) y pruebe de nuevo o baje el programa de algun otro sitio, puede que el file que bajo este corrompido. |
Post Number: 1261 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 11:34 pm: |
RICARDO-- SOLO QUE ESTO NO ES PARA TI.....DISCULPAS...EL RESTO SI.... Help !!!!! Tengo un Viewsat Extreme y despues de que le cargue el bin de Fabrica 2061 no arranco mas. Lo conecto y se queda en 4 "guiones" y de ahi no pasa. He tratado de cargar otros bin 2067,2068,etc. pero siempre me sale un error cuando intento cargar el BIN. Hay algo que pueda intentar para recuperar mi Receiver? Gracias Carlos guerrero. esto trabaja en Reciver que solamente tienen 4 rayitas de luces ( llamado el VS night rider) trata lo siguiente......... |
Monterrey
Post Number: 195 Registered: Aug-06
| Posted on Friday, August 17, 2007 - 11:36 pm: |
Carlos G. Muchas gracias por la información. |
Silver Member Username: Rafita
Post Number: 102 Registered: Mar-07
| Posted on Friday, August 17, 2007 - 11:38 pm: |
Maestros y Compañeros del foro, para comentarles que acabo de poner el ultimo fix para VS lite y rolleo de maravilla, saludos. |
Post Number: 1262 Registered: Nov-06
| Posted on Friday, August 17, 2007 - 11:39 pm: |
RICARDO OTRA INFORMACION QUE TE PUEDA SERVIR PUEDES GUARDARLAS....SALUDOS... ==PARA VIEWSAT ULTRA. USANDO NULL MODEM= Downloading VS ultra usando null modem cable.. 1 es como los demas VS,,,,... 2 espera que el loader diaga complete, despues la pantallita del STB dira INST>END>0000 o hasta que el reloj diga 0.001......ahora apaga el STB y desconectalo.......................... 1) conecta el stb a tu pc................ 2 enciende el stb con el switch de atras......... 3 Press la menu key.................... 4 selecciona Installation y press ok..... 5 Selecciona antenna set up y press ok....... 6 selecciona tus satelites............... 7 entra tu Diseqc # o motor..... 8 no tipe de lnb debe de ser entrado, solo hay 2 opciones standard y universal. el Stb lo seleccionara automaticamente ( nueva tecnologia) 9 press exit y save tus settings.... 10 regresa a antenna set up, aqui tienes 3 donde escoger 1 channel scan,2 auto scan,3 blind scan.. selecciona auto scan y press ok.......... 11 Tu estas ahora en la auto scan opcion y tu veras el satelite que seleccionastes.. arriba veras 3 opciones: 1 search option 2 network search, 3 scan star........................ 12 no cambies nada y ve donde dice scan star y press ok............................... 13 has esto con todos los satelites que tengas y espera que el autorol empieze a trabajar. con los nuevos bines no es necesario load el opkey. |
Post Number: 22 Registered: Aug-07
| Posted on Friday, August 17, 2007 - 11:48 pm: |
Ricardo Solis.....ya te hemos respondido...mira los post de Hetor ...yo tambien puse uno para explicarte...ve arriba y revisa |
Monterrey
Post Number: 197 Registered: Aug-06
| Posted on Saturday, August 18, 2007 - 12:05 am: |
Porque no vamos armando de nuevo la tabla que ahora esta funcionando: 0 = 1 = D 2 = 3 = 4 = 5 = 6 = 7 = B 8 = |
Silver Member Username: Rober2154
Miami,
Fl
Usa
Post Number: 164 Registered: Jun-06
| Posted on Saturday, August 18, 2007 - 12:14 am: |
Ricky Nauta; Es cierto eso que el bin para el pansat 3500 no se puede cargar con la tarjeta?? |
Silver Member Username: Rrios01
Monterrey,
N.L.
Mexico
Post Number: 169 Registered: Oct-06
| Posted on Saturday, August 18, 2007 - 12:35 am: |
que onda raza, solo para reportar el cw600s premium autorrol ok con el 1.45, el cw600s regular autorrol ok con el 1.37, pansat2500a, solo se le cambian los dos primeros digitos de las llaves. saludos a todos |
Monterrey,
N.L.
Mexico
Post Number: 170 Registered: Oct-06
| Posted on Saturday, August 18, 2007 - 12:53 am: |
compadre esrnesto saludos, no habia entrado al foro porque estaba viendo un juego de la nfl, pero aqui andamos y una recomendacion los que tiene receptores viejos, ya vayan pensando en comprar uno nuevo ya se ve cuales tienen mas soporte, los pansat2500 y clones ya desquitaron la inversion vayan ahorrando porque dentro de poco ya no van a tener soporte, es solo una recomendacion saludos a todos. |
Post Number: 214 Registered: Jun-06
| Posted on Saturday, August 18, 2007 - 01:21 am: |
Albertson, gracias por tu recomendación. Héctor Castro, o alguien que tenga el bin 208 para Pansat 2700A, le agradeceré lo envíe a mi dirección maaea@hotmail.com, pues los foros donde regularmente hago las descargas están cerrados. Muchas gracias |
Post Number: 364 Registered: Jun-07
| Posted on Saturday, August 18, 2007 - 01:32 am: |
Que onda mi chino aqui reporatando captivworks premium ok. con el 1.45. todo up. captive works regular ok. con el 1.37 todo up. pansat 2700 a todo up con el 268. Cambio y fuera y todo gracias a ti compadre chino. Bueno me adhiero a las palabras de mi compadre. Aqui se esta viendo quien es quien. Información pegada a la realidad y con toda honestidad. cosa que te empieza a dar problemas , es como cabra que no da leche. Saludos. No señor como esta eso de andar todo parchado, si estan viendo que la bronca es contra viewsat, agarren la onda. y ya dejen de comprar clones, mejor compren una captive works, para 80 dollares que vale. Mejor vayan ahorrando para cuando salgan las cajas buenas y vuelvan los tiempos del pirectv. Saludos. Todo tiene su tiempo, tiempo para vivir y tiempo para morir. Saludos. Ahora como lo dice mi otro compadre EL SEÑOR JAVIER GARZA GONZALEZ, SI ARREGLAR UNA COSA DE ESAS ES DIDACTICO Y LES DA SATISFACCION PERSONAL EL HABER ARREGLADO Y SACADO ALGO PARA ADELANTE. PUES ESTA BIEN. ACUERDENSE QUE LAS COSAS SE HICIERON PARA DARNOS COMODIDAD, NO PROBLEMAS. SI MI CHINO YO ACABO DE VER UNA PELICULA DE PPV. PERO ANTES FUI CON LOS ILUMINATI. HA QUE RAZA. |
Post Number: 365 Registered: Jun-07
| Posted on Saturday, August 18, 2007 - 02:03 am: |
Miguel Angel te lo voy a mandar, si es que otro compañero no te lo a mandado. saludos. |
Post Number: 366 Registered: Jun-07
| Posted on Saturday, August 18, 2007 - 02:06 am: |
es el 208 de pansat 2700 a |
Post Number: 367 Registered: Jun-07
| Posted on Saturday, August 18, 2007 - 02:18 am: |
YA TE LO MANDE MIGUEL ANGEL, SI JALA PARA EL PANSAT 2700A. SALUDOS. |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1352 Registered: Dec-06
| Posted on Saturday, August 18, 2007 - 09:10 am: |
Compa Moi,del 20-21 de agosto se discutiran los planes de usa para combatir la droga en mexico en Quebec,Canada. este es un plan de 3 anos y el valor de 1.2 billones de dollares, para modernizar el equipo de la policia ejercito que se yo para combatir el narcotrafico. lee algo aqui, de esto lo quieren tener muy callado po eso del sentimiento mexicano sobre su soberania. pero creo que algunos ya suenan con cuanto les tocara de esos billones.http://Wola.org/index.php?option=com_content&task=viewp&id=543&Itemid=8 |
Bronze Member Username: Silver1123
Mexico,
DF
Mexico
Post Number: 39 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 09:20 am: |
Nuevo bin de autoroll para cool*sat 5000, si funciona http://ftabins.net/showthread.php?t=6914 View*sat Extreme: http://totalfta.com/DBPSW-070817X.zip View*sat Platinum: http://totalfta.com/DBPSW-070817P.zip View*sat Ultra: http://totalfta.com/PFTAUSW-070817U.zip View*sat Pro: http://totalfta.com/VSPRO-070817A.zip Sonic*view SV1000: http://totalfta.com/SV1000_V0261P.zip Sonic*view SV4000: http://totalfta.com/SV4000_V0156P.zip Sonic*view PVR1000: http://totalfta.com/PVR_V0149P.zip Sonic^*view 8000HD: http://totalfta.com/HD8000_P_16Aug2007_v126.zip SOURCE: TOTALFTA Pan*sat 9000hd: http://www.megaupload.com/?d=PCX9J27F Pan*sat 250SM: http://www.megaupload.com/?d=MLNYHZ15 Pan*sat 3500 SD: http://www.megaupload.com/?d=JDK5QINH Pan*sat 2800A: http://www.megaupload.com/?d=ZZ26CF28 Pan^*sat 2700A: http://www.megaupload.com/?d=CS49EES1 Pan¨^sat 6000HXC: http://www.megaupload.com/?d=PTHKYGAM Pan*sat 5000: http://www.megaupload.com/?d=0CFJ2R70 COnax*sat mini: http://www.megaupload.com/?d=87BGYEQS Conax^*sat Duo: http://www.megaupload.com/?d=87BGYEQS Conax*sat Trio: http://www.megaupload.com/?d=87BGYEQS |
Bronze Member Username: Nando13
Post Number: 16 Registered: Jul-06
| Posted on Saturday, August 18, 2007 - 09:24 am: |
ayuda porfavor no encuentro bin para un Pansat 2500A veo todos menos ese oh es que le puedo poner de otro pansat al 2500, les agradeceria un millon por la ayuda gracias... |
Mexico,
DF
Mexico
Post Number: 42 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 09:32 am: |
Fernando http://ftabins.net/forumdisplay.php?f=48 ahi encontrarás todos los fixes para Pan Sat, incluyendo el 2500A. No puedes ponerle de otro, siempre tienes que buscar el que es para tu equipo |
Mexico,
DF
Mexico
Post Number: 43 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 09:36 am: |
El Pansat 2500 A es de los equipos mas viejos y limitado en la memoria. El 15 de agosto pasado, Black list sacó un fix para el 2500A, despues de dos semanas que los demas sacaron sus fixes. He hecho algunas pruebas a este programa y en dos ocasiones en una hora se ha reseteado apagàndose y prendiendo por si solo. Las preguntas estan en el viento: ¿Sera un mejoralito? ¿Cuánto durara? ¿Podran estabilizar ese problema del reseteo?. Esta misma historia le pasò al Pansat 2300 en Octubre del año pasado 2006. RECOMENDACIÓN: Desaganse a tiempo de este tipo de equipos ya que pronto no tendrán soporte, especialmente por lo limitado de su memoria, lo que hace que no se puedan cargar nuevos autoroles. |
Mexico,
DF
Mexico
Post Number: 44 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 09:39 am: |
El dia de hoy por a las 1:30 horas de la madrugada salieron los ultimos programas que faltaban del autoroll, es decir ya hay programas para los: COOL*SAT: 4000, 5000, 6000, 7000PVR, 8000HD Y 8100HD NEU*SAT : SP6000, SP6000 PREMIUM, 9000HD Pan^*SAT: 2700, 2800 Y 3500 (PARA EL 2500 NI SUS LUCES) VIEW^¨SAT: ULTRA, XTREME, PLATINUM o LITE. Y TAMBIEN PARA EL VISONSAT: IV200 PVR PLUS Procure actualizar su equipo ya que se VIENE UN FUERTE CAMBIO DE LLAVES MUY SEGUIDO. |
Bronze Member Username: Havana
High river,
Alberta
Post Number: 28 Registered: Aug-07
buen dia,,, alguien sabe si el ==BIM PATA EL COLSAT 6000, ESTA ROLEANDO LAS LLAVES,,, AYUDA ,,,CANADA,, |
Post Number: 17 Registered: Jul-06
| Posted on Saturday, August 18, 2007 - 09:42 am: |
si esta fea la cosa para 2500 yo tengo un viewsat platinum el pansat es de mi papa' que tal para viewsat todavia esta todo bien bueno eso espero, bueno juan muchisimas gracias por tu ayuda.. |
Mexico,
DF
Mexico
Post Number: 45 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 09:44 am: |
Fixes para Cool^*sat 4000, 5000, 6000, 7000PVR, 8000HD y 8000HD PVR http://ftabins.net/forumdisplay.php?f=36 |
Mexico,
DF
Mexico
| Posted on Saturday, August 18, 2007 - 09:49 am: |
Fernando, hasta creo que las mismas companias hacen que no sirvan para que compres un equipo mas nuevo. Pero como bien dices, se pone fea la cosa para el 2500a... lo bueno es que tienes otros equipos. Ruben, el bin 147 si esta funcionando: http://ftabins.net/showthread.php?t=6915 |
Bronze Member Username: Neris
Ottawa,
Ontario
Post Number: 35 Registered: Nov-06
| Posted on Saturday, August 18, 2007 - 09:53 am: |
any new keys |
Mexico,
DF
Mexico
Post Number: 49 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 09:59 am: |
(Last Update: Fri. Aug 17, 2007 10:58 PM EST) 86: 01 E1 DE 05 5F F9 0E 84 AE FA AE 47 8D 49 B3 AC New 96: D0 47 36 5D 5B F2 27 66 56 D0 96 C8 3F 85 AF D9 |
Post Number: 23 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 10:25 am: |
Buenos dias a todos.....es solo para saludar ...no se mucho de esto y me ayudan en lugar de yo ayudar pero si puedo saludarles y desearles un buen dia.... |
New member Username: Luna_margarita
Post Number: 6 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 10:29 am: |
Buenos Dias Alguien tiene las llaves pra la ViewSAt 2000 ultra |
Post Number: 24 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 10:57 am: |
Luna Margarita...las llaves son para los sistemas de television y no para los receivers....que ves normalmente,DISH?....todos los receivers usan las mismas llaves....el bin es otra cosa...entonces las llaves estan aca....www.dss-keys.com asegurate de clickear el boton que dice refresh keys.....ahi estan las que estan funcionando....asegurate que la funcion autoroll este en "off" en tu receiver |
Mexico,
DF
Mexico
Post Number: 54 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 11:14 am: |
Aqui estan las llaves http://www.ftasolutions.blogspot.com/ Aqui estan los bins http://ftabins.net/ |
Post Number: 7 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 11:17 am: |
Gracias Jose M Garcia Lo voy a intentar |
Mexico,
DF
Mexico
Post Number: 55 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 11:18 am: |
Necesitan cambiar los bins de autorolls de sus equipos, porque hubo cambios, chequen lo que pasó hace unos dias: Efectivamente el dia de hoy DISH realizò un ataque sorprendente desde las 12:30 horas teimpo del centro, REALIZANDO UN CAMBIO DE LLAVES SIMULTANEAS TANTO EN EL CAJON 00 COMO EN EL CAJO 01 PERO TODAS ESAS LLAVES ERAN FALSAS. A la media hora después de ese ataque se normalizan los autorolls y vuelven a funcionar por si solos, pero resulta que a los 15 minutos de retablecidas las llaves correctas, ENVIAN UN PROGRAMA DONDE CADA 15 MINUTOS LE EMPIEZAN A CAMBIAR LOS DOS PRIMEROS DIGITOS DE LA LLAVE. Bueno eses no seria problema ya que se corrigen los digitos y SE APAGAN LSO AUTOROLLS. A las 15:45 horas hacen el cambio de llaves del cajon 01 al cajon 00 y sigue el mismo problema de alterar los dos PRIMERO DIGITOS. Por lo pronto lo unico que hay que ha cer es colocar la llave manualmente y apagar el autoroll. ESTAMOS YA TRABAJANDO EN LA SOLUCION DE ESTE PROBLEMA YA QUE SE ESPERA QUE LOS CAMBIOS DE LLAVES SEAN CONTINUOS Y NECESITAMOS TERMINAR LOS AUTOROLLS. ¡¡¡TENEMO0S NOTICIAS DE QUE SUFRIERON DAÑOS LAS TARJETAS DEL DISH!!! Luego les informaremos del recuento de los daños ya que se especula que se introdujo a funcionar el MAP B1 y si esto es asì..QUE PROBLEMOTA TENDRAN MUCHOS, TATNO LAS TARJETAS DE DISH COMO ALGUNOS FTAS. |
Post Number: 8 Registered: Aug-07
Lo que veo es Dish |
Bronze Member Username: Mexdss
Monterrey,
N.L.
Mexico
Post Number: 50 Registered: Sep-06
| Posted on Saturday, August 18, 2007 - 11:20 am: |
Ahi va la actualizada de la tabla faltan unas caidas para verificar de que caracter a cual se suma o resta 4, pero segun lo que ha pasado estimo hasta ahora esto: 0 = 1 = D 2 = 3 = 4 = 5 = 6 = 7 = B 8 = C 9=D A=E B=F C=0 D= E= F= Espero a la siguente caida poder completarla, saludos y espero que les sirva. |
Post Number: 9 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 11:22 am: |
Juan tienes las Llaves para la viesat 2000 ultra soy nuevaen esto y no se como conseguirla ya Jose Garcia me dio unas direcciones pero si tienes las llaves te lo agradecere que me las dieras |
Monterrey
Post Number: 198 Registered: Aug-06
| Posted on Saturday, August 18, 2007 - 11:37 am: |
El Chino, para Pansat 2500 dices que solo cambiar los dos primeros dígitos, pero es verdad que ya no corresponde según la tabla que habían publicado, ¿Sabes ahora cuales son los números que hay que sustituir? |
Post Number: 47 Registered: Jul-07
| Posted on Saturday, August 18, 2007 - 11:42 am: |
Hola buenos Dias, alguien podria enviarme el nevo bin para el Pansat 2700A, ya que no lo he podido descargar pues los foros de dode los bajo estan cerrados. Ernesto M, lei en anteriores post que se lo enviaste aMiguel, pudieras enviarmelo. gracias de antemano al que lo haga. Al gmcfood@yahoo.com |
Monterrey
Post Number: 199 Registered: Aug-06
| Posted on Saturday, August 18, 2007 - 11:43 am: |
Gracias americo, esperemos que alguien mas nos ayude a completarla.
Bronze Member Username: Kazanrov
Post Number: 12 Registered: Jan-07
| Posted on Saturday, August 18, 2007 - 12:26 pm: |
Mi raza saben si salio algo para el clone 2500 porque el bin que le puse 294 dejo de funcionar el autoroll alguien tiene las ultimas llaves. |
Post Number: 368 Registered: Jun-07
| Posted on Saturday, August 18, 2007 - 12:31 pm: |
HOLA HERMANO DE COLOMBIA ALBERTSON. AHORITA TE LO MANDO. |
Miami,
Fl
Usa
Post Number: 165 Registered: Jun-06
| Posted on Saturday, August 18, 2007 - 01:44 pm: |
DishNetwork Keys 01 E1 DE 05 5F F9 0E 84 AE FA AE 47 8D 49 B3 AC D0 47 36 5D 5B F2 27 66 56 D0 96 C8 3F 85 AF D9 |
Miami,
Fl
Usa
Post Number: 166 Registered: Jun-06
| Posted on Saturday, August 18, 2007 - 02:00 pm: |
HOLA MUCHACHOS! ALGUIEN LE INSTALO EL FIX PARA EL PANSAT3500 ??? SI ESTA FUNCIONANDO ME AVISAN???? DESDE YA GRACIAS !!!!!! |
Bronze Member Username: Hector_castro
Post Number: 68 Registered: Dec-06
| Posted on Saturday, August 18, 2007 - 02:12 pm: |
roberto. el fix para pansat 3500 esta funcionando muy bien. |
Post Number: 69 Registered: Dec-06
| Posted on Saturday, August 18, 2007 - 02:20 pm: |
instale el bin 325 en mi pansat 3500 y esta funcionando muy bien todo, lo unico que paso que el menu del pansat esta en ingles y no se puede poner en español,alguien sabe a que se debe eso? |
Silver Member Username: Pasis
Leon,
Guanajuato
Mexico
Post Number: 760 Registered: Jul-06
| Posted on Saturday, August 18, 2007 - 02:25 pm: |
buenas tardes a todos aqui reportandome desde huauchinango puebla. juan recuerda que yo ya les h_abia comentado que los estados unidos vendrian a mexico a supervisar la lucha contra las drogas, que pasaria como en colombia, lo recuerdas? que mexico pediria ayuda a EU o a francia. por favor diganme que esta pasando, no tengo acceso a los demas foros por que no recuerdo ninguna de mis contraseñas. aribaaaaaaa la razaaaaaaaaaaa |
