Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through August 17, 2007
Author Thread: Archive through August 17, 2007
Username: Khopdi
Post Number: 51
LK - Please varify keys. The links listed below all have same keys. The keys you have posted do not match the links. Please confirm correct keys.
www.dss-keys.com
www.tvkeyz.com
www.fta123.blogspot.com
Username: Kingusama
Post Number: 225
keys posted at www.ftasolutions.blogspot.com!!
Username: Asandy1234
Why B3V is not auto rolling even though auto roll is on
Username: Jwl1
Post Number: 40
Since I don't have a lap top and have to get up and go to the computer to check the new keys every time they roll, I decided to just change the second number or letter of the newly rolled key, since it's rolling them all correctly (99 percent of the time) except for the first one, and it's always the second number or letter of the first one. For Example, it will roll 60, when it's actually 63. In addition, I noticed it's usually no more than three up or down. Well, it worked and saved me the hassle of looking online.
Username: Khopdi
Post Number: 52
LK - Nevermind. I got it. The correct keys are as follows:
00:FC 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 New Active
01:63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D
01 begains with 63, not 20.
Username: Adale
Post Number: 28
BEV Keys
D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67
4B 1F B2 B8 78 F0 74 CE 9A D1 E0 9E CA 09 41 40
Username: Jwl1
Post Number: 41
Key 1--Active--
Key 0--
C9 FF D4 57 FA 42 23 B4
D5 95 91 21 8B F1 F1 CA
This is why I find it easier to just play with the first number when it rolls, as the sites are not keeping up with the rolling, as they roll.
Username: Jwl1
Post Number: 42
Khopdi--those are not the keys I have, and I took them straight off the my box, and my tv/dishnet is working.
Username: Khopdi
Post Number: 53
Joe - I used what LK had posted. For 01, first set is 63, not 20. 00 keys chaned @ 1:24 pm accoring to LK.
Username: Lklives
Post Number: 11067
same Bev keys...for 10 days now...look above
BTW...autorolls are taking awhile (10 min to 1 hour) on many of the pansats when the DN keys changed about 1:30 pm today...so be patient..
Username: Jwl1
Post Number: 43
Khopdi--and your dishnet is working with those keys? If so, interesting that both of ours are working with different keys.
Username: Khopdi
Post Number: 54
It's working. How is that possible? I have all autoroll off.
Username: Khopdi
Post Number: 55
BTW, I am using 319 bin, not 321 or 323.
Username: Srpskkisiin
Post Number: 49
Dish Network (0101)
Dish 8/16/07 2pm CST
------------01 01 00------------
00: BF 0D 6F DA DB 69 4D 31F5 70 2B 40 A8 F8 28 03 active
01: 63 75 F2 E9 83 31 B5 6F33 60 5B 1F 36 2D 48 7D
please visit http://www.laptopwontturnon.com
find dish pansat fta thread, and download automatic keys updated, very small file, and is very fast at keys update. Direct from receiver.
Post Number: 50
Dish Network (0101)
Dish 8/16/07 2:10pm CST
Dish
00:C9 FF D4 57 FA 42 23 B4D5 95 91 21 8B F1 F1 CA
01:63 75 F2 E9 83 31 B5 6F33 60 5B 1F 36 2D 48 7D
Changed back, but probably both work. Try previous entry and this
Username: Lklives
Post Number: 11069
Listen people...DN changed the keys (1:24pm EST) to a B1 EMM (intended to disable all receivers using autoroll) earlier that I posted above...
but then quickly reverted back to the old keys from early this morn and late last nite, cause it must have affected some subs...but now DN has just changed again...and so has Bev...
Dishnet 0101 ..(Last Update: Thu. Aug 16, 2007 4:00 PM EST)
86: BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 Active
96: 63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D
BEV - Last Update: 08/16/07 3:28 pm EST
00: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67
01: 4B 1F B2 B8 78 F0 74 CE 9A D1 E0 9E CA 09 41 40 Active
Username: Ousu
Post Number: 8
should the keys autoroll correctly if
we have bin 205 for pansat 2700a ??
Username: Sani13
i have a coolsat5000 and i used the keys
96: 63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D....
but when i keep autoroll on it goes back to the old keys which gives me scramble channel...am i the only one? is there a fix?
Username: Rtap
FL
Post Number: 284
people just read before posting. Lk has explained in the post before yours.until they stop messing with the keys we all will experience problems.just learm to enter the keys manually.
Username: Creek
Smithtown, New York
Post Number: 373
I had to change just 2 numbers BF and 63. All the other numbers were right.
Ummm...that's weird.
Username: Jwl1
Post Number: 44
Creek--Yes, that's basically been the case, since they started rolling the keys a million times a day.
Username: Kazanrov
Post Number: 10
Hey guys pzzzzzzzzzzzzzzzzzz that is my third message about what happens with the procedure that I did , I set already the new bin but the ppvs and , hbo and sport chanels i can't see them please some body answer me.
Username: Mkrinc
Is there a new key downloader out there?
Mine is "no longer supported :-)
Username: Gunit2
I put the new DN keys in and I still get scramble channel. LK's keys work, right?
Username: Mkrinc
Sani Patel's are good....
turn off your auto roll
Username: Gunit2
mine still says scramble with those keys....do I need to reset my box?
Username: Rhonda33
We just had a key change. We are waiting for the NEW keys to be posted.
Username: Mkrinc
Still up, change the channel and your good..
Username: Rhonda33
I changed the channel, and restarted my box, still not running. Need new keys.
Username: Mkrinc
Ok but my cs 6000 is up..
Username: Jorge_luis
MONTERREY
MEXICO
Post Number: 681
Username: Bazuka2020
Post Number: 568
Latest News: August 16, 2007 5:35pm EST
Key changes: Manually enter to get back up
Bev -
Key 00:D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67
Key 01:4B 1F B2 B8 78 F0 74 CE 9A D1 E0 9E CA 09 41 40 active
Charlie -
Key 00:BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 active
Key 01:63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D
Stay tuned!
Username: Zayeshaz
Surrey, BC
Post Number: 12
wat are the keys
for dishnetwork
plzz tell me!!!!!!!!!!!!!!!
Username: Liquidqc
Post Number: 10
tried the BEV keys after turning off autoroll, then i turn off/on from behind...
BEV keys didnt work for me
Username: Rtap
FL
Post Number: 285
Dish Provider 0101: Last Updated (16 Aug '07 4:00 PM EST)
Key 0: BF 0D 6F DA DB 69 4D 31 F5 70 2B 40 A8 F8 28 03 (Active)
Key 1: 63 75 F2 E9 83 31 B5 6F 33 60 5B 1F 36 2D 48 7D
Bev Provider 0901: Last Updated (16 Aug '07 3:16 PM EST)
Key 0: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67
key 1: 4B 1F B2 B8 78 F0 74 CE 9A D1 E0 9E CA 09 41 40 (Active)
Username: Liquidqc
Post Number: 11
NM what i posted, some 1 poste dnew keys as i posted the previous msg
Username: Zayeshaz
Surrey, BC
Post Number: 13
RTAP
ITS NOT WORKINGG
KEY O ... BF????
ITS NOT WORKINGG
Username: Liquidqc
Post Number: 12
those BEV keys actualy work for any 1 ?
Username: Rtap
FL
Post Number: 287
aisha i just enter the keys and its working fine. double check your input of keys and make sure.
Username: Cusumano3231
Post Number: 16
not me
Username: Zerochrono
we're down again anyone got new keys
Username: Rtap
FL
Post Number: 288
just enter the keys i posted and turn autoroll off. im up and ruuuuunnning
Username: Rtap
FL
Post Number: 289
the only keys that changed was
BF for 00
63 for 01
Username: Banej
Post Number: 246
these A/R bins suck
Username: Liquidqc
Post Number: 13
ok, Dish works fine,
But the BEV keys arent the right ones
Username: Rtap
FL
Post Number: 290
here a C/P from LK
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released..
Many of these specialize in particular FTA receivers as noted next to their links..USE those for your particular receiver manufacturer..
If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community for many years now...
Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information
So again I highly recommend using ANY of these sites in this first post!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from a reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby!
Final Solution Free To Air:
http://www.fsfta.com/index.php (All receivers)
Future FTA - Blacklist's Site:
http://www.future-fta.info/forum/index.php (Pansat)
Curious Contraptions Community:
http://www.curious-contraptions.com/forums/ (All receivers)
FTA Tech - Free To Air Community:
http://www.ftatech.net/forums/ (All receivers)
DVB Spider - Free To Air Technology:
http://dvbspider.tk/ (Spacestar)
Free To Air:
http://www.f2atv.com/ (C00LSAT and All receivers)
DSS Newbies:
http://www.dss-newbies.net/forums/ (All receivers)
DSS Evolution:
http://www.dssevolution.com/ (All receivers)
DSS Rookie:
http://www.dssrookie.com/forums/ (All receivers)
Global Airway Technology Specialists:
http://www.gat-s.biz/forum/index.php (All Receivers)
Total FTA
http://www.totalfta.com (VIEWSAT and All receivers)
FTA Bins
www.ftabins.net (VORTEX and All receivers)
Cut and Paste these into your browser:
REMOVE the * in links below: These are the largest sites,and therefore Ecoustics has blocked their names and active links..
http://forums.dsstester.c*om/ (All receivers)
http://www.dsscommunity.c*om/forums/ (All Receivers)
http://www.al7bar.t*k/ (All receivers)
http://www.dsscentral.n*et/ (All Receivers)
This site was free but now has a small fee for files, but is the best site for Clone receivers in general..
http://www.pantecf2a.com/support (Pantecs,all clones and all receivers)
File Share Site - No Registration Required:
Good for gettting Original factory firmware:
http://www.ftacentral.c*om/ (All receivers)
Satellite Finders (Look Angle Calculators)
http://www.arachnoid.com/satfinder (Dish 500 support)
http://www.satellitenut.com/calculators/SatelliteHeading.html
http://www.hollsco.com/Products/SatCalc/
http://www3.telus.net/rampage/skew.htm (Dish 500 support)
http://www.remotesat.com/lookangle.htm
Satellite Charts
For information on all satellites and channels they offer
http://www.lyngsat.c*om/america.html
http://www.satcodx.com/
Best site for DISHNET info, channels, transponders and changes etc..
http://ekb.dbstalk.com/dishlist.htm
Direct links to current Dishnet and Bev keys:
www.tvkeyz.com/
www.dss-keys.com/
www.filez.us/km3/keys.shtml
Username: Gunit2
what are the ident codes?
Username: Kingusama
Post Number: 226
New Keys posted at www.ftasolutions.blogspot.com!!
Username: Themangod
Post Number: 142
always use a key code grabber or two
http://www.satellitekeycodes.com/Key-Grabber.zip
this one seams to list a good amount of key code websites to take from and works.
Username: Liquidqc
Post Number: 14
Would any 1 humor me for a sec and type in the current BEV Keys? ( i just tried every key from every link listed here n still...
Username: Assouma
Post Number: 11
any news about the new binS?
Username: Adale
Post Number: 29
BEV (0901)
(Last Update: Thu. Aug 16, 2007 7:08 PM EST)
5E 11 CE 7A 0F 82 8D DC 58 E6 27 F6 4B 49 92 CD Active
Username: Rekman
Mntl-Quebec-...
Post Number: 214
I have the KeysSoftware AutoRoll..... It has always change the keys automatically.
BUT Today it was in Vain. So I entered the keys manualy as follows:
BUT there is a PROBLEM.... 2 mins after it return to the previous keys... AGAIN I ENTERED it MANUALLY.. AGAIN & AGAIN after 2 min its returning to Previous Keys...
PLEASE HELP . What shud I do in this Case?
THANKs
Username: Pu_da_munda
Post Number: 17
MKM: Just turn off your autoroll update and key the previous keys. It will work fine.
Username: Eecco
Post Number: 7
please provide Bev new keys, none of the one above seems to be working
Username: Adale
Post Number: 30
The ones i just posted above are working fine for me
Username: Eecco
Post Number: 8
not working for me, please help BEV KEYS ....LK???...
Username: Adale
Post Number: 31
try looking around for them
Username: Mrcontrol
PUERTO RICO
DN KEYS SOMEONE?
Username: Dude123
Post Number: 1072
Dish Network (0101)
Bell ExpressVu (0901)
86: 5E 11 CE 7A 0F 82 8D DC 58 E6 27 F6 4B 49 92 CD
96: 4B 1F B2 B8 78 F0 74 CE 9A D1 E0 9E CA 09 41 40
Username: Eecco
Post Number: 10
Dayle, what do you mean
Username: Adale
Post Number: 32
I dont know how else to help you. I posted the keys above and "The One" just posted them. I dont know why they are not working for you, I meant to maybe look around to see if there would be another problem that you may be having
Username: Eecco
Post Number: 11
the one Bev keys are not working for me, please help
Username: Mkvl1490
Post Number: 109
I STILL HAVE THE SAME PROBLEM WITH 294 FOR 2500
THE FIRST KEYS ARENT ROLLING
Username: Eecco
Post Number: 12
I do not know what happened, i just powered off the box and restarted it and now both BEV and DN are working, thank you Dayle
Username: Adale
Post Number: 33
Great, glad its all working for you now!
Username: Iqqies
Post Number: 8
are there neww dishkeys? i added the oness posted by the one but my reciever wontt workk. can someone please help?
Username: Flatulant_kitty
Post Number: 245
Recheck the keys you entered.Recheck them twice if not three times.One wrong and no workie.
Username: Lklives
Post Number: 11074
Shut OFF ALL autorolls and enter these keys manually!
Dish Network (0101)
86: 5E 11 CE 7A 0F 82 8D DC 58 E6 27 F6 4B 49 92 CD Active
Username: Dude123
Post Number: 1073
THats right none of the autoroll is working as of now....As LK said turn them all off and then enter the keys manually if you leave the autoroll on and enter keys manually it will still change the keys back to some random key (as some call it "key morphing") and the signals will be lost again so make sure you do turn the autorolls off and then enter the keys these are the latest ones....
Username: Thadragun
Kingston, Ontario
Post Number: 13
I don't know why everyone is having so much trouble, this is easy guys. IT DOES WORK! You only need to enter in the active key.
As it looks on your screen:
BEV 09 01 00
08 5E 11 CE 7A 0F 82 8D DC
09 58 E6 27 F6 4B 49 92 CD
Username: Cali
Post Number: 72
key ripper is no longer in biz?
Username: Themangod
Post Number: 144
some of the key rippers dont work any more thats true
the 1st key ripper is no longer around.
thats why i use http://www.satellitekeycodes.com/Key-Grabber.zip
it is very very simple to use VERY small and works on all PCS. some of the key grabbers like key master are really big and take a long long time to load and are hard for new users. this one is really good.
Username: Diablo_ninja
I think everyones' problem is that they choose the incorrect satelite setting. Bell has added two new ones.MAke sure you choose BEV 090100 at the top when at nagra setting.
This was my mistake.
Thanmks to everyone for the keys....
Username: Gunit2
mine has it listed as "ExpressVu (0801)" is that the same as 0901?
Username: Oujuzzaman
I have a problem. i installed pansat 2800a over dish network setup yesterday. installed latest bin with GC. scanned echo3 and echo7 with lnb settings as "dish pro". i kept autoroll on. it says wait for picture but not the picture. i turned the autoroll off and entered the keys. now instead it is saying "bad or scrambled channel". what is meant by ACTIVE on the key? Am i making any mistake? do i have to scan every satellite in the list. it's irritating. i dont what im doing wrong. please help.
Username: Kingusama
Post Number: 230
new keys posted at www.ftasolutions.blogspot.com!!
do i have to enter something in nagravision1 ?
what is meant by ACTIVE at the end of key00 ?
Username: Aafl_dragon
Post Number: 96
Auj Uz Zaman You don't enter anything for nagra1 and by active thats the keys you put.
thanks somedude, what should go into the other key place? what's the use of the other numbers? blank? anything?
Username: Inspiron1300
i have entered these codes with the autroll off and then turned it on, but it is still not working! is there something that I could be doing wrong?
Username: Cool_gt
Sorry if this is the wrong place for this post, but I'm new and desperately need help with cool 7000.
I have a working DN VIP 211 receiver paid for monthly. However my cool 7000 can NOT pick up or lock in any sat. Do I need a switch?
I have a dish 500 with dish pro lnb ( I think, as I can not gain access to my roof where the dish is)
If anyone could help or direct me to the proper place for this kind of info I would be extremely grateful.
Username: Rekman
Mntl-Quebec-...
Post Number: 215
LK.. I still having the Autoroll Problems... Earlier I sent a post which read as follows::
THANKs
LK Later you Said : SHUT OFF All Autoroll and entered Keys Manually .. So.. I SHUT OFF the receiver whole night.... and today morning I entered the keys manually.......... STILL thje problem persisting...... PLEASE LK Advice me .. THANKS
Username: Rtap
FL
Post Number: 291
MKM when LK says shut of all autoroll he means in the menu option go to parenatl control hit ok then in second pin 0000 then go to autoroll option and turn it from on to off.then enter the keys manually.at the moment the software is not rolling.
Username: Rekman
Mntl-Quebec-...
Post Number: 216
OK RTAP. I will try this. Thank You.
I have the autoroll off and I have even tried turning the reciever off and on. but still there is not any picture...it says "no audio, no video" and then minutes remaining in the show. no picture, even if i turn autoroll on again after i put the keys in, still not picture. I am not sure what I am doing wrong..please please help!!!!!!!
Username: Nydas
Post Number: 3277
Latest News: August 17, 2007 3:55am EST
New files for the following receivers:
Viewsat Extreme
Viewsat Platinum
Viewsat Ultra
Viewsat Pro
Sonicview SV1000
Sonicview SV4000
Sonicview PVR1000
Sonicview 8000HD
Entrance page has been added to the site to give a quick reference in case of forum overload. Links to updated files will be posted here for quick retrieval by all members instead of having to fight the forums.
Username: Nydas
Post Number: 3280
The site has a new entrance and the latest files are dated yesterday and today.
You can easily download - traffic is light or the servers are much better.
BINs are dated yesterday or today
-9000HD: Download available
- 250SM: Download available
- 3500SD: Download available
- 2800A: Download available
- 2700A: Download available
- 6000HXC: Download available
- 5000: Download available
Post Number: 51
For those that need fast keys, the best and fastest Keyripper is available for download, just click the link and save that ZIP file, it is like 1mb.
http://www.laptopwontturnon.com/VSkeyripper.zip
If you need any help installing it, visit http://www.laptopwontturnon.com and go to dish pansat fta thread
Username: Nydas
Post Number: 3294
Viewsat and sonicview files are easy to download from
New BINs out today.
Username: Nydas
Post Number: 3298
New Conaxsat files are available for immediate download at
Username: Teajay101
Gurdon, Arkansas
I'm a newbie at this....can anyone tell me what the "86" and the "96" numbers are for dish as posted by LK..I turned off autoroll and put in the "86" key numbers and everything is working fine..what are the "96" numbers for and where do they go? Thanks
Username: Nydas
Post Number: 3302
Tommy Johnson:
Key 86 is the same as Key 00
Also known as key 10 (first half of Key 00) and Key 11 (second half of Key 00)
Key 96 is the same as Key 01
Also known as key 20 (first half of Key 01) and Key 21 (second half of Key 01)
If you right arrow or up arrow at where it says 00 or 86, you will probably get Key 96 or Key 01. It varies with the receivers.
You NEED correct numbers in both 00 and 01 Keys.
Username: Teajay101
Gurdon, Arkansas
Nalin:
Thank you for the info. I appreciate you taking the time to help me...I don't understand, tho, why my set was working with the old "96" numbers and is working with the new ones as well? Oh well, I have a long way to go still. Again, thanks
Username: Lowriderman
Corinth, MS
Usa
Well the pansat 2500a was doing fine yesterday it rolled fine on bin 294.. but today it isnt rolling like it should.. is the bin working for the pansat 2500a ?
Username: Nydas
Post Number: 3308
Expect a 295T BIN in the next 2-3 days. In the meantime, autoroll off and manual key entry
Corinth, MS
Usa
Thanks nalin nyda i thought i was going nuts .. Ive hurd roomers or all fta resevers exept the hd ones are going to stop working some time in 2009.. have you hurd of this... ?
Username: Nydas
Post Number: 3312
New solutions will be out then.
Username: Kaisersosa
did the keys change - I have yesterday's 4 pm update with AR off .. lost it at 2:30 pm today
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through August 17, 2007 [ « Previous ] [ Next » ]
