Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through August 12, 2007
Author Thread: Archive through August 12, 2007
Username: Arabiankiller
Hamilton, On
i have a problem. sometimes the key i put in gets changed. The firs letter or number. How can i stop that from happenening?
Username: Canndy
Post Number: 429
NEW KEYS NEW KEYS
www.fta123.blogspot.com
GLOBECAST KEYS NEW
www.gcastkeys.blogspot.com
Username: Nydas
Post Number: 3182
cotton coots:
Keys are security measure used by providers. Usually there are two lines of 16 two digit hex numbers. They are referred to as Key 00 and Key 01. Both the lines have to be entered in full and have to be present for the receiver to work, so in reality, there is nothing like Active and passive keys. The last changed key is usually denoted Active key.
Autoroll in a software BIN started about 9-10 months ago. In this the new software allows the new keys to “roll in”, so there is no need for manual entry. There have been many changes in the way the autoroll work and every time such a change occurs the old autoroll software stops working well. The last such change was about 12 days ago and in most receiver we have a “fix” i.e. a change in the BIN, such that the autoroll works well. Not so with the Pansat 2500A, a receiver widely used. We still need to install the keys manually. There is some relief however. With the 293 and 293T BIN, the keys do roll in whether you have the autoroll set to off or on. However, the first digit in both key 00 and key 01 gets changed – the top bit get inverted and you have the first digit shifted by 8. If therefore, you allow to let the keys roll in, and change the first digit of first number (both key 00 and key01) by adding or subtracting 8, you will get the correct key, which you can save and watch TV.
Why has Pansat or BL not implemented this change so far? – I really do not know.
Why are the keys changing so often? – it is DN and BEV’s decision to keep on putting their own security measure as often as they wish.
Username: Ariza_700
Hello folks I need some help: I have ariza 700 and I am using 295eEU bin file.
I am using the following active key :
00: B8 7C AA A2 23 57 2D 44 FF 91 9C E6 39 53 50 9C
For some reason the first digit of the key(B8) is keep changing into 38. I have tried different setting :
1) AUTOROLL/EMU: ON or OFF
but the screen is keep updating the data. The data update goes to 500 % and start again.
when the data updated the first digit of key will change again.
Any help will be greatly appreciated.
Thx
Username: Nydas
Post Number: 3183
ariza 700: Read my long post just above yours.
Ignore the long wait. Keep autoroll off. when your picture goes, turn autoroll off, switch off and on at the back, and wait for about 1 minute.
The keys will have rolled in but the first digit is changed in both key 00 and key 01. Change it by subtracting or adding 8. Turn autoroll off and watch TV.
Username: Alazadam
I have a Faortecstar lifetome Ultra reciever andi want to upgrade it to 294T bin I heard it's out already.Please help me to find a website from where i can download the 294T bin
Thank you
Username: K98
Post Number: 73
thank you nalin good info glad you are back keep up the good work you are the best sincerely cotton coots k98
Username: Nydas
Post Number: 3184
Abdel Aziz Rajabi :
DO NOT USE the 294T BIN till somebody responsible here gives an Okay.
besides me, trust, Julie, LK, satscanner, The One, to Okay it. As far as I know there is NO new BIN 294T out yet.
Username: Blueash
Hi i am using viewsat extreme i hav added all latest keys but i cant see indian channels i can only see american channels wht changes shud i do???
Username: Sunny12
Montreal, Quebec
hi folks, i change my key, signals r coming but picture is not coming, i did blind scan also, but same problem, plz help
Username: Julian_thomas
Atlanta, Ga
Usa
Hey guys just got in and put new keys (58 EB 99 9E B1 A8 2A EA 10 AB 67 BD 2D AA 56 75)and got nothing,am I missing something today. are there new keys?
Username: Laviniatrifoi
Toronto, Ontario
thanks forthe keys they work
Username: Nadxia
Dayton, OH
Post Number: 12
Hey Nalin, Nice to have u back.
Could you please tell me from where I can download 293 or 293T BIN for my Pansat 2700A.
Thanx always
Username: Nadxia
Dayton, OH
Post Number: 13
Or
Can I have the latest bin for Pansat 2700A
Username: Srpskkisiin
Post Number: 37
Dish Keys August 11th 2007 430pm
00:58 EB 99 9E B1 A8 2A EA10 AB 67 BD 2D AA 56 75
01:85 1D AC 71 96 8E 7C 01AB D3 42 A3 C4 D9 CA 62 --
visit http://www.jordinclub.com/forum
Username: Superstar69
thanks luke smith for them keys
keeep it rollin
Username: Tammy
Post Number: 7
Im hoping someone can help me, im trying to get echo 7 and i have found 6,8 does anyone know how far right left up down from 6,8 i need to go? Thanks in advance.
Username: Gusification
Post Number: 52
anyone got keys?
Username: Intra
D/N Active key 01 :
85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62
Username: Pannu16
Post Number: 418
dishnetwork
86: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67
96: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82
Username: Synister
Thank you!
Username: Intra
bad keys pannu ...
Username: Top2000dogg
Post Number: 30
yeah pannu bad keys!!!
Username: Moej1991
Post Number: 7
keys
Username: Cacalad
Post Number: 24
new keys for dish please
Username: Snw7619
Bahamas
why keys keep changing but only second number changing
please explain.
Username: Cacalad
Post Number: 25
keys please for dish
Username: Poonam008
Post Number: 14
96:85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62
It's working
Username: Guicho01
D/N Active key 01 :
Username: Snw7619
Bahamas
i put me keys in manually 2500 pansat dishnetwork
which other way can i program sat.
Username: Creek
Smithtown, New York
Post Number: 370
I'm tired of entering keys!
Is there a new file to fix this auto roll?
The last one I downloaded was DBPSW-070801X.
Post Number: 31
none of these key work!
Username: Freddy14
it does not work for me..
pansat 2500
Post Number: 32
pansat 2500 clone! does anyone know the new keys
Username: Khopdi
Post Number: 44
You f*ing retards. Some of you are toatally screwed. Please f*ing read before you start asking for f*ing keys. A little reading goes along way. Also, pay attention to title thread before you start posting your questions. Again, little research goes a long way. LK, you know what I am talking about. Nalin, I am sick of these neewbies asking dumb questions before doing any research on the topic.
Username: Stormintv
Sudsbury, ON
Hey Momar Kadopi, go change your diaper before you come on here. Not everybody catches on as fast as you want them to.
Username: Nestea
Post Number: 72
DN and Bev Keys Feed
Nag2 keys
Dish Provider 0101: Last Updated (11 Aug '07 6:45 PM EST)
Key 0: 58 EB 99 9E B1 A8 2A EA 10 AB 67 BD 2D AA 56 75
Key 1: 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 (Active)
Bev Provider 0901: Last Updated (6 Aug '07 12:01 PM EST)
Key 0: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67
key 1: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82 (Active)
Sat, 11 Aug 2007 17:46:51 CDT
Username: Lklives
Post Number: 10862
DISH - Last Update: 08/11/07 05:28 pm EST
00: 58 EB 99 9E B1 A8 2A EA 10 AB 67 BD 2D AA 56 75
01: 85 1D AC 71 96 8E 7C 01 AB D3 42 A3 C4 D9 CA 62 Active
BEV - Last Update: 08/06/07 12:09 pm EST
00: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67 Active
01: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82
Khodpdi...I undertsand 100%...People are too lazy to read...or follow simple common sens and post in the correct threads...this thread is a perfect example ...even posting keys here is ridiculous hwn there are so many other key finder utilities and direct links to the latest keys.....and use of autorolls and sites in the "recommended sites" thread would stop 99% of these posts, asking VERY ridiculous already answered 100x questions......
Username: Mkvl1490
Post Number: 106
LOL
i kind of have a weird problem
my bin autorolls
when it autorolls, all the keys are correct beside the first letter or number of each one
for example
58 - C8
85 - 35
just only the first one. its weird thats the only problem. i know i need a bin, but why its like that
Username: K98
Post Number: 75
nalin are ypu tired of posting d.n. keys ifnot please keep us posted if you are tired of us ignorant people then i understand but we really need you back on this site
Post Number: 34
the dish keys aren't working anymore!
Username: Demon101
Rochester , Ny
America
Post Number: 20
CAN ANYONE TELL ME THE KEYS FOR GLOBECAST KEYS? FOR BOSNIANN TV?
Username: K98
Post Number: 76
sean look at l k s post they work
Post Number: 35
at what? what is lks?
Username: Hooch
They aren't working for me
Username: Hooch
I have turned off autoroll and put in latest keys for 01 and nothing happens. Anyone else having same problem. Running Co*ls*t.
Username: K98
Post Number: 77
keys are good check lk last set of #sposted
Post Number: 36
they were good not anymore! i had the keys but then they just stopped working.
Username: K98
Post Number: 78
LK posted dish network keys for d.n. oo o1 check this reply board your post is on
Post Number: 37
the 00 is the one i had and it doesn't work anymore!
Username: K98
Post Number: 79
re set de fault then re enter keys sean
Username: K98
Post Number: 80
sean let me know if the keys oo are not working mine is fine i have pansat 2700
Post Number: 38
i have it doesn't work! i have a megasat yt6688 which is a pansat 2500 clone!!
Username: K98
Post Number: 81
sorry i dont know about your eq. nalin is a good source to contact on this site
Username: Hydro_blazer
New Keys Please
Username: Lklives
Post Number: 10863
DISH - Last Update: 08/11/07 08:35 pm EST
00: D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7 Active
For all receivers!!!
Username: Tausif
Post Number: 11
New KEY Pl.
Username: Snw7619
Bahamas
thank LK working now
keys going off like every 2-3 hours why
Username: Snw7619
Bahamas
Username: Cacalad
Post Number: 26
new keys please
Username: Snw7619
Bahamas
autoroll off
thanks for the keys LK
Username: Snw7619
Bahamas
Post Number: 7
braves winning over phillies
mets tied marlins
thats dishnet
Username: K98
Post Number: 82
thanks lk for posting the oo numbers so fast how do you get them so fast
Username: Juanjose
Post Number: 36
thanks for the keys shannon wong
Thanks LK
Username: Lklives
Post Number: 10864
U want keys fast...then use these DIRECT links below or download they key finder utilty program to your computer desktop "Keymaster 4.0"
here's keymaster 4.0
http://www.dsscommunity.c*om/forums/viewtopic.php?t=3865 ...remove the * from this link...then register FREE...its a good site too for all new files and manuals and guides...
Direct links to keys....
www.dss-keys.com
www.tvkeyz.com
Username: Lklives
Post Number: 10865
U want keys fast...then use these DIRECT links below or download the key finder utilty program to your computer desktop "Keymaster 4.0"
www.dss-keys.com
www.tvkeyz.com
Username: Lklives
Post Number: 10869
Heres the Latest GlobeCast keys....
GC - Last Update: 08/11/07 12:00 am
00: 0F 2B 8A 31 84 D7 2D 2B 40 FF 5E 0B B7 DB 0D 4A Active
01: 83 20 3C A8 E5 7B 93 A6 7B 12 67 AB 40 62 03 B1
Username: Adnom
Thanks LK for the keys
Username: Memin1
hey everybody im new to this stuff can someone plese give me the new keys for the DN please thanks
Username: Destine0429
Quebec
Post Number: 226
Here ya go Mario. You should look above before you ask. Since the keys are always posted here. Do you know how to manually enter them in?
Key number 00, where is says Active after it, means that you only need to enter in this set of keys for the receiver to work.
Username: Nydas
Post Number: 3185
Nadeem: You asked "Could you please tell me from where I can download 293 or 293T BIN for my Pansat 2700A."
293 and 293T BINS are for Pansat 2500A and Pansat 2500 clones repectively. They are NOT for 2700A.
For Pansat 2700A you should have upgraded to Boot 75 a few months ago and you should now be using BIN 205 on top of it. The instructions/procedure has to be exact, and you should go to one of the following sites and get the Instructions, the B75 file, the 27.02 loader, factory BIN and the latest 205 BIN. You must follow instructions precisely as posted.
All files have to be unzipped before use.
If your receiver is a 2700A clone you should use the clone safe 205 Tivo BIN.
http://www.future-fta.info
http://www.al7bar*tk
http://www.dssrookie.com
http://www.f2atv.com
Username: Nydas
Post Number: 3186
creek:
I am surprised that the DBPSW-070801X BIN for Viewsat extreme is not working for you. All reports indicate that it should work, immediately after installation into your receiver. Check the version in your receiver to see if it is the one you have installed
Username: Nydas
Post Number: 3187
sean akins: megasat yt6688 is a pansat 2500 clone.
You are probably changing to the latest keys but not changing the first digit of the other set of keys.
If you have installed 293T BIN, the keys will autoroll with autoroll on and at time with autoroll off.
They will not work till you do a little change. On the first digit od Key 00 and key 01 add or subtract 8. After making the change save it and turn autoroll off. If you are not sure about how to add/subtract 8 to a hex number, somebody has put out a table for you to use in this thread only recently.
Username: Tausif
Post Number: 12
New KEY Pl.
Username: Kingusama
Post Number: 208
visit www.ftasolutions.blogspot.com for the latest keys and files!!
Username: Ddlj
New Keys Pls.
New Keys Please
Username: Keyz_plz
New keys please
Username: Dannienjulie
Post Number: 30
I tried putting these keys in but they won't work what's wrong?
Username: Iqqies
need new keys for DN!! pleasee
Username: Bich_d
Toronto
Post Number: 25
DN:
86: D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7
96: 8C F5 E5 42 3D EC 51 4D 52 3E DA 4C 21 DC 86 85 New
Username: Khopdi
Post Number: 47
86:D1 8D 5D 1E BF 23 4A 93 1C F5 B4 E7 25 FB 16 A7
Post Number: 31
I tried both sets but they don't work.
Username: 1tina_chick
Post Number: 83
01: 8C F5 E5 42 3D EC 514D 52 3E DA 4C 21 DC 86 85
Username: Ddlj
Post Number: 7
Thanks A TON.
thank you ladies and gentleman
them keys works
Username: Mzakcat
Post Number: 45
they work
Post Number: 32
Thanks to allI got them working I'm not to smart.LOL
Post Number: 84
My Signal is a solid 94 -97 % Upload
Username: Babaali
Post Number: 11
htank for new keys
Username: Seetoronto
Hello Guys,
Anyone interested in the Latest Viewsat Extreme PGM file email me.
my email is seetoronto@gmail.com
I am selling it for only $ 6.00 US (six only)
Anybody wants it... ??? i can give you the web address where you can buy it...
Once you buy it the latest PGM file will be emailed to you within 3 hours.
Thank you
seetoronto
Username: Minena77
Post Number: 31
You can get the latest Viewsat Extreme file for free at www.dssrookie.com
It is not necessary to buy it
Username: Zayeshaz
Surrey, BC
thanx...they workk!:-)
Username: Dsource
Post Number: 10
VS BIN
application/x-zip-compressedUpload
1000000221.zip (3.4 k)
Username: Dsource
Post Number: 11
http://www.ftatech.net/forums/
Everything your going to need
Username: Dsource
Post Number: 12
download keymaster 4.0 for new keys and updated keys
Username: Dsource
Post Number: 13
DISH - August 12 - 96 changed @ 11:00 AM EST
BEV - August 5
GCast - Aug 11
86: 0F 2B 8A 31 84 D7 2D 2B 40 FF 5E 0B B7 DB 0D 4A
96: 83 20 3C A8 E5 7B 93 A6 7B 12 67 AB 40 62 03 B1
Username: Cycomykosxtx
Post Number: 13
new keys?
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through August 12, 2007 [ « Previous ] [ Next » ]
