Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through August 11, 2007
Author Thread: Archive through August 11, 2007
Username: Mlewis337
Post Number: 7
i have a fortec star lifetime ultra and some of my channels are missing and when i blind scan for them they dont show up what should i do
Username: Zayeshaz
Surrey, BC
helloooooo...
dishnetwork keyssssssss pleaseeeeeeee
00 or 01???????
Username: Nydas
Post Number: 3172
aisha virk :
You need correct Key 00 (86) and key 01 (96) for the receiver to work. There is no need to think about active or not active. They are all active.
Username: Sincerelady
Oakville , On
Key 0: 33 9C 56 33 2D 71 64 AE DB 54 70 B1 89 01 53 99 (Active)
Key 1: 86 AF 32 30 CE D8 B6 4C 0C 39 51 40 A7 73 D5 C4
Username: Zayeshaz
Surrey, BC
not 86 or 96 i have a different onee
i've got 00 nd 01 onee...
i m so confusedd:S
Username: Ww228king
Post Number: 16
mabey we should have a class on abbreviations ...............DN = Dish Network
Username: Simmi_01
how do u add channels if u accidently have deleted it, i have viewsat platinum dish and all the channels are not working so if u can guys plz tell me y they are doingthat, because the echostar 1,2 are working but the ones that say echostar 7 those don't work
Oakville , On
yes this are for dish network and 86 stand for 00 and 96 stand for 01 .
if you want bev
Key 0: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67
key 1: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82 (active)
hope you will not be confused.
Oakville , On
Post Number: 7
so it is
Dish Provider 0101
for Bev Provider 0901
Username: Lklives
Post Number: 10823
Keymaster 4.0
DN and Bev Keys Feed
Nagra2 Keys
Dish Provider 0101: Last Updated (10 Aug '07 12:00 AM EST)
Bev Provider 0901: Last Updated (6 Aug '07 12:01 PM EST)
Heres the Keymaster 4.0 utility file...have the keys right on your computer desktop!...no need to go to any site LOOKING for keys!
http://www.dsscommunity.co*m/forums/viewtopic.php?t=3865 ...just remove the * in the link above...all sites require a FREE registration
Username: Georgia_girl
Helenwood, Tn
Unitedstates
i tryed the keyz for bell and run scane it still says scrambled or bad help?
Username: Drgaili
Post Number: 14
DN keys arn't working!!is there any thing needs to be done to the reciever?
Thanks to all
Username: Spaulding
does anyone know how the add or substract 8 work? Which set of numbers do i apply it to?
Username: Spaulding
which set of numbers do i apply the add / substract 8 to if these are my numbers?
Username: Albino_midget
Post Number: 591
david, http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1218802#POST1218802
Username: Dsource
Post Number: 9
Need 8000HD loader anyone have or know how to get?
Username: 1tina_chick
Post Number: 81
Key 1; 09 73 64 46 5c 31 8e fd 17 64 86 do 90 17 72 b1
Enjoy !
Post Number: 82
Valco Try dsstester.c*m......... and READ past posts !
Username: Srpskkisiin
Post Number: 33
Dish
Last Updated: 2007/08/10 12:27 PM CST
00: 33 9C 56 33 2D 71 64 AE DB 54 70 B1 89 01 53 99
01: 09 73 64 46 5C 31 8E FD 17 64 86 D0 90 17 72 B1
for more visit http://www.laptopwontturnon.com
Helenwood, Tn
Unitedstates
tinachick are those for bell itryed it still says scrambeld or bad?
Username: Dude123
Post Number: 1065
georgetta chambers
no those are for dish network here are the latest ones for bell
Username: Maria88
these keys are not workingg
Username: Siebel_99
can somebody post new keys
thanks a ton
Username: Poiuyt1
I red several times that there is no new bin for 2500a clone. Hence, they are suggesting to enter keys manually. Since I am new, here is my questions.
Where are these keys?
Are keys are receiver specific, I mean does every receiver have its own key or all receivers have same keys.
Also, are you suggesting once we change keys manually and having 293t bin our receiver will be running ?
Thanks in advance, poiuyt
Username: Top2000dogg
Post Number: 29
what receiver do u have? and yes all keys are for all receivers
Username: Dude123
Post Number: 1067
yes eddy
go to your menu and first turn your auto roll options off and then enter the keys manually. if you look some posts above the latest keys are there just make sure you enter the right one if you are using dish network services then enter dish network keys and if you are using BEV then enter BEV keys. These keys are same for all receivers.
Good Luck
Post Number: 34
Dish
Last Updated: 2007/08/10 2:40 PM CST
00: 4E 46 A3 5C 76 E0 EE 15 E0 B5 AE 4B 3E B8 B3 76
for more info go to http://www.laptopwontturnon.com
Username: K98
Post Number: 66
why are keys changing so much that u cant watch or record a movie on d.n.
Username: K98
Post Number: 67
nalin calling nalin help us dummies with d.n.
Username: Nysohail
Windsor Locks, CT
US
Whats the new keys anyone? for dish..
Username: Dude123
Post Number: 1068
They are keep changing the keys becuase they want you to pay for their services... either deal with the situation right now or pay to get satellite...
Here are the latest dish keys anyways......
Username: Jpz
MTL, QC
CAnada
Post Number: 236
new dish key 00: 4E 46 A3 5C 76 E0 EE 15 E0 B5 AE 4B 3E B8 B3 76 ACTIVE
Username: Dude123
Post Number: 1070
best site for latest Dish Network keys. Some times keys get updated there before they get changed keep it in your favourite list.
http://www.ftasolutions.blogspot.com/
Username: Jokerisback
Post Number: 32
is there a new autoroll file for pansat 2700a and pansat 3500sd
Username: Wakenbake
Post Number: 332
does a phat baby phart?
Username: Nydas
Post Number: 3174
Pansat 2700A. Install b75 boot first, then install 205 BIN. Use 27.02 loader.
Pansat 3500 - new BIN is dated 31/7/2007 - BIN321
Username: Nydas
Post Number: 3175
Luke and The One have posted the correct latest keys.
Username: Gx470
Hi, Can someone help me please. I have Pansat 3500
nagravision 2, Provider id 0101, DN key number 00 will not go to 01 with right volume key, It stays at 00, I can manually change to 01 but then it stays at 01 and will not go back to 00.
Any help is appreciated
Username: Lklives
Post Number: 10829
DISH - Last Update: 08/10/07 06:31 pm EST
01: 8D DD F5 23 12 FC F3 4D 95 9B 2F 05 40 75 6E BC Active
BEV - Last Update: 08/06/07 12:09 pm
00: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67 Active
01: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82
Username: Nvs
Post Number: 7
hi, i have the receiver eagle star its a clone of pansat i believe. i am entering the keys which are given by THE ONE, its not workin on my receiver its not giving me any signal. done anyone know what might be wrong with it?
Username: Moej1991
new keys please
Username: Dannienjulie
Post Number: 26
any body have new keys to D/N
Username: Vlemar
Mississauga, Ontario
Post Number: 30
fom which site can I get boot rom and loder files. Got bin file from dsstester.
Pls advise
Post Number: 28
Sorry I just seen them above. Thanks LK
Username: Vikas_ngp
Username: Gx470
Username: Babaali
Post Number: 8
thank you vikas for new key
Username: Zayeshaz
Surrey, BC
hey guyzz..how come the keyz r changing so muchh?
i mean isnt it suppose to be only oncee???
Username: Crazy_greek
Post Number: 1072
I guess my eyes are going bad.
On the keys that (The One)has posted above,
On (01) I only count (15)
last # is missing?
Username: Nash911
i am loosing signals on my viewsat extreme box
can someone helpp me please
Post Number: 594
thats what they say--jack it-- and you will go blind
Username: K98
Post Number: 68
thank u vikas 4 new keys looks like nalin is quit ; nalin used to be first with #s come on nalin get back to the top !!!!!
Username: K98
Post Number: 69
nalin nalin nalin nalin nalin come on were counting on you
Username: Nydas
Post Number: 3178
I don't live by the television all the time. There was a time when some of the so-called seniors here were being outright abusive to anyone asking for keys and I had to make sure that people who want to watch TV got the keys.
There are a lot of good posters who come out with the keys immediately. It is NOT who has the keys first that matters. What really matters is to get the keys out to the public.
I have stated before in this thread and in another thread, that you do not really have to wait for the keys. with the autoroll off and sometimes with it on the keys are rolling in. Under the 293T BIN the first number is corrupt in both key 00 and key 01 and all you have to do is to add 8 or subtract 8 from the first digit i\of key 00 and key 01.
Username: Wakenbake
Post Number: 333
did you click your heeels three times
Username: Patrascua
if you have something else for key generation please let me know. I use bev. tx adrian
Username: Inspiron1300
we have extreme view sat. 2000. we tried dish and bev keys but nothing is working, cansomeone please help. autoroll is off!
Username: Lklives
Post Number: 10839
Insp...load up the 070801 Extreme bin and TURN ON the autoroll...then watch TV...
BTW...U know if U COULD read U may have a better shot at watching TV...lmao
Username: Desakia
Post Number: 9
NEW KEYS AS OF 8:36
Dish Network 0101
Last Updated: 2007/08/10 8:36 PM CST
86: B8 7C AA A2 23 57 2D 44 FF 91 9C E6 39 53 50 9C
96: 8D DD F5 23 12 FC F3 4D 95 9B 2F 05 40 75 6E BC
Bell Logo
Bell ExpressVu 0901
Last Updated: 2007/08/05 6:00 PM CST
86: D5 D2 91 84 05 4E B6 18 C5 B7 2D E1 7C BE A0 67
96: E8 0B 3E B3 D7 F1 BA 6E 9A 1A D6 95 62 9D 7C 82
Username: Lklives
Post Number: 10842
DISH - Last Update: 08/10/07 09:38 pm EST
00: B8 7C AA A2 23 57 2D 44 FF 91 9C E6 39 53 50 9C Active
BEV - Last Update: 08/06/07 12:09 pm EST
Username: Jpz
MTL, QC
CAnada
Post Number: 237
thanks for the keys
Username: Laviniatrifoi
Toronto, Ontario
cani get thekeys plsssssss asap
Username: Bballbreak
Post Number: 10
can some one tell me if there is a new bin with a reliable auto roll or if there is a key ripper that i can use . please help
Thank you
Username: Xtrawest
Post Number: 61
Thank LK....
Username: Xtrawest
Post Number: 62
Thanks LK....
Toronto, Ontario
I need the dish keys As Soon As Posible plz i wana wach a movie.
thanx
Toronto, Ontario
i got them from another site thenx anyways
Username: Gujugangsta320
hey my keys changed by its self...i thinks thats kool...i have a pansat 9000hd...i guess thats wt u call an autoroll? might me wrong but thnx anyway LK.
Username: Pike_376
Post Number: 9
can someone please tell me what they are
Username: Babaali
Post Number: 9
thank you lk for new keys
Username: K98
Post Number: 70
lk has new keys posted beat nalin again ;check message board trifoi
Username: Pike_376
Post Number: 10
please i still do not have the new keys
hello
Username: Strider_143007
Swainsboro, GA
Post Number: 11
key 0: B8 7C AA A2 23 57 2D 44 FF 91 9C E6 39 53 50 9C (Active)
New key for dish happy watching
Username: Sudalay
hey can some1 tell me how to apply the add 8 subtract 8 situation plz?
Username: Lk_shutup
0+8=8
1+8=9
2+8=A
3+8=B
4+8=C
5+8=D
6+8=E
7+8=F
8+8=0
9+8=1
A+8=2
B+8=3
C+8=4
D+8=5
E+8=6
F+8=7
Username: Maria88
huh? whats that for?
Username: Bhardwaj
i have a viewsat. I put in the keys and turned on the auto roll, now i have sound but a assorted picture. what should i do
Username: Zack1
I am slow, can some body explain with example the table above "
0+8=8
1+8=9
2+8=A
3+8=B
4+8=C
5+8=D
6+8=E
7+8=F
8+8=0
9+8=1
A+8=2
B+8=3
C+8=4
D+8=5
E+8=6
F+8=7
How to use this table? Example please. thanks
Username: Lk_shutup
ex if the first key is 4F you would change the 4 to C (4+8=C) leave the F alone do this for the first part of the keys that your receiver has autorolled
Username: Destine0429
Quebec
Post Number: 222
It's funny. My husband mentioned this to me as well...and now, everyone else is talking about it too. And here I thought he was insane
Username: Lk_shutup
always listen to your husband!
Quebec
Post Number: 224
Lmao....yeah, maybe I should try to alittle bit more...But then again, I hate proving he's right
Username: Dude123
Post Number: 1071
yeah thats normal with the wives!!!! haha
Username: Shutterman11
my key code will not change with the volume control.
so i can put in both sets of numbers.
is my unit fried?
Username: Frobi
Guelph, Ontario
Post Number: 50
Try this:
1) put new batteries.
2) turn receiver off/on from rear switch.
Post Number: 35
Dish Keys August 11th 2007 12:00 pm
01:D9F85894C1B982657400765AB89C482E
more info at http://www.howdoiinstallforum.com
Toronto, Ontario
TAHX FOR THE KEYS
Username: Hello2007
Thanks @luke
Username: Babaali
Post Number: 10
than for key Luk smith
Username: K98
Post Number: 71
thanx luke i cannot get nalin to talk to us about d.n. #s or pansat 2700a bins 205 how to install or beat the current numbers constant changes
Username: Ariza_700
Hello folks I need some help: I have ariza 700 and I am using 295eEU bin file.
I am using the following active key :
For some reason the first digit of the key(B8) is keep changing into 38. I have tried different setting :
1) AUTOROLL/EMU: ON or OFF
but the screen is keep updating the data. The data update goes to 500 % and start again.
when the data updated the first digit of key will change again.
Any help will be greatly appreciated.
Thx
Username: K98
Post Number: 72
new kkys plz!!!!! 4 d.n.
Post Number: 36
for more visit http://www.laptopwontturnon.comDish
Keys August 11th 2007 1:00 pm
00: 58EB999EB1A82AEA10AB67BD2DAA5675
01:D9 F8 58 94 C1 B9 82 65 74 00 76 5A B8 9C 48 2E
Username: Ariza_700
LK,
WHICH ONE IS ACTIVE ? 00 OR 01 ?
THX
Username: Muzz
Toronto, Ontario
Post Number: 14
00 is working
Username: Cacalad
Post Number: 23
new keys for dish please!!!!
Username: Intra
D/N Active key 00 :
58 EB 99 9E B1 A8 2A EA 10 AB 67 BD 2D AA 56 75
Username: Fortec01
Post Number: 107
Username: Demon101
Rochester , Ny
America
Post Number: 19
hi anyone got the keys for globecast? bosnian channels?
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through August 11, 2007 [ « Previous ] [ Next » ]
