Home > Message Board > Home Video > DVD Players > Code needed for Phillips DVP3350
Author Thread: Code needed for Phillips DVP3350
Username: Richard_johnson
Please help, been searching for hours and nothing seems to want to work. This is a DVD/VCR combo - can this be done?
Any ideas / help please?
Richard
To clarify, I mean that I need to know how to crack the code to enable my DVD to play multi region DVD's.
Any ideas anyone? Not even the 'Crack DVD' sites know how to do this.
Kind regards,
Richard
Username: Veiko
Tartu
Estonia
PHILIPS DVP3100, DVP3350 REGION FREE
1. First you have to download "ZORAN.ZIP" and then attached
file which name is "LG36868.IMG"
2. Then You have to burn the CD with this file.
3. Insert the CD after finish burning the CD.
4. Then the region management menu will be shown.
5 If you input '0' and press 'pause key' by
Remote Con. Then Code free is done.
Download the ZORAN.ZIP
http://www.divx.pri.ee/index.php?name=Forums&file=viewtopic&p=387#387
Username: Valhallahal
DVP3350 Hack Fails
I have a DVP3350V/02, purchased in Austria and the posted hack does not work. The machine will not read the CD-R with the *.IMG file on it, but returns a "disc error" instead. It reads other, audio type CDRs just fine. Any ideas?
Hal
Username: Petervg
Hi,
I have here in the Netherlands the same issue as Hal - the DVP3359 DVD player is not reading the DVD-RW with the LG36868.IMG file on it. the display shows err.
Can this be an issue with the 4x compatible DVD-RW itself?
Any help uld be appriciated?
Thanks,
Peter
Username: Madriddvd
It worked for me. Try burning the cd with ONLY the file LG3868.IMG If the file contains anything else like a text file, etc. The dvd player won't read it.
Good luck
DVP3350 Region Code Change Clarified
Madrid Citizen cleared up two issues that prevent the DVP3350 from successfully reading the *.IMG file. First, DO NOT use Nero or anything like that to convert or otherwise process a CD image file to something else. Just use Windows or another facility and simply COPY the *.img file to the disc. Second, my DVP3350/02 would not read from a recycled CD-RW disc. Once I simply copied the *.img file to a virgin CD-R disc, the change region code menu loaded just fine. Thanks to all again.
Username: Maialideth
This worked for me
go to "Preference page" and press "138931" then with Arrow Up/Down set to 0
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Video > DVD Players > Code needed for Phillips DVP3350 [ « Previous ] [ Next » ]
