Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through July 31, 2007
Author Thread: Archive through July 31, 2007
Username: Nydas
Post Number: 3039
Khwaja: Read my post about the latest the keys above in detail and you will know what provider ID means.
Read my note to Sidhu about the latest BIN. You can find it in system info.
Username: Nydas
Post Number: 3040
Desi: Sorry, No card fix
Username: Desakia
thankx for the reply Nalin ,so do you know what the problem is though?
Username: Chechi
Post Number: 29
To Nalin Nyda.
Do you get all the channels with the 293T bin for pansat 2500 clone? Thank you.
Username: Haxit
In A Cave With A Lap-T...
Post Number: 75
keys are out again!!!!!!
Username: Haxit
Post Number: 76
hmmm... same keys but my sat was out, wierd...
Username: Desakia
Post Number: 7
If you guyz are using atmega cards or jeepers your tiers have expired (channels in the guide show up red)...d/l the new jeepers 4.2 program and you should be golden...keys are the same as of the last release date (07/12/07)
ENJOY!!
Username: 428217
Martinsville, Virginia
How do I get the English channels & Indian Channels on my Pansat 3500SD receiver without changing the bin numbers The only way to English channels is the change the bin numbers & when I do get the Indian channels I get only zee tv, B4U & Zee cinema So How do I get these channels on the same receiver without changeing the bin & How do I get all of the Indin Channels as well.
Username: Vaderpapp
Post Number: 10
bev keys!
Username: Muzz
Toronto, Ontario
new key anyone
Username: Nydas
Post Number: 3042
DN keys have not changed.
Username: Nydas
Post Number: 3043
Paresh: You are too confused to elicit a proper answer.
To get American channels and Indian channels, most people have two dishes. Indian channels are on Echo 3 (61.5W) for the East Coast, or 148W for the West Coast. The regular programming is on Echo 7 (119W) and Echo 8.1 (110W) usually.
Give more information on your dishes, LNBs, swithces, the connections, the BIN that is installed on Pansat 3500 etc and somebody might be able to help.
Username: Nydas
Post Number: 3044
Che G. : I think you should get nearly 100% channels on Pansat 2500 clones with 293T BIN. If you are missing some, do a blind scan, and if still missing some, do a specific TP scan for the missing.
Username: Chechi
Post Number: 30
Thank you Nalin for answering;
I did a blind scan for sat 110, I got all the foreign channels including the channel telling me welcome and congratulations you are pointing at 61.5; and I did the same for sat 119, and strangely, I got the same channels, and the channel congratulating me for pointing at 61.5.
So where is the problem? I have a disecq with 4 entries, and I am using number 2 & 3.
Is the disecq broken? So how come I am still getting one sat? Or is my other dish not pointing at the right direction? Mystère et boule de gomme as the french say.
Username: Chechi
Post Number: 31
Actually Nalin, I think, I am not getting the sat 119 W.Why?
Thank you for answering.
Username: Shortla
I have a Pansat 2500 And after putting in the new keys it switches back to the old ones after 3 to 5 minutes. Any clue what got changed?
Username: Nydas
Post Number: 3050
Che G. :
Presuming you have two sats and appropriate LNB in one for both 119W and 110W and in the other for 61.5W, then you should go into Menu/Antenna and do the following software connections.
119W - port 1 on DisEqC
110W - port 2 on DisEqC
61.5W - port 4 on DisEqC.
Then do blind scans.
Afterwards scanning each, if you up/down through the channels, you will see at the bottom left the actual satellite scanned. It really does not matter what sat you appear to be scanning. You will always scan the one you are pointing to.
The Dish which has 119 and 110 can have different types of LNBs to cause difficulties in scanning each separately.
A damaged DisEqC will always scan Port 1 only. NEVER connect/disconnect a cable to the switch with receiver power on. This is the most common cause of DisEqC switch burnout.
Username: Nydas
Post Number: 3051
Larry Short :
Do autoroll off. Then do set default keys. Then enter keys in the appropriate areas of Nagra 2.
Then SAVE.
Then exit, exit exit.
Username: Iagainsti
nalin i need ur help!!! my indian dish is only finding 4 indian n rest eng ch. ive done almost everything which i could through this website. can u guide me plzzz? cuz ma mom is eating my brains to fix this price of ******. ill be grateful to u.thx
Username: Shervin62
Post Number: 9
anyone has the new keys for bell
Username: Vaderpapp
Post Number: 11
my keys keeps on changing by itself but when i put the new keys, couple hours after it changes to the old keys. it happen 5-6 times already. all i have to do is put the new keys from last update but it keeps on changing back to the old ones. any1 knows how to fix that problem?
Username: Cacalad
Post Number: 16
i need to know what channel is the fight hopkins vs wright please someone
Username: Cacalad
Post Number: 17
anybody help me i need to know what channel is the boxing fight
Username: Bertoro
Toronto, Ontario
Post Number: 578
ab...set autoroll to off
Username: Patticake
Hello anyone willing to help. I have a colsat reciever and it is all screwed up. Can anyone tell me what to do to enter new keys and hopefully find all my channels. please
Username: Paper
U, U
U
Post Number: 21
DUDE DOWNLOAD A NEW AUTOROLL THAT WAY U WILL NEVER HAVE A PROBLEM WITH UR RECIEVER IT WILL FIX IT SELF.
DOWNLOAD FROM- www.dsstester,com
If u know how try putting keys in manually
Username: Paper
U, U
U
Post Number: 22
dude download autoroll
Username: Patticake
I tried to download cool sat 6000 file but it is corrupt or sothing it wont download how do i enter manually or is there a different file i can use?
Username: Amritdhillon90
i need the latest bin file for a pantec ultra v1 can someone please give me the link for the file :-) thank u very much
Username: Shervin62
Post Number: 10
anyone has the new keys?}}}
Username: Shervin62
Post Number: 11
for BEV?????
Username: Nydas
Post Number: 3056
amrit : Pantec is a Pansat 2500 clone. You need BIN 293T.
http://www.dssrookie.com
http://www.dsstester*com
http://www.dssevolition.com
You will find it in the Pantec and in the Fortec ultra section. Make sure it is a 293T and not just a 293 BIN. Use straight DB9 cable and BL updater 1.4 for the upload.
All files should be unzipped before use.
Username: Nydas
Post Number: 3057
Patticake : File uploading is sometimes tricky. Go to some of these sites and learn all the details of uploading a BIN.
http://www.f2atv.com
http://www.dssevolution.com
Username: Nydas
Post Number: 3058
Jeff Pattison: As "u" suggested, install the latest BIN and the keys will autoroll. You will find a wealth of information at the sites I have mentioned above.
Username: Shervin62
Post Number: 12
nobody here knows where i can find the new keys
Username: Denali_on_22s
Im just light up my......
Post Number: 2486
wtf?
Username: Shervin62
Post Number: 13
wtf what?
Username: Wakenbake
Post Number: 328
who the... what the...
keys at
tvkeyz.com
dss-keys.com
Username: Dannienjulie
Can any one help me I am not getting any of my local channels but I get everything else.}
Username: Wakenbake
Post Number: 329
LOL
what channels are your locals to be on
http://ekb.dbstalk.com/dishlist.htm
Username: Canndy
Post Number: 392
KEYS
www.fta123.blogspot.com
www.ftakeys.blogspot.com
www.dishkeys.blogspot.com
www.bevkeys.blogspot.com
www.dsskeys.blogspot.com
www.gcastkeys.blogspot.com
Username: Ahmad03
Hi Nalin Nyda..i need some help abt fixing of dish..is there any site from where i could get all information step by step that how to fix a dish from the begning..i mean fixing of dish plate outside connecting a new reciever with the dish and tv..and all after steps to get the signals..i mean what kind of settings required in the reciever to get the signals and channels..in other words when a dish fixing expert go for fixing a fresh installation of satellite anywhere..what procedure they adopt..however i know the procedure to download bin files and keywords..only want to know the initial procedure..and if there is a seperate procedure for all recievers..then let me know how to fix coolsat5000 platinum..i think u hve understood what i am asking..thnkx
Username: Nydas
Post Number: 3060
AHMAD BURHAN
Satelite calculator – Highly recommended.
http://www.kusat.com/install/calculator2.php
Satellite Angle Calculations
http://www.arachnoid.com/satfinder
http://www.satellitenut.com/calculators/SatelliteHeading.html
http://www.remotesat.com/lookangle.htm
A great site for all kinds of information.
http://www.lyngsat*com
There is alot of information in forums too.
Username: Maxpayne
Post Number: 8
i have a problem with my pansat 2700A. since 3 weeks, my pansat didnt work. I have good quality and good signal, but no IMAGE. I put the new keys.
DN and Bev Keys Feed
Nagra2 keys
Dish Provider 0101: Last Updated (12 july '07 1:30 pm EST)
Key 0: C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1
Key 1: 5B 27 8C AF DO 1E A5 A6 D7 74 3B A6 B4 21 17 97 (active)
Bev Provider 0901: Last Updated (10 july '07 7:00 PM EST)
Key 0: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5
Key 1 :CO 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08(ACTIVE)
It says: bad or scramble channel. How can i fix it??
someone help me please!!
Username: Demon101
Rochester , Ny
America
Someone plz help me with new keys for globe cast keys i need them!@ plz help
Username: Banej
Post Number: 238
no can do edin the problem is we dont have the keyz, but i hope we will see a A/R fix for Globo pretty soon.
Username: Demon101
Rochester , Ny
America
ohh damnit do u know when this problem will be fixed?
Username: Canndy
Post Number: 393
GLOBECAST, BEV, DISH, DSS KEYS
Username: Mac05
Post Number: 8
I am down any one with new keys
Username: Mac05
Post Number: 9
all the site as last posted 7-12-07 as the latest keys for dish,
as of yesterday i am down. can some one help me.
Username: R1010
Post Number: 105
Username: Mac05
Post Number: 10
those are the keys i am running now but no signal
Username: Dude123
Post Number: 1059
THose are the latest one.... what bin file are you using? did you try to turn your receiver off/on from the back?
Username: Mac05
Post Number: 11
not sure what bin i am using it was loaded up for me. and yes i did turn it off/on from the back.
Username: Nydas
Post Number: 3065
Ban Cook : Go into your receiver's menu, and find out from system info. Then post here what BIN you have.
Username: Mac05
Post Number: 12
OK Nalin but it won't be until monday i am out of town.
thanks
Username: Rtap
FL
Post Number: 269
Nagra2 keys
Username: Nash911
i have to reset my viewsat box everytime i change the channnel
need help plzzzzzzz
Username: Nydas
Post Number: 3068
Turn autoroll and autotp off. If this does not solve the problem, reinstall the latest BIN
Username: Tammy
Can someone help me, my tv is black and white and I can not remember what I did last time to fix it. Any suggestions wpuld be great. Thanks in advance, Tammy
Username: Tahdah
Post Number: 8
new keys please they just changed them
Username: Elreypr
Please not again!!!!! New keys please!!!
Username: Mocoa
Hey, Shut off your auto roll and plug in the
01 keys (Active)
5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97
This worked for me, however my 00 keys had rolled to something else so I put the old (July 12) keys in.
Good luck, this should get you back up and running
Username: Elreypr
That works!!! Thank You BJPoot
Username: Tahdah
Post Number: 10
still didn't work for me
Username: Scooby6969
Post Number: 7
with my pansat 2800a in the antenna setup what sat. do I setup for Bev (Nimiq1??)
Username: Jmortimer3
Ancaster, Ontario
I need the BEV keys. Anyone have them??
Thanks
Username: Dmc0923
Post Number: 10
my bell is not working, is here any help out there?
Username: Adale
Post Number: 18
BEV-
Key 0: 5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 (active)
Key 1: C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1
Post Number: 8
thats not bev its the old dn keys
Username: Adale
Post Number: 20
Really...then why it is working on my bev?
Post Number: 10
dont no but it is the exact keys for dish net, look at the posts above
Username: Adale
Post Number: 21
Sorry...ur right, put the wrong set in here!!!
Key 0: D3 0A 98 93 87 C8 EC FA 56 64 5E ED 6E C1 FF 0A(active)
Key 1: CO 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08
My apologies!!
Username: Mayday
Hi - hoping someone can help. For some reason, I can only plug in the 00 keys - can't get to the 01 keys, it doesn't give me the option to look at them. Does anyone know what this means? Thanks in advance.
Post Number: 11
just key 1 is key 2 and key 2 is key 1 thats the only difference between the keys you posted
Username: Adale
Post Number: 23
I have no idea what your talking about. All i was trying to do was help and give the BEV keys that I found that are currently working.
I made the mistake of posting the wrong keys the first time as I was reading the wrong set, but the keys that I posted in the second post were the ones that are working right now.
Username: Ptopta
Puerto Plata, Puerto Plata
Dominican Rep.
Nagra2 Keys
Dish Provider 0101: Last Updated (31 july '07 1:30 pm EST)
Key 0: BB 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A
Username: Indopak
Post Number: 7
what is the new dn keys, it stopped working again!!}
Username: Adale
Post Number: 26
I dont run DN but this is what i found. They are different then the ones above so maybe try them?
Key 0: 5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 active
I hope that helps
Username: Luckydraw
Quebec
Post Number: 17
does anyone have the new bev keys they are down again thank you
Username: Adale
Post Number: 27
Still working fine for me L M
Are these the ones your using?
Username: Luckydraw
Quebec
Post Number: 18
thank you i had one number wrong
Username: Mayday
Can someone please read my above post and help - I cannot get to the 01 keys for Dish Network. Thanks.
Username: Mph201
Post Number: 41
To MS, I think you accidentally went to Niagra 1 instead of Niagra 2.
Username: Fortec01
Post Number: 101
D!SH - Last Update: 07/31/07 02:44 pm
00: B8 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A
01: 5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97
B3V - Last Update: 07/31/07 12:51 pm
00: D3 0A 98 93 87 C8 EC FA 56 64 5E ED 6E C1 FF 0A
01: C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08
Username: Nels2k
Post Number: 54
86 is now Active and was last changed on Tue Jul 31 16:47:29 PDT 2007
86: B859DFCF32DD876C3BD137030760306A
96: 5B278CAFD01EA5A6D7743BA6B4211797
Username: Canndy
Post Number: 395
NEW KEYS
Username: Nels2k
Post Number: 55
only problem with me is even with autoroll off my key still seems to change usually the "B8" will change to "BB"
Username: Lklives
Post Number: 10601
Dishnet - Last Update: 07/31/07 02:44 pm
00: Bb 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A Active
Bev - Last Update: 07/31/07 12:51 pm
00: D3 0A 98 93 87 C8 EC FA 56 64 5E ED 6E C1 FF 0A Active
Username: Guanajuatos_best
HEY LK WHERE HAD YOU BEEN?
Username: Survayman12
Not working LK
Username: Canndy
Post Number: 400
Rob try this www.fta123.blogspot.com - reported working
Username: Lklives
Post Number: 10604
As stted above DN is morphing the 1st bytes in DN key 00 from B8 to Bb
00: Bb(B8) 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A Active
Username: 1tina_chick
Post Number: 75
LK Thanks - People please note first line B8 not Bb
Username: Gizzy29
Sussex, Nb
Hi All,
I am a little new to this, I know how to enter the keys I am just not sure where to enter them?
I know it is NAGRA but is it 090500 & 090600?
Username: Patty777
need to turn off autoroll for these dishnet work keys
Username: Assouma
Post Number: 10
hey there does anyone have the bin files for the pansat 2700a all the websites are down right now so plz if you can help...thx
Username: Deadmanwalking
i tried those keys on my viewsat platinum and theres still no picture or sound
i turned autoroll off
should i enter BB or B8 since i entered B8
Username: Blue313
Can someone help?? I enter the new keys, but still scrambled. Where do I enter the 01: keys??????
I have cool 5000 plat
still not working FOR ME
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through July 31, 2007 [ « Previous ] [ Next » ]
