Thread: Pansat 2700A |
New member Username: Richsei
Post Number: 2 Registered: Feb-06
| Posted on Wednesday, August 01, 2007 - 03:40 pm: |
I put the new 2700 fix in now I dont get any pic just a black screen and the box just shows the lines on the display scrolling across the display tryed running the loader again and got the same thing. I can put in a old one and I'll get a setup screen??? |
Post Number: 3 Registered: Feb-06
| Posted on Wednesday, August 01, 2007 - 04:40 pm: |
can anyone help with this problem?? |
Post Number: 4 Registered: Feb-06
| Posted on Thursday, August 02, 2007 - 02:44 pm: |
anyone know whats going on???? |
Silver Member Username: Donnie1973
Post Number: 629 Registered: May-06
| Posted on Thursday, August 02, 2007 - 02:56 pm: |
r u sure you loaded the right bin? Not a clone reciever is it? |
Post Number: 5 Registered: Feb-06
| Posted on Thursday, August 02, 2007 - 03:17 pm: |
Its not a clone and I used loader 27.02 and Bin 205 is this the right ones??? |
Post Number: 631 Registered: May-06
| Posted on Thursday, August 02, 2007 - 03:38 pm: |
Yeah, try to download the bin again. Maybe install a factory bin and try again |
New member Username: Jockster
Brampton,
Ontario
Post Number: 1 Registered: Aug-07
| Posted on Thursday, August 02, 2007 - 03:51 pm: |
i'm new here and i have a pansat 2700A can some1 tell me where i can get the bin file to update the receiver and some instructions on how to load it onthe pansat...plz plz |
Post Number: 6 Registered: Feb-06
| Posted on Thursday, August 02, 2007 - 04:05 pm: |
I have tryed that If I put the factory bin in it will work but when I put the new bin in it will not work I even tryed downloading a bin from another site and it did the same thing?? |
Post Number: 634 Registered: May-06
| Posted on Thursday, August 02, 2007 - 04:29 pm: |
Well, I dont have a clue then. Sorry. |
Post Number: 7 Registered: Feb-06
| Posted on Thursday, August 02, 2007 - 04:39 pm: |
Tk for trying to help maybe someone eles can give me some help??? |
Silver Member Username: Micklee11801
Post Number: 123 Registered: Feb-06
| Posted on Thursday, August 02, 2007 - 07:03 pm: |
did you update your receiver to b75 yet? If not then you have to get that file to update the receiver first then load the 205 bin. |
Post Number: 10 Registered: Feb-06
| Posted on Thursday, August 02, 2007 - 10:06 pm: |
I didnt do that where do I find b75 |
Gold Member Username: Nydas
Post Number: 3083 Registered: Jun-06
| Posted on Thursday, August 02, 2007 - 10:36 pm: |
Pansat 2700A should first have a B75 BIN using 27.02 loader. Then you should install the latest BIN - It is 205 now. Make sure you have a genuine Pansat 2700A. Clones will be ruined. http://www.future-fta.info http://www.dsstester*com http://www.dssrookie.com Tonight there is an ECM going on and you may find it difficult to go to many of the forums. If so, Wait till tomorrow. |
Silver Member Username: Shayeileen
Post Number: 146 Registered: Aug-06
| Posted on Saturday, August 04, 2007 - 08:55 pm: |
I am having the same problem, but when i installed the b75 boot file it just keeps saying b 7 5 across screen and it will not allow me to go back to factory bin?????????any suggestions? cant even see anything on tv screen |
Post Number: 3137 Registered: Jun-06
| Posted on Saturday, August 04, 2007 - 10:34 pm: |
To upgrade your Pansat 2700A/E to Boot 75 is itself a little tricky. Then you have to load BIN 205 on top of it. You should follow the instructions carefully as posted. Make sure you use loader 27.02 http://www.future-fta.info http://www.al7bar*tk http://www.dssrookie.com |
Post Number: 147 Registered: Aug-06
| Posted on Sunday, August 05, 2007 - 05:09 pm: |
is there a way to reset my reciever it just keeps saying b75 and i cannot even reload the factory bin |
Gold Member Username: Satscanner
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2574 Registered: Nov-06
| Posted on Sunday, August 05, 2007 - 05:13 pm: |
Reload the b75 boot file,let it finish and repower on before you interupt the flash/load. |
Gold Member Username: Juancho
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1271 Registered: Dec-06
| Posted on Sunday, August 05, 2007 - 06:29 pm: |
updating pansat2700a,to b-75,, go to menu y do factory default. ,use null modem cable as usual. now you will need ,Gtromloader27.02. b-75 boot file, pansat2700a-070310-b75-120.api and the last 205. Now open loader 27.07 y select b75 boot file, and download it as boot file. it is fast if you see b75 running across ,the update is OK, don't turn off the STB, now select bin file and select factory bin 120 , you will see a line running across forming a rectangle, don't worry about it, let it finish don't turn off you stb, now download 205, when finished the download the stb will turn off and then you will see b75 twice , and then ON , you did it?. turn off you stb and do your settings., a small spoon. |
Post Number: 148 Registered: Aug-06
| Posted on Sunday, August 05, 2007 - 10:36 pm: |
the flash fails???????? |
Niagara Falls,
Kashabowie.K...
MOY
Post Number: 1274 Registered: Dec-06
| Posted on Monday, August 06, 2007 - 10:40 am: |
If you dit it wrong,use this files to bring back you STB to boot 6.2 ,,2700A( b6[1][1].2 by rem35, and start again the process. I change back and forth my STB when the 200 bin dosn't works well. |
New member Username: Tgyoung1
Illinois
U.s.a.
Post Number: 6 Registered: Jul-06
| Posted on Monday, August 06, 2007 - 11:41 am: |
follow the above steps no problem.I have done it and the rst have. want tv try it again.. |
New member Username: Bubble
Post Number: 6 Registered: May-06
| Posted on Monday, August 06, 2007 - 10:01 pm: |
I have a Pansat 2700/A no clone and Iam running 282 Bin is there an autoroll fix or will I have to load the b75 I'am not sure how to do it that's why I have not done it. |
New member Username: Nick72
| Posted on Monday, August 06, 2007 - 10:20 pm: |
I have a Pansat 3500S no clone eny one have the new autoroll or where I can find it? |
New member Username: Malochico
Post Number: 2 Registered: Nov-06
| Posted on Monday, August 06, 2007 - 10:32 pm: |
nelule aici gasesti tot ce vrei( here u can find it) http://www.future-fta.info |
Post Number: 3151 Registered: Jun-06
| Posted on Monday, August 06, 2007 - 10:33 pm: |
Jack: Go to one of these sites and get the full instructions and files http://www.futre-fta.info http://www.dssrookie.com http://www.dsstester*com |
Post Number: 3152 Registered: Jun-06
| Posted on Monday, August 06, 2007 - 10:34 pm: |
it should be future-fta.info above. - spelling mistake |
Bronze Member Username: Teddyv
Post Number: 21 Registered: Nov-05
| Posted on Saturday, August 11, 2007 - 08:11 am: |
Please any one tell me which autoroll is working for pansat 2700a please any one reply. Thanks |
New member Username: Coachman
Naguabo,
P.r.
Usa
Post Number: 2 Registered: Aug-07
| Posted on Saturday, August 11, 2007 - 03:11 pm: |
teddy use the blacklist stb updater version 27.02 x-87bl.exe, the boot_2700a(b75)_(07)0310.bin and bin 205. now i use and working good. |
Bronze Member Username: K98
Post Number: 74 Registered: Jan-07
| Posted on Saturday, August 11, 2007 - 04:30 pm: |
how do u down load this equipment into your 2700a reciver do u plug it into your computerand follow the instructions posted by juan ramirazone say nalin |
Post Number: 35 Registered: Nov-05
| Posted on Saturday, August 11, 2007 - 04:42 pm: |
hd, Where can download this files and please write full name of file. Thanks |
Naguabo,
P.r.
Usa
Post Number: 3 Registered: Aug-07
| Posted on Sunday, August 12, 2007 - 10:41 am: |
teddy, i use a rs232 to download the file from my computer. i have one paper instruction. the name of files: 2700-x-87bl_070731_b75_205_api gtrom loader v27.02(pansat 2700a-b75).exe boot_2700a(b-75)_(07)0310 |
Post Number: 3188 Registered: Jun-06
| Posted on Sunday, August 12, 2007 - 11:12 am: |
Teddy. Surely you can read all the posts in this thread and know where to get the files and instructions and how to upgrade your receiver. You are only hurting yourself and probably not getting the full information, the way you are asking questions. |
Gold Member Username: Crazy_greek
Post Number: 1079 Registered: Jul-06
| Posted on Sunday, August 12, 2007 - 12:05 pm: |
Hey, Nalin I just realize that Teddy registered here almost two (2) years ago. Nov.05 he was asking how to use a compass. Well, I guess he has a reason. BTW, glad to see you back on the job. |
Post Number: 42 Registered: Nov-05
| Posted on Sunday, August 12, 2007 - 12:42 pm: |
Hey Kavin, I am quit with this line. and I moved TX to CT, So am back and I am fasing problame that's why I need help Thanks Teddy |
Bronze Member Username: Amt
Post Number: 32 Registered: Jun-06
| Posted on Thursday, August 16, 2007 - 08:38 pm: |
i have my 2700a upgraded to b75 loaded latest bin 205 it worked for while and few channles only now its showing no signal on screen and when i try to blind scan it shows 0 transponder found there is no signal at all can any one hlep help me please |
Post Number: 35 Registered: Jun-06
| Posted on Thursday, August 16, 2007 - 09:24 pm: |
i am getting no signal and then scrambled or bad channel massege again and again and signle is goign up and down please help |
New member Username: Maharun
West Palm Beach,
Fl
Usa
| Posted on Friday, August 17, 2007 - 03:44 pm: |
I have a Pansat 2700A. The tv screen is black and shows me "Wait for picture 0%", and it goes up to 150%and up but no picture comes on.Pls help. |
Post Number: 3322 Registered: Jun-06
| Posted on Friday, August 17, 2007 - 06:31 pm: |
You need to upgrade to the latest BIN 208. Till you get it, you can try turning autoroll off on your receiver and then manually update the keys. |
Post Number: 84 Registered: Jan-07
| Posted on Friday, August 17, 2007 - 07:38 pm: |
mahbub go into menu if u know how to navigate to nagra vision 2press enter manully enter latest oo o1 keys re;keys 4 d.n. are sometimes shown as 86 = oo 96=o1 updated keys can be found at dss-keys.com good luck if u need detailed help e mail me at cottoncoots@yahoo.com |
New member Username: Loa
| Posted on Friday, August 17, 2007 - 11:10 pm: |
Hi Nalin, I was trying to load 208 bin from future-fta. Future-fta look has changed. It's taking me to Megaupload. Could you kindly give me some guidance about what to do ? |
Post Number: 3326 Registered: Jun-06
| Posted on Friday, August 17, 2007 - 11:16 pm: |
Files are dished out from an independent site. You can try http://www.al7bar*tk |
Brampton,
Ontario
Post Number: 8 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 03:07 pm: |
ok i used X-87BL Loader v27.02 [X-87BL] and loaded the Boot_2700A(b75)_(07)0310 and then used the 208 bin file. the download went fine and all but i'm still not getting any channel. i went to menu and did the scan the channels name show up and all but when it's done scanning i get no picture. it says "Wait for picture 0%", and it goes up and keeps on going up...any idea plz help... |
Platinum Member Username: Lklives
Post Number: 11124 Registered: Jan-06
| Posted on Saturday, August 18, 2007 - 04:28 pm: |
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released.. Many of these specialize in particular FTA receivers as noted next to their links..USE those for your particular receiver manufacturer.. If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community now... Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information . So again I highly recommend using ANY of these sites BELOW!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby! Data Viewing Sequences www.dvsfta.com (All receivers) Future FTA - Blacklist's Site: http://www.future-fta.info/forum/index.php (Pansat) FTA Tech - Free To Air Community: http://www.ftatech.net/forums/ (All receivers) Free To Air: http://www.f2atv.com/ (C00LSAT and All receivers) DSS Newbies: http://www.dss-newbies.net/forums/ (All receivers) DSS Rookie: http://www.dssrookie.com/forums/ (All receivers) Total FTA http://www.totalfta.com (VIEWSAT and All receivers) FTA Bins www.ftabins.net (VORTEX and All receivers) FTA Support www.ftaprosupport.com (all receivers) Cut and Paste these into your browser: REMOVE the * in links below: These are the largest sites,and therefore Ecoustics has blocked their names and active links.. http://forums.dsstester.c*om/ (All receivers) http://www.dsscommunity.c*om/forums/ (All Receivers) http://www.al7bar.t*k/ (All receivers) http://www.dsscentral.n*et/ (All Receivers) This site was free but now has a small fee for files, but is the best site for Clone receivers in general.. http://www.pantecf2a.com/support (Pantecs,all clones and all receivers) File Share Site - No Registration Required: -------------------------------------------------- Good for gettting Original factory firmware: http://www.ftacentral.c*om/ (All receivers) Satellite Finders (Look Angle Calculators) ------------------------------------------------- http://www.arachnoid.com/satfinder (Dish 500 support) http://www.satellitenut.com/calculators/SatelliteHeading.html http://www.hollsco.com/Products/SatCalc/ http://www3.telus.net/rampage/skew.htm (Dish 500 support) http://www.remotesat.com/lookangle.htm Satellite Charts -------------------------------------------------- For information on all satellites and channels they offer http://www.lyngsat.c*om/america.html http://www.satcodx.com/ Best site for DISHNET info, channels, transponders and changes etc.. http://ekb.dbstalk.com/dishlist.htm Direct links to current Dishnet and Bev keys: www.tvkeyz.com/ www.dss-keys.com/ www.fta123.blogspot.com or use Keymaster 4.0 Utility on your computer desktop...remove the * in link, and register FREE.. http://www.dsscommunity.co*m/forums/viewtopic.php?t=3865 BTW...ALL these sites have the NEW working AUTOROLL bins released |
Brampton,
Ontario
Post Number: 10 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 07:53 pm: |
can some1 plz tell me wat autoroll is plz |
Bronze Member Username: Jockster
Brampton,
Ontario
Post Number: 11 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 08:13 pm: |
i think i messed my reciever...i did the factory setting and then put the 208 bin file in now i'm not getting anything...plz help me.... |
Brampton,
Ontario
Post Number: 12 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 08:20 pm: |
i can't even enter the key manually every time i start the receiver the language menu will show and i can't access the parental control or the option below it. i'm getting nothing at all wat should i do? should i boot it with teh boot file 310? and load teh new bin 208? or wat? |
Silver Member Username: Albino_midget
Post Number: 598 Registered: Jul-06
| Posted on Saturday, August 18, 2007 - 08:32 pm: |
select language, do your antenna settings again and scan- |
Brampton,
Ontario
Post Number: 13 Registered: Aug-07
| Posted on Saturday, August 18, 2007 - 08:44 pm: |
i did that but after the scan it says 0 found |
Post Number: 599 Registered: Jul-06
| Posted on Saturday, August 18, 2007 - 09:03 pm: |
your settings must be wrong when in antenna setting make sure you have good signal level and quality |
Silver Member Username: Bladam
Post Number: 123 Registered: Apr-06
| Posted on Saturday, August 18, 2007 - 11:38 pm: |
I There where do i get the b-75 boot file, I try just about every where and I cant seem to find it |
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2744 Registered: Nov-06
| Posted on Sunday, August 19, 2007 - 03:25 am: |
http://www.future-fta.info/Forums/showthread.php?t=47421 everything is here ,complete with instructions. |
New member Username: Dev09
| Posted on Wednesday, August 22, 2007 - 07:41 pm: |
How do I download the loader for pansat 2700-A? Can someone help me please? |
Silver Member Username: Ustaad_hc
Post Number: 228 Registered: Oct-06
| Posted on Wednesday, August 22, 2007 - 07:55 pm: |
HERE IS 2700A LOADER |
Post Number: 229 Registered: Oct-06
| Posted on Wednesday, August 22, 2007 - 08:00 pm: |
just go to freedom fta.com and download it . itry to upload but can't. |
Post Number: 230 Registered: Oct-06
| Posted on Wednesday, August 22, 2007 - 08:04 pm: |
{381984,Upload} |
| Posted on Wednesday, August 22, 2007 - 09:25 pm: |
thank's |
New member Username: Amoltuli
| Posted on Thursday, August 23, 2007 - 11:26 pm: |
I have PANSAT 2700A box and I'm not getting any signal....Blind scan shows no transponders found...I only have the international dish pointing 61.5 Echo 3/Ku....Signal level is at 48% but doesn't change even if I move the dish angle. Do I need the new bin file? If yes, where can I find the procedure to load it. Please help!!! Thanks in advance!!! |
Post Number: 4 Registered: Aug-07
| Posted on Friday, August 24, 2007 - 12:34 am: |
Help please!!!! PANSAT 2700A box showing no signal...Blind scan can't find any transponders....no programs found. Is this a bin file issue or ECM related? |
Post Number: 11316 Registered: Jan-06
| Posted on Friday, August 24, 2007 - 10:15 am: |
realign the dish check cables and connections recheck antenna settings reboot receiver ensure B75 boot upgrade was sucessful post more info read more about your receiver and FTA in general etc... |
Post Number: 5 Registered: Aug-07
| Posted on Friday, August 24, 2007 - 11:48 am: |
Thanks LK. The dish seems to be in the same alignment. However, the boot file shows X-87BL API:2.88_EUbX and Boot version is 6.3 from Nov 24, 2006. I'll try to upgrade to B75 boot, perhaps that is the issue here??? |
New member Username: Elkassem11
Montreal ,
Quebec
Post Number: 1 Registered: Jun-06
| Posted on Friday, August 24, 2007 - 12:25 pm: |
hi guys plz i need the latest clone bin for 2700 clone pansat yhnx for your help |
Post Number: 11318 Registered: Jan-06
| Posted on Friday, August 24, 2007 - 02:00 pm: |
hensen...LOOK...I have a specific thread here with that file ..Pansat 2700 clone fix.... amol ...that B75 boot upgrade missing is DEFINTELY your problem for now..to start with... |
New member Username: Arsenal499
| Posted on Friday, August 24, 2007 - 07:10 pm: |
hey..im tryin to download the new bin file on my pansat i have previously downloaded the B75 using a different computer but the same cable it worked then butr now when im loading the new bin it shows me a box readin "Bin File not reading" my friend has used the same bin file on a different computer for my pansat and it worked so i am wondering what the problem is HELPP |
Silver Member Username: Fastbeatz
Post Number: 200 Registered: Sep-06
what is the order in which u need to put these in the pansat??? factory bin 120...then...B75 boot...then bin 208???? is that right????? |
Post Number: 201 Registered: Sep-06
| Posted on Friday, August 24, 2007 - 07:12 pm: |
i needed to install factory bin because the stb displayed only lines...and it didnt work...so im askin for the order in which to install these |
Post Number: 11327 Registered: Jan-06
| Posted on Friday, August 24, 2007 - 08:12 pm: |
heres' evrthing U need to do the B75 boot upgrade...its very simple... http://www.dsscommunity.co*m/forums/viewtopic.php?t=3132 Pansat 2700A/E Boot 7.5 Upgrade 03-11-07 -------------------------------------------------------------------------------- ""These are the instructions I used and it worked. There are a couple of steps beyond the original BL version that I include to make it a smooth transition. All files are in the zip file attached. 1. Do a factory reset. 2. Load file 115 (latest factory file available for boxes BEFORE upgrade) 3. Start up the loader v27.02 (THIS IS A NEW LOADER and is required for all B75 level files. 4. Select the file BOOT 2700A.......0310.bin and select BOOT FILE ONLY 5. Power the receiver ON at the rear switch and start the download. The front display will show B75 moving across if successful when finished. 6. Open the API file X87_BL_070311_B75_200_API.bin and select API file on the loader. (NOTE: Any api file after 10 Mar 07 should work if/when they are later issued) When complete, the box should say B75 and then switch to "ON" if you followed the instructions completely. If you did not return your box to factory state first, it will switch to a channel number instead of "ON" but may also fail. Shortcuts are user decisions. DO NOT power off until steps are completed. Failure to follow instructions can result in potential damage."""" 4q2 Ok those are pretty much the official instructions, now I'll tell you my experience. Steps 1, 2 and 3 were done, of course with no problems. Step 4 is where I had problems and I never saw the B-75 flash across my receivers screen, just the green dash going back and forth, maybe that was it but my box wouldn't do what was mentioned. Flashed my box numerous times with the boot file but it would not show the B-75 message at the end of flashing. Finally I loaded the 115 factory bin again and instead of turning off my receiver from the back, I left it on. I then selected the 2700A.......0310.bin {BOOT ONLY} and flashed it while my receiver was still on, low and behold it took and b-75 flashed on my receivers display. I was then able to load the X87_BL_070311_B75_200_API.bin, again with my receiver still on and it loaded perfectly with b-75 on my receivers display until the box powered off by itself. Receiver then rebooted with b-75 showing on the display and it going to on. I'm not recommending the steps I did but it worked for me. Follow the recommended steps before my crazy steps, if you get stuck you may want to try what worked for me. I will warn you not to interrupt the flashing procedure until you see the loader tell you that the download was successful.. You can do damage to your receiver that may require a jtag. The kit below also has the new B-75 loader found at PansatUSA, included. -------------------------------------------------------------------------------- B-75 Boot upgrade Full upgrade kit.zip |
Silver Member Username: Pathfinder191
Post Number: 196 Registered: Mar-06
| Posted on Saturday, August 25, 2007 - 02:48 pm: |
I think many people have same problem as I am facing with my Pansat 2700. When I turn it of using the remote and try to turn it on back, it would not respond until I reset it from the back switch. Is there a solution to this problem? |
Post Number: 11364 Registered: Jan-06
| Posted on Saturday, August 25, 2007 - 02:59 pm: |
upload factory bin, then reload the 208 bin.. |
Post Number: 7 Registered: Aug-07
| Posted on Saturday, August 25, 2007 - 05:22 pm: |
LK, I loaded the B75 boot file followed by 208 bin. The download was successful, the receiver switched back to "ON" as expected. However, the blind scan still doesn't find any transponders. I checked the alignment, cable etc and everything is ok, as it was before. Any ideas what's the problem here and what else I should try? The Echo 3/Ku Antenna setup parameters are following: LNB type: Standard LNB Freq: 11250 22KHz: OFF SiSEqC: OFF Legacy SW: SW21 Dish1 Skew: 45 TP: (1)12223 V20.000 Positioner Setting: Disable Satellite Scan: ALL Level is at 45-46% Quality is 0% |
Post Number: 11374 Registered: Jan-06
| Posted on Saturday, August 25, 2007 - 06:13 pm: |
Your dish is NOT aligned properly...everything is NOT OK... "Level is at 45-46%"...should be at least 70% and those settings will vary based on what type LNB's and switches and switch ports U are using...there is NO such thing as "standard" settings that works for every setup...each receiver cable, and hardware setup is differnt... |
Post Number: 9 Registered: Aug-07
| Posted on Saturday, August 25, 2007 - 07:55 pm: |
LK, Seems like the signal strength indicator on the receiver is not working right. It is constantly giving a level of 46% and quality 0, even if I remove the coax cable from the LNB. I've tried a blind scan repeatedly while moving the dish but no luck. Is there another way? |
New member Username: Torbram69
Post Number: 10 Registered: Aug-06
| Posted on Sunday, August 26, 2007 - 06:28 pm: |
LK..please help..I have Pansat 2700A and can not get any PPV chanels. I have Echo 3ku working at 61.5 aand am getting all the indian chanels. Which dish (i.e echo 3ku) do I select to get PPV chanels? Thanks |
Bronze Member Username: Torbram69
Post Number: 11 Registered: Aug-06
| Posted on Monday, August 27, 2007 - 08:00 am: |
i figured it out...Thanks anyways. |
Post Number: 197 Registered: Mar-06
| Posted on Tuesday, August 28, 2007 - 09:01 am: |
Thanks LK, I loaded factory bin and reloaded 208 but no luck. Any other suggestions? Thanks in advance, Sam |
Post Number: 11505 Registered: Jan-06
| Posted on Tuesday, August 28, 2007 - 10:15 am: |
LK Platinum Member Username: Lklives Post Number: 11327 Registered: Jan-06 Posted on Friday, August 24, 2007 - 08:12 pm: -------------------------------------------------------------------------------- heres' evrthing U need to do the B75 boot upgrade...its very simple... http://www.dsscommunity.co*m/forums/viewtopic.php?t=3132 Pansat 2700A/E Boot 7.5 Upgrade 03-11-07 -------------------------------------------------------------------------------- ""These are the instructions I used and it worked. There are a couple of steps beyond the original BL version that I include to make it a smooth transition. All files are in the zip file attached. 1. Do a factory reset. 2. Load file 115 (latest factory file available for boxes BEFORE upgrade) 3. Start up the loader v27.02 (THIS IS A NEW LOADER and is required for all B75 level files. 4. Select the file BOOT 2700A.......0310.bin and select BOOT FILE ONLY 5. Power the receiver ON at the rear switch and start the download. The front display will show B75 moving across if successful when finished. 6. Open the API file X87_BL_070311_B75_200_API.bin and select API file on the loader. (NOTE: Any api file after 10 Mar 07 should work if/when they are later issued) When complete, the box should say B75 and then switch to "ON" if you followed the instructions completely. If you did not return your box to factory state first, it will switch to a channel number instead of "ON" but may also fail. Shortcuts are user decisions. DO NOT power off until steps are completed. Failure to follow instructions can result in potential damage."""" 4q2 Ok those are pretty much the official instructions, now I'll tell you my experience. Steps 1, 2 and 3 were done, of course with no problems. Step 4 is where I had problems and I never saw the B-75 flash across my receivers screen, just the green dash going back and forth, maybe that was it but my box wouldn't do what was mentioned. Flashed my box numerous times with the boot file but it would not show the B-75 message at the end of flashing. Finally I loaded the 115 factory bin again and instead of turning off my receiver from the back, I left it on. I then selected the 2700A.......0310.bin {BOOT ONLY} and flashed it while my receiver was still on, low and behold it took and b-75 flashed on my receivers display. I was then able to load the X87_BL_070311_B75_200_API.bin, again with my receiver still on and it loaded perfectly with b-75 on my receivers display until the box powered off by itself. Receiver then rebooted with b-75 showing on the display and it going to on. I'm not recommending the steps I did but it worked for me. Follow the recommended steps before my crazy steps, if you get stuck you may want to try what worked for me. I will warn you not to interrupt the flashing procedure until you see the loader tell you that the download was successful.. You can do damage to your receiver that may require a jtag. The kit below also has the new B-75 loader found at PansatUSA, included. -------------------------------------------------------------------------------- B-75 Boot upgrade Full upgrade kit.zip After doing this sucessfully, then just upload the latest Autoroll bin, which is now bin 208...and turn ON your autorolls..and be patient while keys roll... |
Silver Member Username: Asharfi
Post Number: 690 Registered: Aug-06
| Posted on Tuesday, August 28, 2007 - 10:46 am: |
Hey, DssCommunity, they don't support clone receivers, am I right? |
Post Number: 11508 Registered: Jan-06
| Posted on Tuesday, August 28, 2007 - 11:10 am: |
DssCcommunity has a "clones" section...and the Pansat 2500, 2700 and 3500 clone files as well as the Coo*lsat 4000 clones files are posted there.. Vortex sold 2500, 2700 and 3500 clones...and he still supports them....and don dinero also supports the 2700 clone...so for the 2700 , there a 2 different clone files available..most people don't know about Vortex.. If u are interested, look in the "Pansat Files" area...and also check the "Clones" area...U will see 2700 clone files in BOTH sections... |
Post Number: 3492 Registered: Jun-06
| Posted on Tuesday, August 28, 2007 - 11:27 am: |
You can get clone files at: http://www.dssrookie.com http://www.f2atv.com http://www.dsstester*com and at many other sites. |
Bronze Member Username: Aksma
Post Number: 42 Registered: May-06
| Posted on Sunday, September 02, 2007 - 04:04 pm: |
The problem for NO SIGNAL for PANSAT receivers are power. If you want to try, just put the same cable which is going to PANSAT into any DISHNETWORK receiver, and check the signal. Surprise!! you will see there is a signal but if you put it back to PANSAT that sker does not work. This is because, DISHNETWORK receivers gives power to the dish, so signals are good, where as PANSAT receivers does not have that feature. So, you need to buy POWERED switches, then everything works fine. NOTE: all this you have to do after successfully installation of bins. ALL THE BEST!! |
Silver Member Username: Delgado258376
Monterrey
Post Number: 224 Registered: Aug-06
| Posted on Sunday, September 02, 2007 - 04:15 pm: |
Achsah: ¿what kind of POWERED?, write an example please. |
Post Number: 43 Registered: May-06
| Posted on Monday, September 03, 2007 - 01:41 pm: |
The switch which comes between the satellite and receiver. like dp34 etc, needs power in it. So, there are some dish network switches which comes with a power plug, use that and put the plug in your wall, you are all set. Google for "Dishnetwork Powered switches", you should find someone selling it. Try in ebay. |
Silver Member Username: Mkvl1490
Post Number: 113 Registered: Feb-06
| Posted on Monday, September 03, 2007 - 02:20 pm: |
9. now Rewrite your Channel list back, BUT, BIG BUT, you must now select the 2700 settings in Channel master. what does that mean, how i do that? |
