Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Pansat 3500 Fix
Author Thread: Pansat 3500 Fix
Username: F_t_a_is_back
Post Number: 222
http://www.megaupload.com/?d=VS10PTZX
Username: Lklives
Post Number: 10650
Pansat3500sd 7/31/07 -- v321 --
The zip has a loader in it, but I loaded it via the sd card and all seems fine. I didn't wait for it to autoroll, I set em manually and it took right off and been fine..
If ya want to manually load the keys..
press 8282 on the remote
then scroll down to nagravision 2, press ok, this opens up another dialog box
enter the --00-- keys // use the following remote buttons for A B C and D;
A=pause button B=sound? button, C=epg button, D=last button
then go back up to the 00 box and side arrow to 01
then enter the --01-- keys
then press the ok button
the ok at the bottom will blink
then exit ALLl the way out to --tv--
http://www.ftaprosupport.com/forums/showthread.php?p=6392#post6392
enjoy...
Username: Lgpansat
What is autoroll vs. manual.
Do I need to set autoroll if I load via the sd card
Username: Rtap
FL
Post Number: 274
autoroll is a feature that rolls the keys automaticaly and manual means you enter the keys thru your remote control. some bin files come with the autoroll feature and some dont.
Username: Lgpansat
Thanks, from LK's comment it does appear that the Pansat 3500SD fix comes with autoroll built in.
Username: Lklives
Post Number: 10657
All the new released files have working autorolls..
Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Pansat 3500 Fix [ « Previous ] [ Next » ]
