Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Viewsat Ultra Keys Help
Author Thread: Viewsat Ultra Keys Help
Username: Avis4
Hi guy, im new here. Can any one tell me how to enter keys on a Viewsat ultra? Im not quite sure how to do it yet.
Thanks in advanced!
Username: Hanz
Post Number: 331
How To Enter Keys Manually In Your VIEWSAT.
1. Menu
2.Installation
3.Enter Pin 0000
4.Code
5.Nagra
6.Left until you see what ever Satellite you want.
Put 00 keys on line 08 & 09 don't change the 08 or 09 number
Put 01 keys on line 88 & 89 don't change the 88 or 89 number
EXIT once then OK to save, the light color is the one you pick to save then EXIT out
Username: Avis4
"Put 00 keys on line 08 & 09 don't change the 08 or 09 number
Put 01 keys on line 88 & 89 don't change the 88 or 89 number"
thats the only part i dont under stand
Username: Avis4
oh nvm.. i figured it out! thanks for the help, and sorry for the double post
Username: Hanz
Post Number: 333
Cool :-)
Username: Akhan
hi i also tried that change the digits but it says no audio or no video where as the signal and quality are good. i have also turned of the auto roll option off. its a viewsat ultra.
Username: Kingeverton
Kingston jamaica
Post Number: 7
hey guys dose this applies for the veiwsat extreme can i used the same method as the one for the ultra you gave
Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Viewsat Ultra Keys Help [ « Previous ] [ Next » ]
