Thread: ViewSat Extreme Question |
Silver Member Username: Destine0429
Quebec
Post Number: 195 Registered: Dec-06
| Posted on Tuesday, July 31, 2007 - 08:24 pm: |
}Ok so my friend recently bought a ViewSat Extreme and all was going well. But now that the keys have changed, he has no idea how and where to input the new keys. So I was wondering if someone could tell me a step by step on how to input the keys into the Viewsat Extreme. We're both used to using Pansat 2500a clones. Please help
Platinum Member Username: Lklives
Post Number: 10631 Registered: Jan-06
| Posted on Tuesday, July 31, 2007 - 08:28 pm: |
JULIE U KNOW BETTER...READ FIRST HERE, I POSTED THIS 3X ALREADY TONITE IN PAST HOUR,...EVEN HAVE "VIEWSAT KEYS HELP" THREAD HERE POSTED!, How To Enter Keys Manually In Your VIEWSAT. 1. Menu 2.Installation 3.Enter Pin 0000 4.Code 5.Nagra 6.Left until you see what ever Satellite you want. Put 00 keys on line 08 & 09 don't change the 08 or 09 number Put 01 keys on line 88 & 89 don't change the 88 or 89 number EXIT once then OK to save, the light color is the one you pick to save then EXIT out. |
Silver Member Username: Donnie1973
Post Number: 624 Registered: May-06
| Posted on Tuesday, July 31, 2007 - 08:30 pm: |
From LK 1. Menu 2.Installation 3.Enter Pin 0000 4.Code 5.Nagra 6.Left until you see what ever Satellite you want. Put 00 keys on line 08 & 09 don't change the 08 or 09 number Put 01 keys on line 88 & 89 don't change the 88 or 89 number EXIT once then OK to save, the light color is the one you pick to save then EXIT out |
Quebec
Post Number: 196 Registered: Dec-06
| Posted on Tuesday, July 31, 2007 - 08:32 pm: |
Oh sorry LK, was just in a hurry. I'm sorry I try to please, but sometimes a girls gotta be a girl. Once again, you aim to please me :D Thanks so much hon. Next time, I will try not to be so hurried. |
Post Number: 10635 Registered: Jan-06
| Posted on Tuesday, July 31, 2007 - 08:38 pm: |
NP...enjoy! |
Quebec
Post Number: 197 Registered: Dec-06
| Posted on Tuesday, July 31, 2007 - 08:42 pm: |
Thanks hon...I bet he will :D I was able to do the keys on his box when I was in front of it, but since he is at his place and I'm here, he's basically screwed without your help :D I knew you wouldn't disappoint |
New member Username: Erl
Post Number: 1 Registered: Jul-07
| Posted on Tuesday, July 31, 2007 - 10:17 pm: |
Hey, I selected "Nagra", but nothing happened. How to "Left until you see what ever Satellite you want"? Sorry for the dummy questions... |
