Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Help with Keys please
Author Thread: Help with Keys please
Username: Dean85
I found the new dish network keys, and they work. However, after a few minutes, that channel gets scrambled once again, because somehow the keys change back to the old ones. How can I fix this problem. I'm using a cool...5000
Username: Donnie1973
Post Number: 623
DISABLE UR AUTOROLL. If u dont, it will keep changing them.
Username: Lklives
Post Number: 10629
SHUT OFF ALL AUTOROLL OPTIONS, THEN ENTER THE CORRECT KEYS
Username: Justin2424
i entered my new keys and the dish still doesnt work.. was working find befor key change?? whats the matter? im using Bell expressVu
Username: Silver1123
Mexico, DF
Mexico
There where two changes Today done by DN. One on the 00 line and anotherone on the 01 line.
First you have to turn OFF all autoroll options on your reciever. This is done by entering MENU and finding the auroroll options.
Here is a link where you can download one of three programs that generate keys:
http://ftasignalmex.com/claves.html
Key Ripper will go off by late August
Mexico, DF
Mexico
New Keys as of 07/31 at 5:30pm EST
B8 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A
5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97
Username: Estefania
k i have pansat 2500a i have changed the keys turned the outroll off ... im using dishnet ... but in every channel except a few it says "scrambled or bad channel" ....i have the the 293t bin ... the signal is good... any ideas
Username: Cw120568
Great fix thank you everyone ! Viewsat ultra turn off auto roll and enter keys works great!
Username: Lgvolvo
New Jersey
I'm trying to do this but cant get it to work. Is this the right way to do it:
00)B8 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A
01)5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97
08)B8 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A
09)B8 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A
88)5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97
89)5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97
Is it suppost to have six lines of codes?
Username: Sk_77095
I have cools5000. I tried to change the keys under dishnetwork 0001 but it did not work and still getting scrambled channels. Please help. sk
Mexico, DF
Mexico
Post Number: 7
I have a cools 5000 and I entered the keys listed above and all channels are viewable.
First, turn OFF all autoroll options, there are 3. You access them through the Menu.
Then enter the codes:
by pressing 8282, you get into the key edit menu...
Choose Nagravision1
10: B8 59 DF CF 32 DD 87 6C
11: 3B D1 37 03 07 60 30 6A
20: 5B 27 8C AF D0 1E A5 A6
21: D7 74 3B A6 B4 21 17 97
If still dont get picture and sound, repeat the same for Nagravision2
Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Help with Keys please [ « Previous ] [ Next » ]
