Thread: Archive through July 19, 2007 |
Platinum Member Username: Lklives
Post Number: 10366 Registered: Jan-06
| Posted on Friday, July 06, 2007 - 10:44 am: |
please do NOT double post...I answered U in the other thread U posted same in.. |
New member Username: Amil
Post Number: 2 Registered: Jun-07
| Posted on Saturday, July 07, 2007 - 09:22 pm: |
can someone tell me where I get the latest bin and loader for fortec star I thank you |
New member Username: Kbrob
Post Number: 7 Registered: Dec-06
| Posted on Saturday, July 07, 2007 - 10:24 pm: |
hi I just put the new DN code in and can't get UFC 73 to come on... can anyone help... what am I doing wrong? please please I can't miss this fight. thanks |
Silver Member Username: Ricky_nauta
Post Number: 172 Registered: Aug-06
| Posted on Sunday, July 08, 2007 - 02:34 pm: |
Does anyone have the new keys for Dish please?? |
Post Number: 173 Registered: Aug-06
| Posted on Sunday, July 08, 2007 - 02:37 pm: |
Sorry. My mistake. I fixed it. Thanks. |
New member Username: Iceman09
Miami,
Florida
Post Number: 1 Registered: Jul-07
| Posted on Sunday, July 08, 2007 - 03:10 pm: |
New Keys? Please |
Silver Member Username: Jpz
MTL,
QC
CAnada
Post Number: 212 Registered: Jun-06
| Posted on Sunday, July 08, 2007 - 04:57 pm: |
Hi To All. Any one have the new keys for DN please ?? |
Miami,
Florida
Post Number: 2 Registered: Jul-07
| Posted on Sunday, July 08, 2007 - 07:31 pm: |
rick how did u fix it |
Gold Member Username: Nydas
Post Number: 2979 Registered: Jun-06
| Posted on Tuesday, July 10, 2007 - 12:41 pm: |
Che G.: You asked: "Where can I can find the latest Bin, for my new pansat 2500 clone?" http://www.dssrookie.com http://www.totalfta.com http://www.dsstester*com Look under Pantec or under Fortec Ultra for 293T BIN. Use Straight RS232 DB9 F/F cable and BL updater 1.4. Wherever you get your BIN, make sure you download the instructions and follow them explicitly. Best of luck. |
Post Number: 2980 Registered: Jun-06
| Posted on Tuesday, July 10, 2007 - 12:43 pm: |
amil khosro : If you have Ultra the answer is above. If you have the classic, look carefully for the right BIN. |
Post Number: 2981 Registered: Jun-06
| Posted on Tuesday, July 10, 2007 - 12:47 pm: |
veryevilnip: Make sure you have the 293T BIN. for genuine Pansay 293 is OK, but I always recommend the 293T BIN for Pansat 2500 and clones. Make sure you have the correct date and time and time zone. Turn the autoroll on and autoTP off, then do a set default keys and switch off at the back and turn it on. Let the keys roll in. Then make sure you turn autoroll off and autoTP off for normal viewing. |
Post Number: 2982 Registered: Jun-06
| Posted on Tuesday, July 10, 2007 - 12:48 pm: |
asasasassssas hghjhjh : If yours is a Lifetime Ultra, the answer is above. |
Post Number: 2983 Registered: Jun-06
| Posted on Tuesday, July 10, 2007 - 12:53 pm: |
DN – Provider ID 0101: (Last Update: 2007/06/26 ) Key 00 (86): C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1 Key 01 (96): FA 48 09 8E D7 E2 FE 3F E8 A3 5B 76 BF 4F 27 A1 BEV – Provider Id 0901: (Last Update: 2007/06/06) Key 00 (86): E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 Key 01 (96): F1 69 FA E9 5F 6E 33 94 5E 28 F3 C4 99 5A 00 F5 |
Bronze Member Username: Curler
Post Number: 35 Registered: Mar-07
| Posted on Tuesday, July 10, 2007 - 06:23 pm: |
Bell ExpressVu (Last Update: 2007/07/10 17:17 PM PDT) 86: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 96: C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08 |
New member Username: Coolsat70
Post Number: 6 Registered: Apr-06
| Posted on Tuesday, July 10, 2007 - 06:30 pm: |
Nalin Nyda, Thank you for your help. I have another question for you, how can I enter the keys on a fortec star platinum? Thank you in advance. |
Post Number: 2987 Registered: Jun-06
| Posted on Tuesday, July 10, 2007 - 06:52 pm: |
I do not have specific knowledge of key entry on Fortec star platinum. Usually you go into Parental control and enter the second Pin as 0000 or something specific for the receiver. Keys are entered in Nagravision 2, and under provider ID 0101 for DN and Provider ID 0901 for BEV |
Post Number: 10468 Registered: Jan-06
| Posted on Tuesday, July 10, 2007 - 07:26 pm: |
DISH - Last Update: 07/10/07 04:08 pm 00: C9 82 3A AE 0B 0F 24 59 BB CD 40 B5 0D EB 6C 43 01: CB FB 84 C0 97 81 54 5E 41 7F 6A 72 B0 2D 0C BC Active BEV - Last Update: 07/10/07 03:44 pm 00: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 01: C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08 Active |
Post Number: 3 Registered: Jun-07
| Posted on Tuesday, July 10, 2007 - 07:37 pm: |
Thank you Nalin. I appreciate your effort |
Post Number: 7 Registered: Apr-06
| Posted on Tuesday, July 10, 2007 - 07:42 pm: |
LK do you know how to enter keys on a fortec star platinum ? |
New member Username: V12adel
| Posted on Tuesday, July 10, 2007 - 11:41 pm: |
hi all i have colsat 5000 i need t oput the new keys i dont know how to get ther can i get help please |
| Posted on Tuesday, July 10, 2007 - 11:43 pm: |
its was working very well i fregot how to put it in |
Silver Member Username: Therepo
Ftaview.com
Post Number: 131 Registered: May-07
| Posted on Tuesday, July 10, 2007 - 11:48 pm: |
adel, latest bin is 144 for CS5K. You don't need to input keys, just turn your autoroll options ON. |
Post Number: 3 Registered: Jul-07
| Posted on Tuesday, July 10, 2007 - 11:51 pm: |
ok thanks but if i need to add new keys on the same receiver what do i ned to press what numbers to takem there for colsat 5000 its something like 850 or 852 i dont know |
Ftaview.com
Post Number: 132 Registered: May-07
| Posted on Tuesday, July 10, 2007 - 11:52 pm: |
But if you like to do it, haha, press "8282" while on a channel. |
Post Number: 4 Registered: Jul-07
| Posted on Tuesday, July 10, 2007 - 11:56 pm: |
thanks a million |
Post Number: 10474 Registered: Jan-06
| Posted on Wednesday, July 11, 2007 - 09:59 am: |
Dn & Bev Keys : 10 July 07...correction to my post above...regarding DN keys.. Dn Keys : Keys 00 : C5 42 C5 Ae 9b 04 1d Aa Aa Dc Fc 40 99 82 3b D1 ( Active ) Keys 01: Fa 48 09 8e D7 E2 Fe 3f E8 A3 5b 76 Bf 4f 27 A1 ************************************************** ************** Bev Keys: Keys 00: E3 56 7b 2f 6c C1 51 Ff D9 42 4d 8a D3 3e 44 C5 Keys 01: C0 89 A1 34 84 22 32 Cd 36 11 33 7f Ab 4e 02 08 ( Active ) |
Post Number: 3000 Registered: Jun-06
| Posted on Wednesday, July 11, 2007 - 10:26 am: |
DN keys have not changed for several weeks now. They remain as I posted above, before LK suddenly decided to step in with wrong info. The BEV keys - Key 01 changed and has been posted by DF above. |
New member Username: Irfanc30
| Posted on Thursday, July 12, 2007 - 02:06 am: |
Hi This is my first time to post a massage on this site.I have Viewsat 2000 Platinum receiver. I was getting all the chanells for last six months. I was changing the keys when ever it needed. Two days ago keys were changed. I changed the keys but no picure. Now i am getting the signal but after a while I am losing it. If the turn the back switch of the receiver off and on the signal comes back again. Can anyone help me please. |
New member Username: Kardary7
Nashville,
T.N
Post Number: 6 Registered: Apr-07
| Posted on Thursday, July 12, 2007 - 04:09 am: |
new keys please |
Post Number: 3010 Registered: Jun-06
| Posted on Thursday, July 12, 2007 - 09:44 am: |
Irfan: Try the Viewsat new BIN file dated yesterday. http://www.dssrookie.com/forums/b-font-color-cd2626-vs-xtreme-files-font-b/dbpsw -070703x-upgrade-141745.html ======================================= VS2000 XTREME release note ======================================= ------------------------------------ DBPSW-070703X ------------------------------------ * Versions - Release Date : 2007.07.03 - Main software : DBPSW-070703X - Bootloader : 0.0C * Change ( Main software upgrade ) - PIN code mistake message (You can see the message if you input different code when you change PIN code.) - When you enter code menu you can't reach the key address but the key value directly. Attached Files DBPSW-070703X.zip (862.3 KB) |
Post Number: 3011 Registered: Jun-06
| Posted on Thursday, July 12, 2007 - 09:47 am: |
kardary: There are no new keys, since the last post 2-3 posts above yours. |
New member Username: Scooby6969
| Posted on Thursday, July 12, 2007 - 01:09 pm: |
can I use my pansat to get directv instead of dish net |
Bronze Member Username: Cacalad
Post Number: 11 Registered: Apr-07
| Posted on Thursday, July 12, 2007 - 01:10 pm: |
new keys please for dish |
| Posted on Thursday, July 12, 2007 - 01:13 pm: |
Dn Keys : Keys 00 : C5 42 C5 Ae 9b 04 1d Aa Aa Dc Fc 40 99 82 3b D1 ( Active ) Keys 01: Fa 48 09 8e D7 E2 Fe 3f E8 A3 5b 76 Bf 4f 27 A1 |
Bronze Member Username: Sobe1
South beach,
Fl
Post Number: 35 Registered: Jun-07
to get the latest keys go to these sites as recomended by LK. www.tvkeyz.com/ www.dss-keys.com/ www.filez.us/km3/keys.shtml |
| Posted on Thursday, July 12, 2007 - 01:20 pm: |
| Posted on Thursday, July 12, 2007 - 01:22 pm: |
Hi Nalin Thank you for sending the link. I have tried to load the new file. I am still not getting any signal also the picture became black and white. Help me please. Thank you |
Bronze Member Username: Luqe
Post Number: 46 Registered: Sep-06
| Posted on Thursday, July 12, 2007 - 02:14 pm: |
The second pin option is not showing in my parental control menu. Does anyone know how i can get in to change the code? |
Post Number: 12 Registered: Apr-07
| Posted on Thursday, July 12, 2007 - 02:16 pm: |
somebody help me i put the new keys and it works but 5 minutes later is not working and i check the keys and there right how can i fix that somebody please |
Post Number: 13 Registered: Apr-07
| Posted on Thursday, July 12, 2007 - 02:19 pm: |
the keys dont work now someone please |
Post Number: 14 Registered: Apr-07
| Posted on Thursday, July 12, 2007 - 02:44 pm: |
SOMEBODY HELP ME PLEASE THE KEYS DONT WORK |
New member Username: Sandyh
Cambridge,
Ontario
Post Number: 5 Registered: Feb-07
dish 01 5b278cafd01ea5a6d7743ba6b4211797 |
Bronze Member Username: Silverfox62
Kentucky
Post Number: 18 Registered: Aug-06
| Posted on Thursday, July 12, 2007 - 02:46 pm: |
anyone have the new DN keys |
Post Number: 15 Registered: Apr-07
| Posted on Thursday, July 12, 2007 - 02:47 pm: |
THANK YOU SANDY |
Kentucky
Post Number: 19 Registered: Aug-06
| Posted on Thursday, July 12, 2007 - 02:54 pm: |
thanks sandy key are working |
New member Username: Muzz
Toronto,
Ontario
Post Number: 2 Registered: Feb-07
| Posted on Thursday, July 12, 2007 - 03:07 pm: |
New key 01-5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 |
New member Username: Jpatel007
Post Number: 3 Registered: Sep-06
| Posted on Thursday, July 12, 2007 - 05:27 pm: |
Did these Keys changed after these? Can some one please peovide latest keys after this one? 01-5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 |
Post Number: 3021 Registered: Jun-06
| Posted on Thursday, July 12, 2007 - 06:12 pm: |
DN – Provider ID 0101: (Last Update: 2007/07/12 ) Key 00 (86): C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1 Key 01 (96): (changed today) 5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 BEV – Provider Id 0901: (Last Update: 2007/07/10) Key 00 (86): E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 Key 01 (96): (changed 2 days ago) C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08 |
Post Number: 3022 Registered: Jun-06
| Posted on Thursday, July 12, 2007 - 06:13 pm: |
DN keys changed today as above and are working fine. |
New member Username: Sadafmpd
Post Number: 6 Registered: Jun-06
| Posted on Thursday, July 12, 2007 - 07:52 pm: |
I am missing some channel on Echo1.2/KU. Any help/suggestion Nalin |
New member Username: Whiteknight88
| Posted on Thursday, July 12, 2007 - 08:57 pm: |
thanks LK for the list. Also Does anyone know why/how come I don't have this channel called "VIVA" on DN? It is german i believe. It has great mainstream euro music on it I miss VIVA! lol |
Post Number: 3025 Registered: Jun-06
| Posted on Thursday, July 12, 2007 - 10:06 pm: |
SADAF M PASHA : 1. Make sure you have latest BIN. 2. Turn switch off at back and turn it on after 30-40 seconds. 3. Do a Blind scan with autotp off. 4. Do a TP scan of missing Channels . |
| Posted on Thursday, July 12, 2007 - 10:11 pm: |
what satellite is BEV |
Post Number: 3028 Registered: Jun-06
| Posted on Thursday, July 12, 2007 - 10:20 pm: |
BEV is at 82W and 91w. Go to http://www.lyngsat*com for more info. Replace * above with a . |
Bronze Member Username: Walidsm
Post Number: 20 Registered: Aug-05
| Posted on Friday, July 13, 2007 - 01:04 am: |
Keys please |
Ftaview.com
Post Number: 146 Registered: May-07
| Posted on Friday, July 13, 2007 - 07:18 am: |
Nick, maybe one of these? VIVA TV Philippines is on ch. 713 on either TP 1 @ 118° A-F3 or TP 13 @ 121° E*9. Mono musak Viva Mariachi is on ch. 941 TP 12 @ 119° E*7. |
New member Username: Laure
Fredericton,
NB
Post Number: 9 Registered: Mar-07
| Posted on Friday, July 13, 2007 - 11:25 am: |
still looking for new keys....am I overlooking them????please and thx |
Bronze Member Username: Laure
Fredericton,
NB
Post Number: 11 Registered: Mar-07
| Posted on Friday, July 13, 2007 - 11:55 am: |
sorry for being such a pest, I finally got the keys....only the odd number had changed, I was only looking at the 1st couple of #'s and they hadn't changed...........sorry |
New member Username: 0129
Post Number: 4 Registered: Jun-07
| Posted on Friday, July 13, 2007 - 03:42 pm: |
colsat 6000 need keys |
Gold Member Username: Evadelparaiso
Puerto Rico
Post Number: 2424 Registered: May-06
| Posted on Friday, July 13, 2007 - 04:58 pm: |
Jose: The keys are the same for all receiver. Check the last keys posted above. |
New member Username: Vaderpapp
| Posted on Friday, July 13, 2007 - 07:26 pm: |
key plz  |
| Posted on Friday, July 13, 2007 - 09:24 pm: |
thanks therepo! I'll try those. |
Bronze Member Username: Rated08
Post Number: 22 Registered: Nov-06
| Posted on Friday, July 13, 2007 - 10:19 pm: |
Havent had any problems in months till today, my friends DN is working fine mine isn't whats the problem. We have the same bins. |
Gold Member Username: Satscanner
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2349 Registered: Nov-06
| Posted on Saturday, July 14, 2007 - 01:06 am: |
Key's pls.          |
Post Number: 10528 Registered: Jan-06
| Posted on Saturday, July 14, 2007 - 09:03 am: |
Here's working GLOBCAST KEYS enjoy while it last: Globcast Keys: C101 86: 41 A1 44 AD 2D 0F 42 CA 30 80 F5 06 7B 4A 48 7B 96: EC BF 90 84 C0 C7 6C BC C5 4D DC 13 7A E7 6B ED |
Bronze Member Username: Billybeerboy
Carthage,
Il
United states
Post Number: 69 Registered: Mar-06
| Posted on Saturday, July 14, 2007 - 09:48 am: |
What is a satelite?Does Rufuss R. Jones still wrestle? |
Bronze Member Username: Hoosier_daddy
Post Number: 95 Registered: Dec-06
| Posted on Saturday, July 14, 2007 - 10:51 am: |
How about SD Jones..... |
Post Number: 10534 Registered: Jan-06
| Posted on Saturday, July 14, 2007 - 01:06 pm: |
lugman...U do NOT have the "parental control" option to get 2nd pin/password because U MUST scan (or upload a channel list) the satellites first to enable that option to appear...think about it, why would receiver need to have parental controls, if U have no channels input/scanned into the receiver to control.. |
New member Username: Jmortimer3
Ancaster,
Ontario
| Posted on Saturday, July 14, 2007 - 01:46 pm: |
my keys have changed 4 times since yesterday. Anyone have the new keys for BEV? Thanks |
Bronze Member Username: Roxy06
Post Number: 25 Registered: Mar-07
| Posted on Saturday, July 14, 2007 - 02:55 pm: |
i've looked everywhere and can't find any new keys for BEV...does anyone have any new keys besides the one posted above? |
Silver Member Username: Banej
Post Number: 227 Registered: Jun-06
| Posted on Saturday, July 14, 2007 - 03:04 pm: |
try these roxanne. these are the latest for bev Bell ExpressVu (Last Update: 2007/07/10 17:17 PM PDT) 86: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 96: C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08 |
Post Number: 26 Registered: Mar-07
| Posted on Saturday, July 14, 2007 - 03:11 pm: |
those aren't working for me, I'm using a colsat 6000 and up until today it's been working fine, I just can't seem to get it working, is everyone else down too. |
Ancaster,
Ontario
| Posted on Saturday, July 14, 2007 - 03:16 pm: |
I have those keys loaded and nothing....looked everywhere as well. I miss my TV |
Post Number: 10539 Registered: Jan-06
| Posted on Saturday, July 14, 2007 - 03:49 pm: |
if U are using those keys above, which U have saved in the receiver, and U still do not have TV, then U have other issues...there are tons of key finders links here as well..here's just 1.. www.dss-keys.com |
Post Number: 8 Registered: Dec-06
| Posted on Saturday, July 14, 2007 - 05:08 pm: |
any news on the keys? |
Post Number: 10546 Registered: Jan-06
| Posted on Saturday, July 14, 2007 - 05:37 pm: |
DISH - Last Update: 07/14/07 03:16 pm 00: C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1 01: 5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 B3V - Last Update: 07/14/07 03:16 pm 00: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 01: C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08 |
Silver Member Username: Canndy
Post Number: 387 Registered: Nov-06
| Posted on Sunday, July 15, 2007 - 04:43 pm: |
The Key source: whenever 1 is down, the other is up. www.fta123.blogspot.com www.ftakeys.blogspot.com www.dishkeys.blogspot.com www.bevkeys.blogspot.com www.dsskeys.blogspot.com www.gcastkeys.blogspot.com |
New member Username: Shervin62
Post Number: 8 Registered: Mar-07
| Posted on Sunday, July 15, 2007 - 04:53 pm: |
are u sure these are the correct keys? 00: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 01: C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08 i just entered them in my sat...they dont work |
Post Number: 10561 Registered: Jan-06
| Posted on Sunday, July 15, 2007 - 05:19 pm: |
keys are correct...operator error is usually 99% of most problems..If U can't put gas in your car...or correct keys in the receiver, then U shouldn't be driving.. |
Ancaster,
Ontario
| Posted on Sunday, July 15, 2007 - 05:37 pm: |
shervin just try unplugging the box and plug it in again. Sometimes that seems to work. |
Post Number: 9 Registered: Dec-06
| Posted on Sunday, July 15, 2007 - 08:10 pm: |
bev doesnt work, ive put those exact codes and it wount work. ive been putting keys manually for a year now. its not working |
Bronze Member Username: Srpskkisiin
Post Number: 23 Registered: Mar-07
| Posted on Monday, July 16, 2007 - 05:08 pm: |
Visit for newest keys, help or whatever FTA, fastest way to get keys, they are updated as soon as they change.http://www.jordinclub.com/forum You can also download KeyRipper at this forum, free without registering, so you don't have search the internet for keys, just open this program and click on GET KEYS: |
New member Username: Ahmad03
Post Number: 3 Registered: Mar-07
| Posted on Tuesday, July 17, 2007 - 09:49 am: |
hi... i hav just got Coolsat5000 platinum reciever..i need it's loader and latest bin file..plz help me |
Post Number: 4 Registered: Mar-07
| Posted on Tuesday, July 17, 2007 - 03:45 pm: |
i also need to know that which cable i use to transfer bin file for Coolsat5000 platinum, either null modem or straight data cable..thnkx |
New member Username: Abbasusa77
Post Number: 7 Registered: Apr-07
| Posted on Tuesday, July 17, 2007 - 07:46 pm: |
is any one have new keys for panset |
Post Number: 8 Registered: Apr-07
| Posted on Tuesday, July 17, 2007 - 08:45 pm: |
can any one post the new keys plz |
New member Username: Iwishiwaskevinfederline
Post Number: 9 Registered: Oct-06
| Posted on Wednesday, July 18, 2007 - 12:45 am: |
00: C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1 01: 5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 make sure autoroll is off |
Post Number: 3034 Registered: Jun-06
| Posted on Wednesday, July 18, 2007 - 03:01 pm: |
C00LSAT 5000 v144 06-20-2007 1. New TP added at T5 -. 12152 (Diar TV, Iran TV Network, Jaam E Jam, AFN and Omid E Iran) -. 11999 (Aljazeera) 2. New Satellite added (ANIK F3(118.8 W) Warning: Use at your own risk C00LSAT5000_NORW_144_20070620.ZIP (845.2 KB) Use Loader C00LSAT_Pro_Loader_v.2.4.zip (167.4 KB) Cable – Straight DB9 http://www.f2atv.com http://www.dssrookie.com http://www.future-fta.info |
Bronze Member Username: Atul_shah
Post Number: 22 Registered: Oct-06
| Posted on Wednesday, July 18, 2007 - 10:22 pm: |
New Keys Please |
Post Number: 23 Registered: Oct-06
| Posted on Wednesday, July 18, 2007 - 10:26 pm: |
New Keys for DISH ??? Key Master still has D!SH - Last Update: 07/14/07 03:16 pm 00: C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1 01: 5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 (Active) B3V - Last Update: 07/14/07 03:16 pm 00: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 01: C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08 (Active) |
Post Number: 24 Registered: Mar-07
| Posted on Thursday, July 19, 2007 - 03:32 pm: |
Globecast C101 (Last Update: 2007/07/12 12:01 PM PST) 86: 41A144AD2D0F42CA3080F5067B4A487B 96: ECBF9084C0C76CBCC54DDC137AE76BED More info at http://www.jordinclub.com/forum |
New member Username: Pu_da_munda
Post Number: 8 Registered: Feb-07
| Posted on Thursday, July 19, 2007 - 06:16 pm: |
New keys for DN |
Post Number: 3035 Registered: Jun-06
| Posted on Thursday, July 19, 2007 - 06:28 pm: |
DN – Provider ID 0101 (Last Update: 2007/07/12) Key00 (86): C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1 Key01 (96): 5B 27 8C AF D0 1E A5 A6 D7 74 3B A6 B4 21 17 97 Globecast Provider ID C101 (Last Update: 2007/07/12) Key00 (86): 41 A1 44 AD 2D 0F 42 CA 30 80 F5 06 7B 4A 48 7B Key01 (96): EC BF 90 84 C0 C7 6C BC C5 4D DC 13 7A E7 6B ED BEV Provider ID 0901 (Last Update: 2007/07/10) Key00 (86): E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 Key01 (96): C0 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08 BEV Provider ID 0905 (Last Update: 2007/03/15) Key00 (06): B7 2F 03 35 70 4A CD B0 6D 43 33 59 92 E2 1D F3 Key01 (46): D5 51 BA FE 58 50 BE 61 A4 BD 09 F3 54 4F C5 FC BEV Provider ID 0906 (Last Update: 2007/03/17) Key00 (06): 8D 1A 1C F4 2C B9 7F 85 38 65 D6 7A 5D 59 5D 88 Key01 (46): 11 FE 27 1D 89 9E D3 B4 DB 8E CB C8 10 D3 E7 F7 |
Post Number: 9 Registered: Feb-07
| Posted on Thursday, July 19, 2007 - 06:35 pm: |
with these keys its DN is not working |
Post Number: 3037 Registered: Jun-06
| Posted on Thursday, July 19, 2007 - 06:50 pm: |
Sidhu: Keys are as posted. Switch off at the back, wait for 30 seconds and switch on. If this does not work, post details of you your receiver and BIN. |
Post Number: 10 Registered: Feb-07
| Posted on Thursday, July 19, 2007 - 07:32 pm: |
Nalin: I switched off and after switching it on after 1 min. it doesnt work. BIN File is 289T and its Panset reciever. Can you help me in fixing the problem? |
New member Username: Khawaja105
Post Number: 8 Registered: Oct-06
| Posted on Thursday, July 19, 2007 - 08:31 pm: |
I have a pansat 2500 clone and my question is the New Keys are not working. I have power cycle my receiver. By the way, what is the provider ID, that comes on top column in Niagravision 2, where we enter the new keys. Thanks. |
Bronze Member Username: Pu_da_munda
Post Number: 11 Registered: Feb-07
| Posted on Thursday, July 19, 2007 - 08:39 pm: |
Now by its own DN is working fine |
New member Username: Desakia
| Posted on Thursday, July 19, 2007 - 09:07 pm: |
i have a DV3 (pretty old) receiver, all of my asian channels are showing up red in the guide, well i can`t see any channels. Now i have tried the keys NALIN posted, but these are the same keys since -7/12/07 Can anyone help me fix this, i use Jeepers and ATMEGA128 to program my card. ANYONE PLEASE HELP |
Post Number: 3038 Registered: Jun-06
| Posted on Thursday, July 19, 2007 - 10:29 pm: |
Sidhu: Glad you are up and running. Latest BIN for Pansat 2500 clones is 293T. 289T will work fine but does not autoroll. In general, it is best to keep autoroll and autotp off. When new keys appear, turn auto roll on, switch off at back and then swithc on and the new keys will roll in about 90% of the time. |
