Thread: PANSAT 3500 SD- Signal Level & Quality Issue |
New member Username: David_2
Post Number: 10 Registered: Jan-07
| Posted on Monday, July 30, 2007 - 08:33 am: |
PANSAT 3500 SD- Signal Level & Quality Issue DISH 500 Satellites: Echo 3, Echo 7, Echo 8 LNBs: Dish Pro DiSeq: 4 x 1 Bin: X-05BL_070201_312_api.bin Configuration: 3 cables from LNBs to Diseq switch 1 RG 6 cable to receiver Here I go: Everything was working fine till last night. I was helping friend for his Sonicview 8000HD . I Disconnected my receiver , including taking out RG 6 connected to my 3500SD Then connected SV 8000HD, loaded latest bin, scan two satellites. I was successful in doing that. Then, I disconnected SV 8000HD. Now, I connected my 3500SD. I go to Antenna Set up, my signal level down to 32 and Quality level down to Zero. I tried 1) shut switch from back off and on. 2) Factory default, 3) Reload Bin 312 again. No luck. Any one has suggestions? I will appreciate your help |
Silver Member Username: Albino_midget
Post Number: 550 Registered: Jul-06
| Posted on Monday, July 30, 2007 - 12:43 pm: |
are you connected to IF INPUT,when connected to antenna in you get those symptoms |
Bronze Member Username: David_2
Post Number: 11 Registered: Jan-07
| Posted on Monday, July 30, 2007 - 03:10 pm: |
NO |
Silver Member Username: Rtap
FL
Post Number: 270 Registered: Jan-07
| Posted on Monday, July 30, 2007 - 10:34 pm: |
samdo try loading the latest bin 320 and scan all the birds. |
Gold Member Username: Hawaiian_time
Kanaka freak...
Post Number: 1198 Registered: Apr-06
| Posted on Monday, July 30, 2007 - 11:38 pm: |
Samdo, the 3500 has had problems with leaking capacitors. Try going to Future fta and looking up info there. You need to register first. I know that we have had threads here, but it's been a long time since anyone brought up that problem. A friend of mine changed them and his unit works great now. This could be your problem. |
Bronze Member Username: Jack786
Post Number: 23 Registered: Oct-06
| Posted on Tuesday, July 31, 2007 - 07:13 am: |
I also had same problem on my pansat 2700A, i changed c-13 and c-14 capacitors and it's working fine now. Each capacitor is 80 cents. |
Post Number: 12 Registered: Jan-07
| Posted on Tuesday, July 31, 2007 - 08:16 am: |
Thanks everyone for helping me out. Everything is back to normal, getting all channels on Echo 3, Echo 7, Echo 8 I like to share my experience how I got channels back First disconnected 1) 3 cables from LNBs to my DiSeq switch, 2) RG 6 cable from DiSeq switch Reconnected all back as follows: A) cable from 119 LNB to Port 1 of DiSeq switch, B) A) cable from 110 LNB to Port 2 of DiSeq switch, C) cable from 61.5 LNB to Port 3 of DiSeq switch. Next went to receiver menu, antenna setup, selected Echo 7, Echo 8, & Echo 3. Under each selected LNB type as “Dish Pro”, DiSeq # as 1, 2, & 3 respectively. I got Signal level for each “85” and Quality “99” Blind-Scanned all 3 satellites, but to my frustrations no picture.I checked Key #s, they were fine. I decided I am going to Factory Default from main menu. Set my Key code to “on” in Autoroll option. Rechecked Signal level, quality level and DiSeq #s for all satellites under Antenna setup. Blind- Scanned all satellites again Last step was go to Menu, “SD Memory”, deleted my channel data backup file. In other words, I am going to create my favorites all over again and save as new backup file. One note: I am still using X-05BL_070201_312_api.bin Finally I got all channels and picture back. I want to thank everyone who chipped in to help me out. |
Post Number: 26 Registered: Oct-06
| Posted on Tuesday, July 31, 2007 - 08:53 am: |
SAMDO, question for you. I have dish pro with 2 LNB, one is titled 119 and 110. Actually there's another plug which is titled "IN". How did you connect it to 61.5? |
