Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Vs pro
Author Thread: Vs pro
Username: Dishall
Post Number: 32
i just programmed vs pro and scanned and missing many channel on 61.5. do i need t add any channel list, any help
Username: Hardrockstriker
Post Number: 945
Is your dish for 61.5 aimed properly? Check you quality level.
Username: Nydas
Post Number: 3070
Off and on a Sat scan or Blind scan does not catch all the channels. I have got round it by doing specific TP scans for the missing channels.
Username: Dishall
Post Number: 33
i have pansat 2500 at same angle at same dish it gats almost all channels while vs pro gets only 37
Username: Nydas
Post Number: 3072
That is precisely what I am trying to convey to you. When you scanned the Pansat you caught all the channels. when you scanned the VS pro you did not. They are two different receivers.
Just try a TP Scan or two and see what happens
All the best.
Whenever connecting or disconnecting a receiver, switch it OFF.
Username: Dishall
Post Number: 35
how tp search in vs pro i do not see such option ..tp scan
Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Vs pro [ « Previous ] [ Next » ]
