Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > CW600p Remote
Author Thread: CW600p Remote
Username: Satscanner
Beaversbush, Sportsmans P...
Great White ...
Post Number: 2485
My new reciever came with a "universal remote"for up to 3 extra devices,tv ,vcr,aux,and stb.I 've looked through all the user info on the sites and in the users manuall but no codes or info on how to program this remote for the tv.Anybody have these codes and info to program this remote?
Username: Albino_midget
Post Number: 549
http://www.dssrookie.com/forums/753348-post2.html
Great White ...
Post Number: 2486
Thanks Albino,I'll check it out.
Great White ...
Post Number: 2488
Thanks, the search code feature worked great!
Username: Bandizzy
Post Number: 155
THE USER MANUAL OF THE REMOTE CONTROL CW-600S Premium
The remote control is used for the components of America. It can control four different kinds of component TV, VCR, AUX, STB.
Except STB part is programmed with our STB others can be used for controlling different installations. Now the following is the program mode.
Setting the Code:
Follow the step 1 and 2 below for each component you plan to use with the Commander.
Step1: Entering the Code Number
M
1 See the supplied “Component Code numbers”, and find the three digit code number for the desired component. If more than one code number is listed, use the number that’s listed first to complete the steps below.
For example, if you‘re setting up a Philips’ VCR, you would use the code number 035. If your component isn’t listed, see “Searching for the Correct Code”.
2 While pressing the SET button, press the POWER button.
3 Press the button of the component that you want to set up.
4 Enter the component’s code number. For example, if you’re entering the code for a Philips VCR, you would press 035
5 Press and release the EXIT button to store the code number in the Commander’s memory.
6 Go to “Step 2: Checking if the Code Number Works” to finish setting up.
1 Power on the component you want to set up.
2 Aim the Remote Commander at the component and press a button
to check if that button works. For example, press the POWER
button to see if it works on your component.
3 Check that the other buttons of the Commander is operating the corresponding functions of the component. You can write down the code number on the label inside the battery compartment lid.
If the Commander doesn’t seem to be working.
First, try repeating these setup procedures using the other codes listed for your component ( see the supplied “Component Code Numbers”).
If after trying all the codes listed for your component you still cannot get the commander to work properly, try the search method described in “Searching for the Correct Code.”
If you‘ve tried all the code numbers listed for your component and you still cannot get the Commander to work (or if your component is not listed in the “Component Code Numbers” tables), try these steps.
1 Power on the component you want to set up. Insert a tape or disc if necessary.
3 Press the button of the component on the Commander that you want to set up.
4 Press the release the PAGE+ button. Then press and release the POWER button.
5 Repeat step 4 until the correct code number is found. Each time you press the PAGE+ button and then the POWER button, a new
code number will be transmitted. Keep trying until your component operates by receiving the transmitted signal from the commander
(e.g., the power turns off, the PAGE+ function works, playback starts, etc.) Be patient as you do this, it may take about 100 tries until the
correct code number is located.
6 When the correct code is found, press the EXIT button to store the code number in the Commander’s memory.
7 Check that the Commander is operating the other functions of your component by
Controlling the Volume of Video Components
Connected to an Audio System
The Commander is factory preset based on the assumption that you hear the sound of your video components from your TV’s speakers,
and that you hear the sound of your audio components from the loudspeakers connected to your receiver (or amplifier).
Factory Setting:
Button Controls the volume of TV, VCR, CBL/ SAT*, DVD* TV RCVR Receiver (or amplifier) CD*, AUX* Receiver (or amplifier) on the RCVR button.
If you assign an audio component on the CBL/SAT, CD, AUX or DVD button, you can control the volume of the receiver (or amplifier) on the RCVR button. If you assign video components on these buttons, you can control the volume of the TV. Thus you can control the volume of your TV or receiver (or amplifier) while operating a video or audio component without first having to press the TV or RCVR button. For example, to control the volume for your VCR channels, you don’t need to press the TV button first. However, if your video components are connected to an audio system, you probably hear your TV’s or VCR’s sound from the loudspeakers connected to your receiver (or amplifier), not from your TV speakers. In this case, you need to change the factory setting so that you can control the volume of your video components without first having to switch to the receiver (or amplifier). To change the factory setting for the volume control, follow the procedures below.
Note
This feature is effective only when a receiver or amplifier is set up on the RCVR button.
You cannot control the volume of a receiver (or amplifier) set up on CBL/SAT, CD, AUX or DVD button while operating a component of another button.
TV/VCR Combo
Brand         TV Code         VCR Code
Daewoo                 036                  044
Emerson                021                  023
                              021                  022
                              020                  058
General Electric    027                  024
                              027                  025
Gold Star LG        003                  035
                              013                  035
                              012                  035
                              030                  035
                              046                  035
                              050                  035
                              051                  035
                              049                  035
Magnavox             011                  012
                              011                  013
                              018                  012
                              018                  013
                              047                  012
                              047                  013
Panasonic              018                  011
                              018                  012
 Quasar                  018                  012
                              018                  009
                              018                  010
                              048                  012
                              048                  009
                              018                  010
RCA/Proscan        018                  011
Samsung               023                  024
                              023                  025
                              023                  029
                              027                  024
                              027                  025
                              027                  029
Symphonic            023                  041
TVs
Brand                    Code(s)
Admiral                 002, 014, 009
Akai                       003
AOC                      012
Audinac                 034
Bell & Howell       014, 009, 038
Broksonic               003, 012
Craig                      022, 023, 020, 021
Croslex                   011
Crown                    023
Curtis Mathis         003, 019, 023
Daewoo                  035, 036, 003, 041, 073
Daytron                  013 Emerson                022, 013, 020, 021, 023,
003, 015, 042
Fisher                    025
General Electric    002, 018, 003, 007, 045
Gold Star/LG        003, 013, 012, 030, 046,
050, 051, 049
Hitachi                  031, 013, 003, 032
JC Penny               003, 002, 030, 007
JVC                       028, 029
KTV                      033, 013, 003, 023, 034
LXI (Sears)           002, 003, 011, 025, 019, 012, 052
Magnavox              011, 012, 013, 003, 043, 047
Marantz                 024
Mitsubishi/MGA   024, 003, 012, 066
NEC                      003, 012
Panasonic              018, 016, 017, 007, 049, 067
Philco                    011, 013, 003, 068, 035, 031
Philips                   011, 056, 043
Pioneer                  037, 018, 019
Portland                 003, 008
Quasar                   018, 007, 048
Radio Shack          002, 012, 024, 023
RCA/Proscan        002, 003, 004, 005, 006, 007, 008,
044,045,046, 053
Samsung                026, 012, 013, 003, 055
Sanyo                    025, 023, 054, 069
Scott                      023, 012
Sharp                     014, 013, 015, 070
Signature 2000      014, 009
Sony                      001
Sylvania                011, 012, 003
Symphonic             023, 039, 040, 074
Toshiba                 060, 019, 014, 052, 059
Videch                   031, 003, 012
Wards                    013, 003, 015, 012
Zenith                    009, 010
VCRs
Brand                    Code(s)
Admiral                 030
Aiwa                     041, 050, 035
Akai                      052, 053, 054
Audio Dynamic     017, 040
Bell & Howell      033, 046
Broksonic              020, 022, 017
Canon                    012, 011
Citizen                   035
Craig                     018, 035
Curtis Mathis         007, 041, 012
Daewoo                 044, 015, 012, 064
DBX                      017, 039, 040
Dimensia               007
Emerson                044, 022, 023, 019, 020, 021, 041, 058
Fisher                    033, 037, 038, 036
Funai                     041
General Electric    032, 007, 038, 036
Gold Star, LG        035
Go Video               051, 042, 043
Hitachi                  011, 007, 008
HQ                        015
Instant Replay        012, 011
JC Penny               012, 008, 007, 033, 017, 039, 040
JVC                       017, 047, 048, 049, 039, 040
Kenwood               017, 039, 035, 040
LXI (Sears)           041, 035, 008, 036, , 037, 033, 038,
052
Magnavox              013, 011, 012, 010, 063
Marantz                 017, 039, 040
Marta                     035
Memorex               012, 038
Minolta                  008, 007
Mitsubishi, MGA  026, 027, 028, 029, 056, 057, 065,
059
Multitech               028, 041, 024
NEC                      017, 039, 040
Olympic                012, 011
Optimus                 027
Orion                     055
Panasonic              009, 010, 011, 012, 060
Pentax                    008, 007
Philco                    011, 012, 044, 020
Philips                   035, 013, 011, 012, 063
Pioneer                  011
Quasar                   011, 012, 009, 010, 006
RCA, Proscan       007, 008, 011, 012, 013, 014, 015,
016
Realistic                012, 033, 031, 038, 027, 041
Samsung                025, 016, 024
Sansui                    017
Sanyo                    033, 038, 046, 044, 035
Scott                      015, 016, 024, 038, 026, 027, 028,
029
Sharp                     030, 031
Shintom                 018
Signature 2000      041, 030
Singer                    018
Sony                      001 (VTR1: Betamax)
Sony                      002 (VTR2: 8mm)
Sony                      003 (VTR3: VHS)
Sony                      004 (VTR4: DV)
Sony                      005 (VTR5: DV)
Sony                      006 (VTR6: DV)
Sylvania                013, 011, 012, 041
Symphonic             041
Tashiro                  035
Tatung                   017, 039, 040
Teac                      017, 039, 041, 040
Technics                012, 011
Toshiba                 015, 014, 052
Wards                    030, 031, 038, 034, 035
Yamaha                 033, 017, 039, 040
Zenith                    034
DVDs
Brand                    Code(s)
Aiwa                     015
Denon                    006, 017
Harman/Karden     018
Hitachi                  008
JVC                       007
KLH                      010
Onkyo                    016
Panasonic              002
Philips                   012
Pioneer                  004, 019, 021
RCA                      005
Samsung                014
Sharp                     011
Shinco                   022
Sony                      001, 023
Sylvania                020
Thomson                013
Toshiba                 003
Yamaha                 006
Zenith                    009
Cable Boxes
Brand                    Code(s)
Hamlin, Regal       022, 023, 024, 025, 026
Jerrold, G.I            043, 001, 002, 003, 004, 005, 006, 007, 008,
018, 022, 044
Oak                        027, 028, 029
Panasonic              019, 020, 021
Pioneer                  014, 015
Scientific Atlanta  009, 010, 011
Tocom                   043, 016, 017
Zenith                    012, 013
 Satellite
For the U.S.:
Brand                    Make                          Code(s)
DirecTV                Hitachi                        005
                              Hughes                        004
                              Panasonic                    003
                              RCA/Proscan              002, 007
                              Sony                            001
                              Toshiba                       006
 For Canada:
Brand                    Make                          Code(s)
Star Choice           General Instrument      009
Express Vu            Echo Star                     010
Receiver/Amp.
Brand                    Code(s)
Aiwa                      039, 021
Denon                    026, 027, 035, 036
Fisher                    010
Harman, Kardon    034
JVC                       046, 019, 018, 098
Kenwood               024, 015, 014
Magnavox              020
Marantz                 028
NAD                      032, 104
Nakamichi             086, 105
Onkyo                    033, 038, 042
Panasonic              007, 099
Philips                   028
Pioneer                  031, 085, 090
RCA                      092, 093, 020, 106
Rotel                     067
Sansui                    037, 089, 087, 086
Sanyo                    010
Sharp                     027, 015, 100
Sherwood              030
Sony                      001, 002, 102
Teac                      088, 057, 087
Technics                025, 044, 007
Toshiba                 101
Yamaha                 029, 045, 013, 103
CD
Brand                    Code(s)
Aiwa                     036, 020
Denon                    025, 008
Emerson                091
Fisher                    039, 009
GoldStar, LG         101
Harman, Kardon    030
Hitachi                  040
JVC                       032, 017, 018
Kenwood               033, 013, 023
Magnavox              015, 025
Marantz                 071
NAD                      028
Nakamichi             043, 082
Onkyo                    029, 034, 037
Panasonic              009, 094
Philips                   015
Pioneer                  027, 016
RCA                      081, 088, 089
Sansui                    082, 083, 086
Sanyo                    039, 009
Sharp                     008, 014, 095
Sherwood              038
Sony                      001, 098, 099, 100
Teac                      048, 053, 083
Technics                024, 031, 004
Yamaha                 026, 035, 012
Tape
Brand                    Code(s)
Aiwa                     027, 029, 017, 063
Denon                    019, 005, 006
Fisher                    007
GoldStar, LG         004
Harman, Kardon    022
JVC                       015, 016
Kenwood               024, 011
Marantz                 031
NAD                      021
Nakamichi             058, 068
Onkyo                    025, 026, 028
Panasonic              047
Philips                   031, 065
Pioneer                  023, 014, 002
RCA                      061, 062
Sansui                    058, 057
Sanyo                    007
Sharp                     019, 064
Sony                      001, 066, 067
Teac                      057, 059
Technics                030, 003, 047
Yamaha                 020, 010
MD/DAT
Brand                    Code(s)
Aiwa                     012
Akai                      018
Denon                    003
JVC                       005, 008
Kenwood               004, 011, 014
Marantz                 007
Onkyo                    020 (DAT)
Panasonic              010, 006
Pioneer                  016, 020 (DAT)
Sansui                    009
Sharp                     013
Sony                      001, 002, 019 (DAT)
Teac                      005
Yamaha                 017
Mini Hi-Fi Component System Codes
Brand            Rcvr/Amp       CD       Tape     MD
Admiral                 095            085
Aiwa                     021             020
                              022             021        017
                              039             036        027
                              079             074        052       012
Akai                      074             068         048
B&O                      068            063         041
Crown                   062             058
Daewoo                 004             002
Denon                    009            007         005
                              027             008         019
Denon                027              008        019
                          023              022        018
                          036              008        019       003
Gerrard             057               053
GoldStar/LG     008               006       004
Harman/Kardon    034           090
Jensen                060              084        022
JVC                    018              017        015      005
                           019              018        016
                           070              017        042
                           018              017        042       005
                           078              073        051       008
Kenwood           014              013        011
                          015               014        012
                          024               033        024
                          024               023
                          071               065        045       014
                          071               065        011       014
                          082               077        054       011
                          083               078        055       014
Marantz             016              015         013
                          028               038         013
                           094              015         033
McIntosh            097              090
Onkyo                033               034         025
                           033              029          025
                           084               079         056     015
Panasonic           007              005
                           007              004          047
                           077              072          050      010
Philips                016              015          013
Pioneer               005              003          002
                           090               027         023
                           017               016         014
                           005               016         002
                           017               016         002
                           072               066         046
                           081               076         053       016
RCA                   091               080         060
SABA                 040               041
Samsung             041               042
Sansui                 087               083         057
Sanyo                  010               009         007
Schneider            069               064         043
Sharp                   036               008         019       003
                            015               014
                            027               008         019
                            027               008         006
                            080               075                       013
Sherwood            011               010         008
                            012               011         009
Sony                    001               001         001       001
                            002               001         001       001
                            102               098         066
                            102               098         067
Brand           Rcvr/Amp     CD      Tape      MD Sounde-sign        096           087
T+A                    063            059       040
Teac                    054            049       045
                            087                         057
Technics              006           004       003
                            007           004        047
                            044           024        030
                            025           031        003
                            073           067        047
Toshiba               101           096
Yamaha               013           012        010
                            029            026        010
                            029            026        020
                            029            026        044
Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > CW600p Remote [ « Previous ] [ Next » ]
