Thread: Which one is the best box with support |
Bronze Member Username: Cable
Post Number: 84 Registered: Aug-06
| Posted on Saturday, July 28, 2007 - 02:02 am: |
i just want to no that which one is the best box with good support ?? |
Bronze Member Username: Sitsat
Post Number: 81 Registered: Jun-06
| Posted on Saturday, July 28, 2007 - 06:36 am: |
without a doubt, that will be the dishnetwork receiver and they are always there if you call them  |
Gold Member Username: Crazy_greek
Post Number: 1045 Registered: Jul-06
| Posted on Saturday, July 28, 2007 - 08:25 am: |
Hey,Sit Sad I think amit was asking about Free to Air Receiver. I have Dish Network, they are there when you call, but not so hot on service. BTW do you get paid by the hour or by the customer? |
Silver Member Username: Brucester
Post Number: 504 Registered: Jul-06
| Posted on Saturday, July 28, 2007 - 10:31 am: |
you can get cw600p for 110CAN it is a great box for your doller it got great support i have 2 and it is the best box i have tried others and cw is the best and easy to use and the best thing it cost less then most other boxes and it is not a clone and in my eyes the other best is viewsat but cost around 200CAN and is little harder to use the choice is up to you but i love my cw600p |
Post Number: 85 Registered: Aug-06
| Posted on Saturday, July 28, 2007 - 10:53 pm: |
how good is the new CNX MINI ......... |
Gold Member Username: Satscanner
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2487 Registered: Nov-06
| Posted on Sunday, July 29, 2007 - 12:15 am: |
I'm really impressed with cw600s premimum too. Awesome box ,right behind my VS ultra,and cost only $83.oo can.I'll play with it for awhile ,then probbally get a SV4000 next. |
Silver Member Username: Bandizzy
Post Number: 156 Registered: Jun-06
| Posted on Sunday, July 29, 2007 - 12:38 am: |
sonicview 4000 hands down. the cw works great but the features and the look for the sv 4k is better but Twice as much. If you plan on using multi reciver switches the cw and sv interfear with each other. unless you use a power inverter, but that don't completely get rid of the problem either. you can mod the cw to 15/19 volts and even alows you to use the cw with DPP lnbs, and that seems to work better. I know this is a little off subject but if your gonna buy one choose one or the other for future thinking. You'll find alittle less headache. |
Gold Member Username: Hawaiian_time
Kanaka freak...
Post Number: 1195 Registered: Apr-06
| Posted on Sunday, July 29, 2007 - 05:20 am: |
Just look at who Charlie is going after and you'll get an idea of which brand DN is most worried about. I think you can't go wrong with a viewsat ultra, great support and nice features. |
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2489 Registered: Nov-06
| Posted on Sunday, July 29, 2007 - 07:29 am: |
Shlitz,I'm using my cw600s preminium with 6 sats dp and legacy lnb's mixed with 3 receivers at a time in the system and no problems with anything.This box has super features and exellent picture.So far I have no complaints and still finding more features with this box. It's way more fun than my ultra. |
Post Number: 86 Registered: Aug-06
| Posted on Sunday, July 29, 2007 - 07:36 am: |
no way i can't belive that satscanner u mean fortech ultra ? if it is then i can belive you if its vs ultra i can't belive that. cw600s is not even closer to vs ultra it can't even come near vs ultra ........maybe u don't have more experience with vs ultra . who wants mess areound with kround and all that shtz to update ur cw's in vs ultra there is only one program file and wala ur good to go ....... |
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2490 Registered: Nov-06
| Posted on Sunday, July 29, 2007 - 07:42 am: |
opkey file? Other than a card reader and usb ,what does the vs ultra have over the 600p ? picture is way better on cw. |
Post Number: 87 Registered: Aug-06
| Posted on Sunday, July 29, 2007 - 07:46 am: |
it just the one time and its not even necessary to load the opkey .... how abt channel list in cw....and kround satndby mode and u need the 3 different file to make ur cw works..... |
Post Number: 88 Registered: Aug-06
| Posted on Sunday, July 29, 2007 - 07:49 am: |
is ur cw have usb upgrade ?? its easy to upgrade |
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2491 Registered: Nov-06
| Posted on Sunday, July 29, 2007 - 08:10 am: |
Ok , vs is tops ! They kill there own boxes, import clones,over priced and you can add ch list or opkey or not .cw you don't have to add a ch list or the icon file if you don't want it.It' nice though.And no card reader,but vs hasn't activated it yet, but usb isn't worth the price difference.But the pic quality isn't as good as cw either and cw has more adjustments for pic and zoom too. |
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2492 Registered: Nov-06
| Posted on Sunday, July 29, 2007 - 08:15 am: |
And the vs ultra or the cw600sp both are not the "Best receivers" out today. |
Post Number: 89 Registered: Aug-06
| Posted on Sunday, July 29, 2007 - 09:22 am: |
vs dosen't belive in card or card reader its a gift from vs to there customer thats alll ....and vs is super fast scanning the sats don't have to wait like u do in cw for a long time to scan the sats .. lolz hahahha |
Post Number: 157 Registered: Jun-06
| Posted on Sunday, July 29, 2007 - 12:11 pm: |
they are both great boxes, I have both. They do mess with each other. the SV get the wait for update and the CW goes no signal when there on the same switch. was all i was saying. I've used the SV with CS and Pansat and didn't have the problem. Just stating whats worked for me. plus the epg, performance, and features on the SV are better no doubt, but then agian 100 bucks for the CW and 160 for the SV. |
Silver Member Username: Cartier1
Post Number: 530 Registered: Feb-07
| Posted on Sunday, July 29, 2007 - 10:43 pm: |
SatScanner Gold Member Username: Satscanner Beaversbush , Sportsmans Paradise Great White North Post Number: 2487 Registered: Nov-06 Posted on Sunday, July 29, 2007 - 12:15 am: I'm really impressed with cw600s premimum too. Awesome box ,right behind my VS ultra,and cost only $83.oo can.I'll play with it for awhile ,then probbally get a SV4000 next. satscanner what you mean play with it little.   |
