Thread: Hey Satscanner or somebody ???? |
Silver Member Username: Charjam
Post Number: 183 Registered: Sep-06
| Posted on Friday, July 27, 2007 - 07:07 pm: |
I have Pansat 2500 with 2.88 bin . I loaned it to a friend and set it up for him . He has a dishnetwork setup , On the lnb, it says dishnetwork tm 119 i have 75 level and 92 quality . When i do a blind scan i only picked up 5 TP"s . the channels i did get it says bad channel or scrammeled . I did a reboot several times and got some to work . So some would work and some wouldn't . Any ideas i thought maybe a bad cable but i have 92 % |
Silver Member Username: Rtap
FL
Post Number: 268 Registered: Jan-07
| Posted on Friday, July 27, 2007 - 08:07 pm: |
hey David try checking what setting you have lnb. if port 1 or port 2.go to menu,installation and check |
Silver Member Username: Runnerguy
Pluto
Post Number: 419 Registered: Sep-06
| Posted on Friday, July 27, 2007 - 08:17 pm: |
I am using the 293 bin with auto-roll off om my 2500a....make sure your setting are correct: LNB TYPE = DishPro DISEcQ – 119 = 1 and 110 = 2. |
Post Number: 184 Registered: Sep-06
| Posted on Friday, July 27, 2007 - 08:31 pm: |
I have the switch set right because the channels that do come in are fine . But i have the lnb set as standard |
Silver Member Username: Cntrlaltdel
Post Number: 147 Registered: Nov-06
| Posted on Saturday, July 28, 2007 - 12:26 am: |
Hey Satscanner or anyone else... is anybody getting BEV channel 2401? the channel display says Howard Stern, but the channel won't work, the rest of my BEV channels do. |
Silver Member Username: Mrskullz1
Brooklyn, New York
Post Number: 729 Registered: Feb-07
| Posted on Saturday, July 28, 2007 - 12:49 am: |
bill hunter....david hunter....perhaps brothers? |
Gold Member Username: Crazy_greek
Post Number: 1046 Registered: Jul-06
| Posted on Saturday, July 28, 2007 - 08:40 am: |
Hey, Bill Hunter There is NO Channel 2401 on Bev,besides Howard Stern in not welcome in Canada. |
Post Number: 148 Registered: Nov-06
| Posted on Saturday, July 28, 2007 - 12:51 pm: |
There's 2401 on mine, and since when is Howard not welcome in Canada? He's on my Sirius every morning and HowardTV is on Rogers Cable! |
