Thread: Please help - Pansat 2700A |
Bronze Member Username: Jack786
Post Number: 17 Registered: Oct-06
| Posted on Tuesday, July 24, 2007 - 12:09 pm: |
Hello, I need help, if this issue was reported before, please provide me link and I will read thru that thread for resolution. I have Pansat 2700A. It was working fine until about 3 weeks ago. It stopped working. The Level in Installation shows 99%, the "Quality" is blank. I check the dish and cable all okay. I connected DN receiver and I check the signal strength, I was getting about 90 to 110. I loaded the boot 75 on it and then loaded bin file 203. I'm still catching any Transponder. Please Help. |
Post Number: 18 Registered: Oct-06
| Posted on Tuesday, July 24, 2007 - 12:10 pm: |
I'm still "not" catching any Transponder. |
New member Username: Maxpayne
Post Number: 6 Registered: Dec-06
| Posted on Tuesday, July 24, 2007 - 02:14 pm: |
i have a problem with my pansat 2700A. since 3 weeks, my pansat didnt work. I have good quality and good signal, but no IMAGE. I put the new keys. DN and Bev Keys Feed Nagra2 keys ---------------------------------------- Dish Provider 0101: Last Updated (12 july '07 1:30 pm EST) Key 0: C5 42 C5 AE 9B 04 1D AA AA DC FC 40 99 82 3B D1 Key 1: 5B 27 8C AF DO 1E A5 A6 D7 74 3B A6 B4 21 17 97 (active) Bev Provider 0901: Last Updated (10 july '07 7:00 PM EST) Key 0: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 Key 1 :CO 89 A1 34 84 22 32 CD 36 11 33 7F AB 4E 02 08(ACTIVE) It says: bad or scramble channel. How can i fix it?? someone help me please!! |
New member Username: Dragonfly2
Post Number: 5 Registered: Jul-07
| Posted on Tuesday, July 24, 2007 - 02:36 pm: |
it sounds like you need to download the latest bin file |
Gold Member Username: Dude123
Post Number: 1057 Registered: Jul-06
| Posted on Tuesday, July 24, 2007 - 04:56 pm: |
no 203 bin should be working fine right now other than the "last" key problem. Did you try and swith your receiver ON/OFF from the back? do that and if the problem still exist then do a blind scan |
New member Username: Rayjen
Post Number: 6 Registered: Mar-07
| Posted on Thursday, July 26, 2007 - 04:03 am: |
try checking caps in the receiver on power supply board c13 and c14 if puffed up on top there bad make sure you replace the same way they came out neg and positive |
Gold Member Username: Nikk
Post Number: 1943 Registered: Sep-06
| Posted on Thursday, July 26, 2007 - 11:20 am: |
jack.. First of all...you need to check if the Diseqc switch is working or not, try to plug directly the cable coming from one of your LNB's to the receiver and then select Diseqc to OFF at the settings, if you can get video then your Diseqc is bad, Diseqc are very sensitive components and normally fails when humidity or some other conditions happen.... |
Bronze Member Username: Amt
Post Number: 27 Registered: Jun-06
| Posted on Thursday, July 26, 2007 - 08:16 pm: |
Hi I just bought Pansat 2700a I need the loader and bin file can anyone please help me |
Gold Member Username: Nydas
Post Number: 3061 Registered: Jun-06
| Posted on Thursday, July 26, 2007 - 09:53 pm: |
Pansat 2700A info from http://www.future-fta.info Boot 75 Loader 27.02 Latest BIN 204 This info also at http://www.dssrookie.com http://www.al7bar*tk. |
Gold Member Username: Satscanner
Beaversbush,
Sportsmans P...
Great White ...
Post Number: 2480 Registered: Nov-06
| Posted on Thursday, July 26, 2007 - 10:35 pm: |
Those are autorollig bins,so use it and keep the auto tp off. |
Post Number: 21 Registered: Oct-06
| Posted on Monday, July 30, 2007 - 01:35 pm: |
An update to my original question. I changed the c-13 and c-14 capacitors and I'm getting the signals now. Thanks guys. |
Post Number: 7 Registered: Jul-07
| Posted on Monday, July 30, 2007 - 08:10 pm: |
i have a pansat 2700a receiver and i have a problem with it keeping the channels. i have to rescan them then it is ok until i do some channel seaches. I also can't seem to be able to turn the tp autoupdate "on" |
Post Number: 25 Registered: Oct-06
| Posted on Tuesday, July 31, 2007 - 07:17 am: |
Jelly bean, I noticed it last night on my receiver too that i have to keep rescanning, the channels doesn't stay. Also same issue with not being able to turn the TP on. I wonder if it's due to bin file 204. Is that what you have? |
Post Number: 8 Registered: Jul-07
| Posted on Tuesday, July 31, 2007 - 11:13 am: |
yes, i have bin 204. |
Post Number: 28 Registered: Oct-06
| Posted on Tuesday, July 31, 2007 - 11:47 am: |
maybe we need to go back to older bin file. |
Post Number: 2013 Registered: Sep-06
| Posted on Tuesday, July 31, 2007 - 11:52 am: |
I have bin 203 and no problem with the channels.... |
New member Username: Scooby6969
| Posted on Tuesday, July 31, 2007 - 03:06 pm: |
with my pansat 2800 in the antenna setup what satallite do I setup for bev (Nimiq 1??) |
Post Number: 9 Registered: Jul-07
| Posted on Tuesday, July 31, 2007 - 04:48 pm: |
i have a 2700A receiver and i just lost the image the quality is 88%, but the it keeps seaching for the signal. does anyone have the new numbers yet. im not the only one who lost their pictures. |
Post Number: 10 Registered: Jul-07
| Posted on Wednesday, August 01, 2007 - 08:39 am: |
i am new at this. i have a pansat 2700a and i don't know how to put the new keys in. i see there are new keys that came out july 31 and i don't know the proceedure to put the new ones in |
Bronze Member Username: Dragonfly2
Post Number: 11 Registered: Jul-07
| Posted on Wednesday, August 01, 2007 - 08:49 am: |
Dish Provider 0101: Last Updated (31 july '07 1:30 pm EST) Key 0: B8 59 DF CF 32 DD 87 6C 3B D1 37 03 07 60 30 6A Key 1: 5B 27 8C AF DO 1E A5 A6 D7 74 3B A6 B4 21 17 97 |
