Thread: Satelite signal |
Silver Member Username: Charjam
Post Number: 180 Registered: Sep-06
| Posted on Friday, July 20, 2007 - 06:08 pm: |
I have a pansat 2500 and i took it to a friends house to let him use it but i can't get a sig. i am in buffalo area it says 231 deg by 26 deg but we can't get anything level is good . Any ideas Thanks Ps I did a factory reset on it |
Post Number: 181 Registered: Sep-06
| Posted on Friday, July 20, 2007 - 06:10 pm: |
By the way i have only one lnb going direct to the receiver |
Silver Member Username: Vndpatel
Post Number: 182 Registered: Mar-06
| Posted on Friday, July 20, 2007 - 06:53 pm: |
Try a blind scan? |
Post Number: 182 Registered: Sep-06
| Posted on Friday, July 20, 2007 - 07:34 pm: |
Thanks Bob but i did that , Nothing |
New member Username: Mpiper22
Choctaw,
OK
Post Number: 1 Registered: Jul-07
| Posted on Saturday, July 28, 2007 - 11:22 am: |
I have a cs6000 and need to download a channels template, where do I get this? |
Gold Member Username: Nydas
Post Number: 3067 Registered: Jun-06
| Posted on Saturday, July 28, 2007 - 10:16 pm: |
Mary Piper: Try http://www.f2atv.com http://www.dssrookie.com http://www.dssevolution.com http://www.dssrookie*com |
Silver Member Username: Hardrockstriker
Post Number: 943 Registered: Apr-06
| Posted on Sunday, July 29, 2007 - 12:36 am: |
Your dish isn't aimed correctly. Having a high level does not mean that the dish is aimed at the satellite; you must also have high quality. |
Gold Member Username: Crazy_greek
Post Number: 1048 Registered: Jul-06
| Posted on Sunday, July 29, 2007 - 07:17 am: |
Hey, David Hunter What Satellite are you trying to scan in? Are you trying for EchoStar 8/10 @ 110.0W? |
