Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Captiveworks loader
Author Thread: Captiveworks loader
Username: Timscarlet
Usa
Post Number: 245
Hello, i have tried to install a file today,
and the captiveworks loader is not working, i
downloaded a file a month ago, and it worked then, but not now, i heard another person had trouble also, is there a problem with the loader?
Username: Ustaad_hc
Post Number: 200
try CWloader V1.02 Zip
Username: Brucester
Post Number: 501
or try the 1.06 this is the loader i used on my 2 cw600p all is good one box got the bin140 and the other got bin142 with no trouble you can get it from dssrookie*com
Username: Hawaiian_time
Kanaka freak...
Post Number: 1168
Hey bruce, My friend has a 600p but can't seem to input keys with the 142 bin. Is there something else that needs to be loaded like a patch? There is nothing on the menu to access keys. And the autoroll doesn't work. I know I'm supposed to read but not much info on CWs here. Thanks.
Username: Mrskullz1
Brooklyn, New York
Post Number: 650
hawaiian time...go to any channel and press the page down/up button...there you can edit the keys.
Username: Therepo
Ftaview.com
Post Number: 138
Hawaiian time, you don't need to mess with the keys, 142 bin autorolls like a champ. Enable the patch: on a scramble channel, press F1, you'll see an "H" on the receiver display, then press "000". The tv screen will have a message saying "patch enabled". Now just wait for it to grab the keys. You may have to reboot the unit, too.
Username: Therepo
Ftaview.com
Post Number: 139
Here is the 1.42 bin for CW600 premium:
http://www.hostclip.com/dl/e88806cfc54610938f9a5741400768ed
Here is Loader v1.06:
http://www.hostclip.com/dl/6374a8a7ef29d166f918e57ae070bbbe
Username: Lklives
Post Number: 10507
therepo...cool that U did that for hawaiaan, cause he's one of the good guys here...
hawaiain..the pansat site future-fta.info has alot of captiveworks stuff, if ever in doubt..
BTW...Go Red Sox!
Username: Brucester
Post Number: 502
im glad to see others helping out with this box sorry im so busy working its hard to get back to others so keep up the good work and good info on the cw
Kanaka freak...
Post Number: 1171
Thank you very much guys! I really appreciate your help!
Username: Pkverma
Jabalpur, Mp
India
where I can get the new captive works program , look like need to down load new program
Username: Lklives
Post Number: 10636
U need to input new keys after u shut off the autorolls...
Here is a How Tos guide for all of the features available in CW600s Premium.
1.How to change EPG style? (Available in V1.13 Premium)
Now EPG style can be changed to new or old style. New epg style looks great but if you are using full channel name Old epg style will work good for you because it got more room to show full channel names. Here is how you can change EPG style.
Main Menu ->System settings-> OSD -> EPG Style -> Old or New
2.How to Turn ON/OFF Display Icon feature? (Available in V1.13 Premium)
Premium model allows you to see Icon in EPG and also on right upper corner of the screen. To make this feature work you have to load the Icon.bin file to your receiver. After you have loaded the Icon.bin file must turn this feature ON/OFF to see Icons in EPG and on screen.
Main Menu ->System settings-> OSD -> Display Icon -> Yes / NO
3.How to set 10/24 channels display?
Main Menu -> System Setting -> OSD -> Scroll down to Channel List change that option to 10 or 24.
Now whenever you will press Ok button on your remote it will show 10 channels or 24 channels.
If you press F1 key system will sort all of the channels
4.How to set Event Timer on fly?
With new OSD you can set event timer to certain event that will start in future sometimes on fly. Before set an event timer just make sure EPG is fully loaded.
EPG -> Scroll to the event that you want to tune automatically and press “Green” key from your remote. A window will open to confirm date and time that event will start; Now just Press Ok to set.
5.How to Factory Default a CW600?
New OSD the location for this feature is changed but it works exactly the same as in old OSD.
Main Menu -> Installation -> Factory Default
6.How to set time?
Main Menu -> Channels Manager -> Timer -> Time setup
7.How to Enable Patch or Disable Patch?
Exit all menus, Press F1 key; the LED will display 'H', then press '000'
8.How to Edit Patch key?
After Enable patch key, go to
Main Menu-->Accessories--> Key Menu
9.How to configure the SID sort?
From main menu->system setting->system->channel No. style can change:
Normal: Normal sort order
SID sort: Dish order
10.How to Category Search?
1) Make sure the epg is loaded- to do that just open the epg screen and see if the boxes are full, if not go choose any box that has no epg and wait 15-20 sec and it will be filled. (You only need to do this once in the beginning).
2) Then exit and hit F2 on your remote.
3) Category box will open, just choose what category you want to watch and hit ok
4) After 2-3 seconds, a list of channels will open which are CURRENTLY playing these categories (every half hour this list changes when a new show is finished or started)
5) Next to the channel there is the title of the show, if you hit INFO button it will open the full information, hit INFO again and it will disappear. Just select what you like and watch.
11.How to Blind scan?
BLIND SCAN function can be accessed by going to
Main Menu-> Installation -> Antenna Setting -> selecting the satellite
that you want blind scan and press Yellow key on your remote.
12.How to Clone CW600s Box to Box?
From DigitalPlus:
1) Connect the master and slave box with twist RS232 null modem cable (pin2 to pin3, pin3 to pin2, pin5 to pin5).
2) Start the master receiver and press "POWER" key to make it standby “- - : - -“.
3) Start the slave receiver, in the master box the led will display 'H' and blink it.
4) Input the password:
111 ---- Transfer S/W
222 ---- Transfer data
333 ---- Transfer data, then S/W
444 ---- Copy whole flash except Boot Loader.
5) After finishing inputting the password. Transfer will begin. When it finish, the LED will Display "-End". Disconnect the cable, start your receiver.
Note: By the different password, you can do what ever you want to do for Box to Box.
13.How to set DishPro LNBs?
DishPro LNB settings can be accessed by going to
Main Menu-> Installation-> Antenna Setting-> LNB type-> OCS-DP
14.How to Set Legacy SW21/42/44/ Switch?
Legacy Switches settings can be accessed by going to
Main Manu-> Installation-> Antenna Settings-> Legacy SW
Set the type of switch you got on your dish setup. Don’t forget to set DISCQ setting to none otherwise it will not work properly.
15.How to set channel lock on certain channels?
Channels can be locked by going to
Main Manu->Channels Manager->TV Channels -> Right Arrow-> Lock/unlock go to specific channel and press OK key on your remote.
16.How to video adjustments option menu?
Video options can be accessed by pressing zero “0” when view your normal TV. Brightness, Contrast, Saturation, Hue, Sharpness and Tint can be adjusted
17.How to Auto TP?
Auto Transponder Update can be Turn ON and Turn OFF by going to:
Main Menu ->System settings-> system-> Auto TP changed to ON or OFF.
18.How to get Twelve hour EPG on a CW600s?
To get 12 hours EPG tune to any channel on listed Transponders. EPG will show 12 hour programming.
Some TPs below help you get 12 hour EPG:
Dishnetwork:
TP: 12530
For Example CHs : 457 or 517
XXXX:
TP:12268
For Example CHs : 212 or 615
19.How to change Time setting from Military to Regular?
To change time from Military to Regular go to
Main Menu -> System Setting -> OSD -> Time Display Format change to 12/24.
20.How to search Favorite show channel number and time?
Shows can be searched with start time and channel number by pressing the Click on
Find key on your remote -> select OK -> then type your show name and search.
21.How to Turn ON/OFF Auto Roll feature?
Autoroll feature can be turn OFF and ON by going to:
Main Menu -> System Setting -> OSD -> Autoroll -> ON/OFF
22.How to Turn ON/OFF key update message?
Key update message can be turn OFF or ON. This feature can be accessed by going to:
Main Menu -> System Setting -> System -> Key Update Message -> ON/OFF
23.How to turn ON/OFF DN/XXX full name display?
This unique feature can be accessed by going to:
Main Menu -> System Setting -> System -> Scroll down to the next page -> ON/OFF
_________________
Home > Message Board > Home Video > Satellite TV > Archive through August 01, 2007 > Captiveworks loader [ « Previous ] [ Next » ]
