Thread: Archive through June 20, 2007 |
New member Username: Lexi
Post Number: 3 Registered: Jun-07
| Posted on Wednesday, June 13, 2007 - 08:23 pm: |
New Keys anyone?? please. |
Bronze Member Username: Therepo
Ftaview.com
Post Number: 50 Registered: May-07
| Posted on Wednesday, June 13, 2007 - 08:25 pm: |
Rat, one of these times you're out there adjusting the dish, take a socket wrench with you and tighten it up real good. For keys, check in your system info you have the latest software installed: x-85bl_070411_293_api. Then make sure the autoroll option is turned ON. |
Bronze Member Username: Katekev04
Post Number: 21 Registered: Jun-06
| Posted on Wednesday, June 13, 2007 - 08:29 pm: |
Those keys are not working for me either! |
Post Number: 22 Registered: Jun-06
| Posted on Wednesday, June 13, 2007 - 08:34 pm: |
Never mind, needed to roll I guess |
Bronze Member Username: Vazman4u
Post Number: 15 Registered: Jun-06
| Posted on Wednesday, June 13, 2007 - 08:52 pm: |
Help! Since keys changed, no TV! Pansat 2700A X-87bl | API:75-2.03_EUBX Boot Ver: 75 070411 bin I have high level, but 0 quality. Did they move the SATs? I went to my roof and played with the position of the dish, but still no quality. I get "no signal" even on channels that are not scrambled. Can u please tell me if I should spend some more time on my roof or is it a software issue? Nalin, anything??? |
New member Username: Rat
Post Number: 2 Registered: Jun-07
| Posted on Wednesday, June 13, 2007 - 08:53 pm: |
therpo, He hooked it to a pole and inserted into the groud. I have to get a new pole, because that is what is causing it to move. My system information reads x-85bl API :2.82Ta_EU Boot ver: 6.0 21. Oct. 2006 Future - FTA Make sense? |
Silver Member Username: Bertoro
Toronto,
Ontario
Post Number: 574 Registered: Apr-05
| Posted on Wednesday, June 13, 2007 - 08:55 pm: |
guys..try these...again they are working for me Key 0: 3A 50 1C 03 02 07 30 A6 75 5A 13 22 32 E3 6E A5 |
Post Number: 16 Registered: Jun-06
| Posted on Wednesday, June 13, 2007 - 09:07 pm: |
I have the correct keys installed and I tried autoroll on and off. Can anyone please help? |
| Posted on Wednesday, June 13, 2007 - 09:22 pm: |
I also have the correct keys but no picture. Autoroll is on as well. |
Post Number: 4 Registered: Jun-07
| Posted on Wednesday, June 13, 2007 - 09:28 pm: |
Should codes for Provider ID 01 and 09 be exact? I put the above codes in for Provider ID 01 01, Key number 01 and 00. What about Provider ID 09? Please help |
Post Number: 17 Registered: Jun-06
| Posted on Wednesday, June 13, 2007 - 09:34 pm: |
RAT: Provider ID 09 is for the BEV keys try these: Bev Provider 0901: Last Updated (6 June '07 2:45 PM EST) Key 0: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 (Active) Key 1: F1 69 FA E9 5F 6E 33 94 5E 28 F3 C4 99 5A 00 F5 |
Post Number: 5 Registered: Jun-07
| Posted on Wednesday, June 13, 2007 - 09:48 pm: |
Thanks Joe. It keeps jumping to TP AutoUPdate. Not sure why... |
Post Number: 6 Registered: Jun-07
| Posted on Wednesday, June 13, 2007 - 09:53 pm: |
I'm up and running. I turned the TP autoupdate off and now I'm up. |
New member Username: Bobby5612
Warsaw,
In
United States
Post Number: 1 Registered: Jun-07
| Posted on Wednesday, June 13, 2007 - 10:19 pm: |
i have a fortec ulta i tryed to put the key in but when i hit the ok button my receiver go off. what sould i do |
Ftaview.com
Post Number: 51 Registered: May-07
| Posted on Wednesday, June 13, 2007 - 10:39 pm: |
Rat: The bin you have is from last October. No wonder it's not autorolling!!! |
Gold Member Username: Nydas
Post Number: 2838 Registered: Jun-06
| Posted on Wednesday, June 13, 2007 - 10:51 pm: |
Rat: Based on the information about your current BIN, I would suggest you install 293T BIN and not 293 BIN. There is a small chance that your receiver might be a Pansat 2500A clone and not the real thing. |
New member Username: Moej1991
| Posted on Wednesday, June 13, 2007 - 10:53 pm: |
hos everybody doing |
| Posted on Wednesday, June 13, 2007 - 10:56 pm: |
im da best person 2 ask 4 help wit ur problems wit tv |
| Posted on Wednesday, June 13, 2007 - 10:58 pm: |
if any body thinks im wrong com c me niggas |
Bronze Member Username: Srpskkisiin
Post Number: 20 Registered: Mar-07
| Posted on Thursday, June 14, 2007 - 11:38 am: |
keys are about to change, check http://www.jordinclub.com and go to forum, and find dishkeys section for newest keys |
Bronze Member Username: K98
Post Number: 34 Registered: Jan-07
| Posted on Thursday, June 14, 2007 - 11:56 am: |
need keys for d.n. out 11:50 am 6-14-o7 |
Bronze Member Username: Barbados
Post Number: 21 Registered: Aug-06
| Posted on Thursday, June 14, 2007 - 12:00 pm: |
Hi all need keys for Pansat |
New member Username: Vinodtiwari
Mississauga,
Ontario
| Posted on Thursday, June 14, 2007 - 12:06 pm: |
new keys please}}} |
Post Number: 35 Registered: Jan-07
| Posted on Thursday, June 14, 2007 - 12:31 pm: |
nalin you are the best thanks #s r working |
Post Number: 22 Registered: Aug-06
| Posted on Thursday, June 14, 2007 - 01:42 pm: |
Hi cotton coots do u have the keys does anyone have the keys thanks Bajan |
Post Number: 2839 Registered: Jun-06
| Posted on Thursday, June 14, 2007 - 02:00 pm: |
DN (Provider ID 0101) Key 00: (86) 3A 50 1C 03 02 07 30 A6 75 5A 13 22 32 E3 6E A5 Key 01: (96) CB FB 84 C0 97 81 54 5E 41 7F 6A 72 B0 2D 0C BC Bev (Provider ID 0901): Key 00: (86) E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 Key 01: (96) F1 69 FA E9 5F 6E 33 94 5E 28 F3 C4 99 5A 00 F5 |
Bronze Member Username: Silverfox62
Kentucky
Post Number: 17 Registered: Aug-06
| Posted on Thursday, June 14, 2007 - 02:01 pm: |
dish keys arent working anyone have the keys?? |
Mississauga,
Ontario
did anyone have the new keys please thanks |
Bronze Member Username: Tonytoy
Post Number: 26 Registered: May-06
| Posted on Thursday, June 14, 2007 - 02:27 pm: |
Hi Vinod: Nalin has just posted the keys for DN and BEV. |
New member Username: Magicmeraj
Mississauga,
ON
| Posted on Thursday, June 14, 2007 - 04:03 pm: |
THEREPO you are the best thanks it's working. |
Post Number: 21 Registered: Mar-07
| Posted on Thursday, June 14, 2007 - 04:32 pm: |
Yea folks those keys work, but there is a trick to it, just visit my forum at and go to dishbev keys thread; http://www.jordinclub.com |
Post Number: 2840 Registered: Jun-06
| Posted on Thursday, June 14, 2007 - 05:37 pm: |
You do not need to join other forums for keys, and the instructions are available at most forums. |
Warsaw,
In
United States
| Posted on Thursday, June 14, 2007 - 08:01 pm: |
i the one who have the fortec ulta i download the 293t but the receiver is still shuting down when i hit the ok button after putting in the keys can someone help me |
New member Username: Allen9
Toronto,
On
Post Number: 3 Registered: Oct-06
| Posted on Thursday, June 14, 2007 - 09:14 pm: |
new key please? |
Post Number: 2843 Registered: Jun-06
| Posted on Friday, June 15, 2007 - 02:11 pm: |
bobby gordon: 1. Note down your DisEqC settings if any. Do factory reset. 2. Install factory BIN or 280T BIN 3. Install 28oT BIN. 4. Do user settings including time, date and time zone. Do disEqC settings if any. 5. Install 293T BIN. 6. Scan at least one satellite. 6. Set autoroll on, auto TP off 7. Switch off at back - wait 40 seconds. Switch on. 8. The keys will auto roll. 9. Scan other sattelites. Make sure your files are unzipped. Use BL updater 1.4 and straight cable. Always WAIT, WAIT, WAIT at the end of an upload to the receiver. Best of luck |
Post Number: 2844 Registered: Jun-06
| Posted on Friday, June 15, 2007 - 02:12 pm: |
There are no new keys since my last post yesterday. |
Post Number: 18 Registered: Jun-06
| Posted on Friday, June 15, 2007 - 02:32 pm: |
Nalin, Please read my post that I posted earlier. My real question is, Would your bin or any other setting cause you not to get a signal?Or will you get a signal no matter what software is installed on the pansat 2700A? Please help. I respect your suggestions. |
New member Username: Amil
| Posted on Friday, June 15, 2007 - 04:01 pm: |
Hi Every one my name is amil and new to FTA system please don't make fun of me if I asked stupid qustions. somebody installed the system and didn't give any instruction. |
New member Username: El_limite
Post Number: 2 Registered: Feb-06
| Posted on Friday, June 15, 2007 - 04:58 pm: |
does someone have the new keys? |
Warsaw,
In
United States
| Posted on Friday, June 15, 2007 - 08:42 pm: |
nalin i tried to do what you said to do but it didnt work, the autoroll start counting then the receiver cut off do you have any more idea.thank |
Silver Member Username: Anai
TX
United States
Post Number: 168 Registered: Jun-05
| Posted on Friday, June 15, 2007 - 09:53 pm: |
actual keys? please |
Bronze Member Username: Wineskm
Post Number: 12 Registered: Oct-06
| Posted on Friday, June 15, 2007 - 10:06 pm: |
I've done a Factory Reset without writting down the DisEqC settings. What can I do to get them right? KmW |
Post Number: 2846 Registered: Jun-06
| Posted on Friday, June 15, 2007 - 10:31 pm: |
Joe Vazman : Incomplete installation of the software followed by possible change of direction of your dish. The best I can suggest now is to reinstal the BIN and then do a repositioning of the Dish to aim it properly. |
Post Number: 2847 Registered: Jun-06
| Posted on Friday, June 15, 2007 - 10:34 pm: |
bobby gordon: When autoroll does not function properly, you should turnit off, do a "Set default keys" - then enter the Key00 and Key 01 manually. |
Post Number: 2848 Registered: Jun-06
| Posted on Friday, June 15, 2007 - 10:36 pm: |
KmW: You can look at the switch and note down the physical connection. Alternatively try setting Port 1 to something such as 119W and see if you have good quality, then try scanning. If you have time and do not want to climb on tothe roof, trial and error method works. |
Post Number: 13 Registered: Oct-06
| Posted on Friday, June 15, 2007 - 11:20 pm: |
Nalin, thanks, I have access to my antenna from the ground. Here are the some of the settings on the menu of my LTU. LNB Type: Local-Freq.: DiSEqC #: Skew: TP: I show Echo 8.1/kU with a Level of 79% and Quality of 96%, and Echo 7/kU with a Level of 80% and Quality of 89%. What is the best way to get all the settings right? Thanks Again, KmW |
Bronze Member Username: Colo_colo
Post Number: 67 Registered: Jun-06
| Posted on Saturday, June 16, 2007 - 04:08 pm: |
does anyone has new keys for dish? |
Post Number: 2850 Registered: Jun-06
| Posted on Saturday, June 16, 2007 - 04:54 pm: |
The last valid keys for DN were on 13th June and have been posted. |
Silver Member Username: Jpz
MTL,
QC
CAnada
Post Number: 209 Registered: Jun-06
| Posted on Sunday, June 17, 2007 - 09:51 am: |
Hi to all |
Bronze Member Username: Vlemar
Mississauga,
Ontario
Post Number: 28 Registered: Nov-05
| Posted on Sunday, June 17, 2007 - 11:14 am: |
all channels seem to have gone off line. all channels report "no signal" error when selected. Tried a couple of other sites where new keys become available quite promptly but with no success. I watched the channels with the keys posted on June 13 until wee hours of Sunday. Hopefully new keys will be posted soon. |
Bronze Member Username: Gusification
Post Number: 50 Registered: Nov-06
| Posted on Sunday, June 17, 2007 - 11:48 am: |
anybody have new keys? |
Mississauga,
Ontario
Post Number: 29 Registered: Nov-05
| Posted on Sunday, June 17, 2007 - 04:13 pm: |
any idea if a new bin is required this time around. all the sites continue to post keys effective as of June 13, 2007. seems encryption algorithm may have been changed. any insight into what has transpired will be greatly appreciated. |
Ftaview.com
Post Number: 60 Registered: May-07
| Posted on Sunday, June 17, 2007 - 04:31 pm: |
Diknet hasn't changed keys or anything else since the 13th. You have some other problem. "No signal" sounds like NO SIGNAL! not "scrambled channel". Check your antenna quality/strength levels. |
Post Number: 2851 Registered: Jun-06
| Posted on Sunday, June 17, 2007 - 05:07 pm: |
I am confirming that there is no DN keys change since 13th June and there are no missing channels. |
Bronze Member Username: Hvs
Post Number: 25 Registered: Aug-06
| Posted on Sunday, June 17, 2007 - 05:51 pm: |
All channels are reporting "No Signal". Keys seem to be ok. But am getting 0 quality all of a sudden. And after 5 hrs without doing anything everything is ok........... But now again after watching for 2 hrs its all gone again with 0 quality....... I don;t understand the problem. Any help is really appreciated. |
Warsaw,
In
United States
| Posted on Sunday, June 17, 2007 - 07:40 pm: |
hello nalin, i tried to do that enter the key manually and the receiver still shut it self off, when i hit the ok button i got to go in the back of the receiver and turn the power back on, need help thank |
Bronze Member Username: Rainman62
Post Number: 14 Registered: Nov-06
| Posted on Monday, June 18, 2007 - 02:03 am: |
I'm having same problem too. All Sats 119, 110, 61.5 no signal 0 quality/strength. If I turn off the receiver for a min or so then turn it on, the signal will come back for about few sec then everything go off again. |
Post Number: 15 Registered: Nov-06
| Posted on Monday, June 18, 2007 - 02:04 am: |
BTW, I have CS5K |
Ftaview.com
Post Number: 62 Registered: May-07
| Posted on Monday, June 18, 2007 - 06:49 am: |
Coolsats will power off if there is a short somewhere in your connection to LNB. Or... If you're running DPP LNB(s) or dp34 switch you should have DN receiver connected at the same time to supply power requirement. That means you can't just unplug coax from sub box and plug into fta, as it will often work for a few minutes, then nothing. And if it works you are putting strain on your box anyway, so keep sub box connected, and run another cable for fta. |
Post Number: 2852 Registered: Jun-06
| Posted on Monday, June 18, 2007 - 09:48 am: |
bobby gordon : You probably do not have your date, time and time zone set properly and with wrong time you are going into a never ending EPG fetch. Another problem many people get into is not waiting long enough after an upload of a BIN. Always when autoroll misbehaves in any way, the best thing to do is 1. Set date, time and time zone. Blind Scan if necessary. 2. Turn autoroll and autoTP off 3. do "Set default keys" 4. Install keys manually (Key 00 and Key 01) and SAVE. 5. Turn receiver off. 6. Turn it on after a minute. If you still have problem, it would seem that you did not do the process of uploading the BIN properly. All this applies to people who have good working setup. If your initial set up has changed, then you have intorduced other variables. |
Post Number: 2853 Registered: Jun-06
| Posted on Monday, June 18, 2007 - 09:52 am: |
SamS: Note what Therepo has said above. This is the first time somebody on this forum has confirmed that with some DN equipment and LNBs, you need to power the system separately for FTA receivers to work. I have been aware of this problem notably with Pansat 3500 and some models of Viewsat and it seems that the C00LSATS may also have the same problem. |
Post Number: 7 Registered: Jun-07
| Posted on Monday, June 18, 2007 - 10:37 am: |
My quality went out. I changed my a dish direction and my quality came back 90%, but for Echo 7/ku 119, I am missing a lot of channels. I loaded all of the other Echo Satellite and they all mostly came in with all the channels, but the channels that I really want are on 7/ku. Why is some TP's Quality 0 when others is high? How can I get all the proper channels for 7/ku? |
Post Number: 8 Registered: Jun-07
| Posted on Monday, June 18, 2007 - 10:38 am: |
also, my DiSEqC is set to Off. My 22khz is also set to off. My positioner Setting is on Disable. Does this mean anything? |
Post Number: 16 Registered: Nov-06
| Posted on Monday, June 18, 2007 - 11:12 am: |
Therepo and Nalin, sorry, I don't understand what you mean with "so keep sub box connected, and run another cable for fta" I have been running my cs5K for almost 6 months with no problems with signal of ~97% on all LNBF. I was out of town over the weekend, so what happen suddenly? I have 3 receivers in my 2 homes (I work in different town), 2 receivers are working flawlessly, and only mine have stop working. Will resetting the receiver and re-scanning would fix the problem? |
Post Number: 26 Registered: Aug-06
| Posted on Monday, June 18, 2007 - 12:41 pm: |
don;t try to rescan..... SamS I am having the same problem right now as I mentioned in my prev. post. I tried to reinstall everything again by doing factory default settings. But then now I am also not able to scan as the quality is 0% & so its not taking any channels or TP while scanning. In my case also this "No Signal" error came in the weekend & then it again disappered for about 2 hrs & then again it came on the screen killing my happiness. |
Post Number: 27 Registered: Aug-06
| Posted on Monday, June 18, 2007 - 12:42 pm: |
any help in this matter would really be appreciated.... |
Post Number: 17 Registered: Nov-06
| Posted on Monday, June 18, 2007 - 01:02 pm: |
I'm shocked what could happen out of the sudden over the weekend? It seems like someone disconnected the cable except when you turn the receiver off and on, the channels will come on for a few sec and then dissapear. I did a reset this morning Harry, and now I have no channels and no signal. Harry, have you tried bypassing the db34 switch? (I'm at work now and cannot try anything till later today). Does anyone think the problem lie with the swtich? I'm sure it's not dish alignment, because it's set tight and we had no bad weather other than heat. Anyone else is having similar problem beside Harry and I? |
Platinum Member Username: Lklives
Post Number: 10012 Registered: Jan-06
| Posted on Monday, June 18, 2007 - 02:20 pm: |
Nalin said above... "This is the first time somebody on this forum has confirmed that with some DN equipment and LNBs, you need to power the system separately for FTA receivers to work." Well thats BS!!!!!!... It has been posted here THOUSANDS of times that DPP LNB's (DN equipment) need an additional power source for the FTA receivers to operate..in fact myself and PRFRMNJ constantly advised people of this! |
Post Number: 18 Registered: Nov-06
| Posted on Monday, June 18, 2007 - 03:31 pm: |
what do you guys mean to power the system separately? please advise. |
Post Number: 10017 Registered: Jan-06
| Posted on Monday, June 18, 2007 - 04:37 pm: |
It means that U need to also connect a DN receiver and leave it powered ON always...as the DN receiver supplies power to the Dish Pro Plus LNB's, that a FTA receiver cannot always do alone.... |
Post Number: 19 Registered: Nov-06
| Posted on Monday, June 18, 2007 - 04:45 pm: |
That's not a good news, where am I going to get a DN receiver? ebay? maybe. Any particualr model?do I need a service? |
Post Number: 10019 Registered: Jan-06
| Posted on Monday, June 18, 2007 - 04:48 pm: |
no service needed ...and any OLD DN receiver will do.. DPP LNB's are a pain.. |
Post Number: 20 Registered: Nov-06
| Posted on Monday, June 18, 2007 - 05:21 pm: |
That's why in my other home the 2 recievers are still working because I installed legacy LNB to the dish500 for 119/110 and another for 61.5 connected via dp34 switch, instead of the DPP. Well Thanks LK for your advise. Let me get busy and start searching for DN receiver. |
Warsaw,
In
United States
| Posted on Monday, June 18, 2007 - 05:32 pm: |
hi again nalin i tried the way you said to do but when i go to do set default key my receiver go out |
Post Number: 10021 Registered: Jan-06
| Posted on Monday, June 18, 2007 - 05:33 pm: |
Dp 34 switch is for Dish Pro LNB's not Legacy LNB's.. good luck...U should be able to pick up an old DN receiver from a tag sale, flea market for $25...and don't worry about a card for it.. |
Post Number: 2856 Registered: Jun-06
| Posted on Monday, June 18, 2007 - 06:14 pm: |
SamS: I had posted the following about 4-5 months ago, but at that time LK and his cronies wantedto laugh at me instead of accepting it. ON THIS FORUM, I had attempted about 4 times to alert people to the power draw of DN equipment and in particular the LNBs with DP34. So LK, stop taking credit for something you were riduculing only a few month ago. The following is part of my previous post on this subject. http://www.microyal.com/dp-34a-instal-istrn.jpg The DP34 gets its power from the receiver, which should be on for the switch to work. You might want to consider putting a separate power supply to DP34. You might also consider using a DP3437 dishpro adaptor, connect to one outlet of your DP34 and power it separately. " |
Post Number: 10028 Registered: Jan-06
| Posted on Monday, June 18, 2007 - 06:24 pm: |
nalin...U got some big lying gonads trying to take credit for something PRFRMNJ and myself were posting.. and U in fact were arguing AGAINST us about the need for more power!...U are a low life LIAR!...two faced phoney bi*tch! Don't even talk to me...u disgust me! |
Post Number: 2858 Registered: Jun-06
| Posted on Monday, June 18, 2007 - 06:31 pm: |
LK: I have ALL the posts of that time and YOU were the ones who did not accept my statement for the need of extra power. I am saying: Do not attempt to take the credit for something you were totally ignorant of and were ridiculing. Go and take you paranoid psychotic, and get OFF this thread. |
Bronze Member Username: Chechi
Post Number: 25 Registered: Apr-06
| Posted on Monday, June 18, 2007 - 07:22 pm: |
I am buying a new receiver, and would like to Know if a Pansat 2500A is still relevant, because I can buy it with 40 dollars. So I am thinking about the availability of the software in the future; I mean new BIN, etc.. Or do I need to upgrade to pansat 2700? Thank you in advance for your help. |
Post Number: 9 Registered: Jun-07
| Posted on Monday, June 18, 2007 - 07:31 pm: |
Can someone help me from my earlier post? |
Post Number: 10033 Registered: Jan-06
| Posted on Monday, June 18, 2007 - 08:17 pm: |
rat...the bottom line is....to start with, U must realign the dish correctly and input the appropriate dish/antenna settings into your receiver, along with proper cabling and switch....U need to go to another site and read the manuals..there are NONE here...GO READ THE... "RECOMMENDED REPUTABLE SATELLITES SITES" thread here.. whatever u do, do NOT listen to nalin...she has ruined many people's receivers with her always incorrect info.. |
Post Number: 2859 Registered: Jun-06
| Posted on Monday, June 18, 2007 - 09:25 pm: |
LK: Get off this thread. You are the one responsible for ruining receivers when you did not know about the power supply problem with Pansat 3500. YOU start reading in the forums you advise others to read. Your information and knowledge is stale and what little you post is C/P from others. You are PLAGIARIST and a LIAR and now trying to take credit for things you did not know about. Go somewhere else with your lies. |
Post Number: 10041 Registered: Jan-06
| Posted on Monday, June 18, 2007 - 11:45 pm: |
nalin...STFU...and go away!...u just told a newbie to Jtag a receiver with a simple fix nite rider lights problem...he most likely would have destroyed his receiver if he had listened to U...and EVERYONE chided U for your WRONG INFO once again...get the hell out of these forums! |
Post Number: 21 Registered: Nov-06
| Posted on Tuesday, June 19, 2007 - 12:32 am: |
You guys LK and Nalin, you always argue and always fight, I've been watching this forum for almost 6 months now, between both of you always fight, fights and more fights. Do you guys agree on something? Sometimes, I'm wonder if you knew each others and faking the fights. |
Post Number: 10048 Registered: Jan-06
| Posted on Tuesday, June 19, 2007 - 08:59 am: |
Its NOT a 'fake" for sure...nalin is very dangerous with her bad info constantly...IU've ben doing this stuff at many sites for many years LONG before nalin ever even heard the word "satellite"..SHE IS JUST AN EGOTISTIC OVERBEARING CONTROL FREAK WHO IS totally OUT OF CONTROL...she's an embarassment to herself and this hobby...she would be banned from any site that I admin at.. |
Post Number: 2868 Registered: Jun-06
| Posted on Tuesday, June 19, 2007 - 09:59 am: |
SamS: Initially I was not aware that your problem might be related to DP34 switch and/or DN LNBs and their power draw. I had posted many months ago a well researched statement - If you are using DN equipment and DP34 switches, you may have power problems with FTA receivers. Many people are switching from DN receivers to FTAs and running into this problem. Therefore, in all cases it is prudent to advise people to power the DP switch separately. LK and his cronies, who had no idea about this problem ridiculed me, insulted me and pretended never to accept it. During those day 2-3 clients had their POansat 3500 damaged because they believed that LK and his cronies were right and I was wrong. Now the same LK is trying to tell everybody that he always knew it and had always advised it. He is a Plagiarist and a liar of the worst kind. I believe in playing it safe. There is a probability of damage to your receiver if the DP34 is not powered properly and I do not want to take any chances. The extra power does not cost too much - it can even be an old discarded DN receiver. |
Post Number: 22 Registered: Nov-06
| Posted on Tuesday, June 19, 2007 - 10:20 am: |
I have an old DN 3000 reciever in the basement (that's a lagacy receiver), will that work? I was reading around and people are saying that I need a receiver that can support and power DPP (in other words not a lagacy one). What's your thought on this? In regard to a power inserter, any idea where to buy those? and what's better a power inserter or an old DN reciever? Thanks |
Post Number: 2870 Registered: Jun-06
| Posted on Tuesday, June 19, 2007 - 10:52 am: |
Connect it up as shown in this diagram and see if it works. http://www.microyal.com/dp-34a-instal-istrn.jpg |
Mississauga,
ON
| Posted on Tuesday, June 19, 2007 - 01:17 pm: |
I want to now the size of the dish and LMB for this angles (61.5º,77º,105º, 110º, 118º,119º,121º,129º, 148º).} |
Post Number: 23 Registered: Nov-06
| Posted on Tuesday, June 19, 2007 - 02:11 pm: |
are you serious? there's no one dish for all of these. I know (110, 119, 121 or 105) are one superdish 61.5 is a single dish 300 or dish 500 Others I'm not sure |
New member Username: Zidane88
| Posted on Tuesday, June 19, 2007 - 02:56 pm: |
Hey guys, I haven't gotten any signal from the 119 dish for three days. I tried turning the reciever off and then turning it back on, but the problem presists. The 110 is working just fine. I have seen people with same problem on this forum as well. Can you guys help me please?! |
Post Number: 24 Registered: Nov-06
| Posted on Tuesday, June 19, 2007 - 03:59 pm: |
I'm assuming you used to have signal on 119 and now you don't. Do you have dish 500? what kind of switch do you have? I'm assuming either your wire or the switch gotten bad. I heard the switch get bad every now and then. Try connecting the 119 directly to your reciever and see if you have a signal (bypass the switch). |
| Posted on Tuesday, June 19, 2007 - 04:04 pm: |
I got no idea what switch I have. But as you said, the signal on the 119 is now completely gone and it has nothing to do with the keys. I'll talk with my brother; he knows about this much more than I do. I'll get back to you. |
Post Number: 2879 Registered: Jun-06
| Posted on Tuesday, June 19, 2007 - 07:14 pm: |
magicmeraj : If you want all these Sats, try a 30-33" Dish with a motor. |
Mississauga,
ON
| Posted on Wednesday, June 20, 2007 - 09:32 am: |
Thanx for the answer Nalin but I want to no about the size of the dishes there r some in the market like 18" 22" 24" 30" 33" & 39". So for which angle we use all this Dishes. |
Post Number: 2887 Registered: Jun-06
| Posted on Wednesday, June 20, 2007 - 10:28 am: |
I did say that the size of Dish should be 30-33". You then motorise it and you can have all the above Sats. Motorised dishes are controlled with a controller and you swing it to the Sats as and when you need a channel for viewing, so angle is not as relevant as it is when setting up a fixed Dish. From the level of knowledge you have about this technology, it is best you get an installer to install it for you. The approximate costs are about $100 for Dish about $150 for motor and about $80 for installation. Receiver costs vary between $100 to $250. |
Post Number: 10087 Registered: Jan-06
| Posted on Wednesday, June 20, 2007 - 11:02 am: |
Motorised dishes are controlled with a controller and you swing it to the Sats as and when you need a channel for viewing, so angle is not as relevant as it is when setting up a fixed Dish. LMAO...are U for real?....U are dumber than dumb! |
Bronze Member Username: Sccrskills
Post Number: 46 Registered: Dec-06
| Posted on Wednesday, June 20, 2007 - 04:08 pm: |
new keys anybody |
Post Number: 47 Registered: Dec-06
| Posted on Wednesday, June 20, 2007 - 04:09 pm: |
i was watching an important soccer game and picture went out please need new keys fast |
New member Username: Johnkapo
Post Number: 4 Registered: May-07
| Posted on Wednesday, June 20, 2007 - 04:21 pm: |
new keys pls. for 20th june |
