Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through June 07, 2007
Author Thread: Archive through June 07, 2007
Username: G0dm0de
DISH - May 31
86: 13 F1 FD 82 96 B8 7C 0A 7E 93 80 6A 6B 25 66 B0
96: 53 B1 5A D5 D0 FD 53 8C 6F 19 5F DE BF 78 80 8E
Username: Dish_addict
Post Number: 11
I'm having serious problem and nopbody has been able to help me. Please please listen....
I have Dish Network. In my Channel Edit section, I just have old pin. I know that I need Second pin to input the codes (I know what to do then). But can someone tell me a step by step approach of how to get that second pin showing on Menu's Channel Edit screen. I hope someone can help and solve my problem.
Username: Jalaj69
Norcross , Georgia
Post Number: 82
hey guys, i have coolset 500 platinum..
i recently lost all he signal and everytime i change channels or any thing, it says Scram. Bad. Channel..
is their a new keys for this?
Please HELP
Post Number: 12
Jalaj, just unplug the wire from the port and try plugging after a few seconds. It may work...
Post Number: 13
Username: Lklives
Post Number: 9721
to get 2nd pin...load factory bin, then latest bin..
Username: Jalaj69
Norcross , Georgia
Post Number: 83
...well sorry it is coolset 5000 ..
but yaa i found the new pin which was key86 that is deffernt.
but i forgot how to enter in the pin...
please direct me on how to enter the pin with this box..
thanks
Post Number: 14
Hi LK, I have loaded factory bin and selected English. That makes Parental Control and Channel Edit unaccessible. Now I went to Antenna Setup and have started Echo 3 KU TP download. After which I will do the Echo 7KU download. Am I on the right track....
Username: Lklives
Post Number: 9723
Did u allow the AUTOROLL to input the new keys?
BTW...NEVER unplug a wire from "the port" when powered on...and a RESET is a power OFF, wait 2 minutes, power ON using, rear switch fixes some problems, but NOT key changes!
and a "pin" and KEYS are NOT the same!
Username: Brittney199
Is there any new keys for dish network? Cause it's not working for me.Help please!!!!!!!
Thnx
Username: Nydas
Post Number: 2754
DJ: For the "second Pin" to show up in the menu, you have to scan at least one satellite.
When you scan Echo 7, make sure you have it on a different DisEqC port.
Username: Nydas
Post Number: 2756
Anna Tan : New Keys have been posted today at least twice above.
Username: Lklives
Post Number: 9726
DJ...to access "parental Controls" , U must perform a scan which then inputs channels into your receiver... otherwise there is NO need for parental controls UNLESS U have channels scanned and inputted...hope u understand that logic..
and u will need the latest bin too!...after the factory bin!
Username: Submission
Hi, i hope someone can help:
I've inputted the new dish keys into my reciever, but im still getting a "No Signal" msg on my screen. Does any one have any suggestions, as to what the prob may be?
Thanx
Username: Lklives
Post Number: 9738
U need to provide much more info and your experience level..
BTW...use same keys as posted above, that changed yesterday..
Well, i dont have much experience with this stuff, thats for sure. I did use the same keys as posted above, and they were the exact same when i went to put them in.
What info do you need?
Username: Lklives
Post Number: 9741
Keymaster
DN and Bev Keys Feed
Nagra2 Keys
Dish Provider 0101: Last Updated (May 31 5:00pm EST)
Key 0: 13 F1 FD 82 96 B8 7C 0A 7E 93 80 6A 6B 25 66 B0 (active)
Key 1: 53 B1 5A D5 D0 FD 53 8C 6F 19 5F DE BF 78 80 8E
Bev Provider 0901: Last Updated (29 May '07 11:45 AM EST)
Key 0: 6B 73 F5 77 2A D2 4B 89 58 FC 76 ED 01 08 E1 9F
Key 1: F1 69 FA E9 5F 6E 33 94 5E 28 F3 C4 99 5A 00 F5 (Active)
U cannot fix a possible 100 problems with 1 post...u need to go READ about this stuff...Use thesites listed in the "recommended reputable satellite sites" thread, depending on which receiver u have...
BTW...how can I possibly tell U "what info"...ALL info!!!!....lmao
Arrite dude, thanx for your help.
Username: Luqe
Post Number: 43
i have lost some indian channels...set, setmax and tvasia. i scanned the sattelite again...also tried just tp scanning.......they still won't come.....anyone know how to fix it?
Username: Thoronto
Post Number: 15
Thanks, I had done that... the problem I am facing is only for international channels such as Globo, that searching message keeps comming back very oftem. All the other channels are fine.
thanks again for the input (-:
Username: Vitalllliy
if idon't want to change keys can be change avtomatic or should i load same bin to make this work
Thanks
Username: Nydas
Post Number: 2757
luqman: SET SETMAX AND TVASA are on the same TP
12470 (H) on Echo 3. With the viewsats and Sonicview, you often do not get them on a blind scan first time.
You will usually succeed with the scan of the single TP as above.
Username: Happytv
Hi...I have a Pansat 3500sd. It was working fine until yesterday. I put in the new keys hoping that will make it work, however no luck. Even though autoroll was on.
I tried to turn autoroll off and enter the keys manually, still no luck. I tried default keys, autoroll off/on. Entered new keys and still no luck. I have been reading other posts. Do you think I have to reload the bin and if so, do I do a factory reset, load bin 80 and the latest bin? Can you tell me what I can do. Thanks
Username: Lklives
Post Number: 9749
bin 80 is not a TV watching bin...its a BOOT file...U have much to learn and have NOT done your homework...since U have a Pansat, go to www.future-fta.info ....to their forums and join free!...and if U do NOT, then don't bother coming back here!
Username: Joe123xyz
Post Number: 32
LK, please be patient with others, you are a good guy and we want to keep learning from you. Thanks.
Username: Happytv
LK...Thanks for pointing me in the right direction, however is your tone necessary? You can tell by the number of posts that I don't ask very many questions because I mostly read about issues. If I would of asked "what are the new keys" when clearly it was posted two messages above, I can maybe understand your tone. Nevertheless, I just asked a simple question that you probably could of answered without being condescending. I know about the bin file and maybe I confused the context. Anyone but LK...What do you suggest that I do if the current keys are not working. Should I reload the bin. (Pansat 3500sd)
Username: Nydas
Post Number: 2762
al7bar*tk has good instructions and better cautions using B80 and loading the latest BIN on top it. I think it is BIN 319 but you should check.
future-fta.info also has good Pansat section and you should look at it too.
Username: Nydas
Post Number: 2763
LK: We all know that it is early getting drunk time for most people except you. Stay out and let others help. We DO NOT need your drunken psychosis here.
Username: Luqe
Post Number: 44
Nalin, I used to get the missing channels on echo 1.2......and i did try to scan just the TP...the TP also starts updating itself if i put the channel on.......but nothing comes up.
when i scan a TP it doesn't ask me to enter any TP....so how can i scan just this TP on echo 3? pls help....
Username: Lklives
Post Number: 9759
Tom...did u come here for FTA info or to give a BS speech about "tone"?...hit the road kid!...and take the lesbo nalin with ya!
Username: Happytv
Well, I am obviously not getting any useful information from you.
Username: Lklives
Post Number: 9763
kid..U wouldn't know "useful info" if it hit U upside the head...WHICH IT HAS!
Username: Letmeon
Post Number: 146
Both cHanged this week !!!! A/R ok.....
Username: Nydas
Post Number: 2770
LK: Get OFF this thread. You are not helping anybody.
Username: Jakeinthedisco
Orlando, Fl
Usa
yeah Nalin, LK is mean..
But i got my channels to work =][its bc i needes new keys]
And yes i stil dont know difference betwen Bev and Dish, and honesly ,i dotn care LK.
Jorge thank you for posting keys =]]
Username: Nydas
Post Number: 2771
Bev is provider ID 0901 and also provider Id 0905 and 0906 for special events.
DN is proivder ID 0101.
The keys are different for each of the 4 ID listed above and each ID has two sets of keys - Key 00 and Key 01. Each Key is sixteen 2-digit numbers.
Username: Lklives
Post Number: 9802
wow...I'm really impressed with that info...hehehe...
if the kid "jake' doesn't care about the diff between Bev and DN, then why reply...unless u want to look like an "authority" and post stupid basic FTA 101 repetitive ramblings, as U did...why not do a post about chewing gum while walking!...thats more your speed!
Username: Nydas
Post Number: 2772
LK is a psychologically deranged person and you should ignore him. He does not like anybody else to be helping.
Username: Srpskkisiin
Post Number: 11
Newest Keys for DN, BEV and GlobeCST are here
http://www.jordinclub.com/forum/index.php?board=6.0
Username: Abbasusa77
is any one have new keys plz
Username: Tonytoy
Post Number: 16
Hi Nalin, you are great.
Could you please guide me with links and files so that I can recover my Pansat 2700A? Can you imagine there is only one field for Nagravision2 key either 01 or 00 and that is also only if I change it. I am talking about DN keys.
Now the receiver is not working. Please let me have all of the files that can completely fix my receiver.
Username: Tonytoy
Post Number: 17
Nalin: Please read this post in connection with my earler post, just above this one.
When I turn the receiver on, the little black screen on it shows "b-75" moving on it for a couple of seconds and then the word "on" appears on it. But when I go to move to channels, I see the message "scrambled on bad channel".
Not only that, but when I go to Nagravision2, I see only one field for key 01. When I try to switch to 01, I can't. Please suggest some solution.
Username: Tonytoy
Post Number: 18
Nalin:
Let me make corrections in the last line of my above post. "when I try to switch from key 01 to key 00 or otherwise, I can't."
Username: Gujaratichokri5
hey my name is priya and i am having problem with my echo/3iku dish network 3 channels are now working zeetv zeecinema and b4u movies so please someone help me i get all other channels liek sahara b4u music and stuff but just those 3 channels do not work:-( please help...thank you
Username: Nydas
Post Number: 2778
abbas: There are no new keys for DN. Try switching off at the back, wait for 40 seconds and switch on. If this does not work, more details are needed to get your working.
Username: Nydas
Post Number: 2779
TJ:
This will get you to the appropriate area for Pansat 2700A
http://www.future-fta.info/Forums/forumdisplay.php?f=43
This will get you the
New 2700 Loader (and factory files)
READ –READ – READ the instructions,, even though you do not need to reinstall boot 75. You may want to do it anyway.
http://www.future-fta.info/Forums/showthread.php?t=47447
This file has the loader and the factory file (bin 1.20).
You will need this loader to do the boot fix upgrade.
this is from the pansat USA website. Only use the factory file if you want to factory restore the box.
2700A loader.zip (447.4 KB)
When you have the boot 75, you should install the BIN 203
Current autoroll bug fix....
http://www.future-fta.info/Forums/showthread.php?t=49828
x-87bl_070411_b75_203_api.zip (414.1 KB)
Username: Nydas
Post Number: 2780
TJ:
You will also find that
http://www.al7bar*tk and
http:www.dssrookie.com
have similar files and instructions. You MUST read all the instructions and follow them explicitly.
You must have a null modem cable with F/F DB9 connection on it.
Username: Nydas
Post Number: 2781
Priya: Do a Blind scan to get all the channels. After that sometimes the SET,SETMAX group is missing. In that case, do a separate TP scan of 12470(h).
Best of luck.
Username: Tonytoy
Post Number: 19
Nalin:
Thanks for all these posts for me. I have the null modem cable. However, I just clicked your first link in the first post
the message there is "there are no posts in this forum".
Username: Tonytoy
Post Number: 20
Ok Nalin:
I have just found the files on the links given by you. I am going to hit the instructions and will go ahead. I will let you know soon.
Thanks.
Username: Luqe
Post Number: 45
Nalin, what should I do if the missing indian channels don't come even after the TP scan?
Username: Tonytoy
Post Number: 21
Nalin:
No progress. I think my null modem cable has a problem. When I download the files, I get the message "can't open the serial port".
Do you suggest changing the cables?
Username: Walidsm
Post Number: 16
Hi, I have a Pansat 2500A and bin 293. It was working very well but accidently, it turned off and on alone and after then I don't see even the bleu screen which normally says bad scrambled. Although it is on but I just see what we see when the reciever is off (I don't know the word in english). I checked the cable between the TV and receiver and I changed it although it is good but I still have the same problem.Also, I installed the factory bin and after then I instaleed the bin 293T but I still have the same problem. Can some one help me please???!!!!
Post Number: 12
Newest Keys for DN, BEV and GlobeCST are here 5.30
Post Number: 13
When you leave the factory bin on there, does that do anything, or is it the same? Did it turn on and off while you uploaded a bin? Explain more.
Username: Curler
Post Number: 33
Anyone have the new bev keys???
Post Number: 14
bev
86: E3567B2F6CC151FFD9424D8AD33E44C5
96: F169FAE95F6E33945E28F3C4995A00F5
for more visit forum
Username: Curler
Post Number: 34
Thank you very much, Luke.
Username: Lklives
Post Number: 9850
Keymaster 4.0
Nagra2 Keys
Bev Provider 0901: Last Updated (6 June '07 12:45 PM EST)
Key 0: E3 56 7B 2F 6C C1 51 FF D9 42 4D 8A D3 3E 44 C5 (Active)
Username: Cacalad
need new keys for dish
Username: Walidsm
Post Number: 17
I installed the factory bin and after then I installed bin 293T As a result, the reciever board is working and I see the chanels numers in the board of the receiver. But there is nothing in the TV. what I see in the TV is similar to what you see when the Pansat is off and the TV is on (just the noise). Please help!
Username: Canndy
Www.livefta.com, Www.livefta.com
Www.livefta.com
Post Number: 371
NEW KEYS UPDATED JUNE 6!
www.fta123.blogspot.com - the fastest keys on the net!
NEW KEYS!
www.livefta.com
Username: Canndy
Www.livefta.com
Post Number: 372
NEW KEYS!
www.livefta.com
Username: Baluja
Post Number: 164
Dish Keys as 6/6/2007
00: 13 F1 FD 82 96 B8 7C 0A 7E 93 80 6A 6B 25 66 B0
01: DE 60 DB 80 74 A2 AE CF 8A 9E 27 79 9D D5 43 5B
Username: K98
Post Number: 29
thanks rakesh you are the best !!!!!
Username: Too_tall
I have a pansat 2500 I cant get the espn chanels I don't know what I'm doing wrong in the sat set up.
Username: R1010
Post Number: 104
thanks rakesh
Username: Too_tall
can some one help me out in gettint the setting for espn chanel I might have the wrong setting,help!!
Username: Saw_tech_one
Post Number: 24
make sure auto roll is set on for 5 min to regain keys good luck
Username: Tonytoy
Post Number: 22
Hello Nalin:
After having gone through the scheme of steps suggested by you earlier, I am finally able to see all the channels. But once again, the DN provider id 0101 has only one key 00 available and the other 01 is not accessible.
Could you please suggest something?
Username: Lklives
Post Number: 9852
Keymaster 4.0
Nagra 2 Keys
Dish Provider 0101: Last Updated (6 June '07 8:00pm EST)
Key 1: DE 60 DB 80 74 A2 AE CF 8A 9E 27 79 9D D5 43 5B (Active)
Post Number: 15
Hi Nalin, a few days ago, I had asked a question on not having second pin for loading the keys. I did factory settings and then scanned both Echo 3 KU and Echo 7 KU but still no second pin. You suggested :"For the "second Pin" to show up in the menu, you have to scan at least one satellite. When you scan Echo 7, make sure you have it on a different DisEqC port."
My channels for both 3KU and 7KU still don't work. Can you tell me what I'm doing wrong. Should I rescan in factory settings? What port should I keep as DisEqC. You may think I am dumb, but truly, I'm not so tech savvy in this matter....please help...
Username: Nydas
Post Number: 2783
TJ: Did you unzip the files before attempting to load?
Username: Nydas
Post Number: 2784
TJ: I answered a previous question - ignore above
Username: Nydas
Post Number: 2785
Echo 3 and Echo 7 can only be scanned using TWO SEPARATE dishes. You have to align the Dishes for 119W (echo 7) and Echo 3 (61.5W). I usually recommend using Port 1 for 119W, Port 2 for 110W and Port 4 for Echo 3.
Post Number: 17
Nalin, my dish is aligned for 119W (echo 7) and Echo 3 (61.5W). However, even after rescanning, the channels don't come nor does the Second pin show in Channel Edit screen of Menu. DisEqCM for Echo 7KU is 2 and for Echo 3KU is 3
Username: Ameena
Ottawa, Ontario
Hi,I need help as I always enter the keys which are active from the web ,but never get the picture.Please help me as it is becoming a regular problem for us to take the receiver every time and get it fixed.An early response will help me
Username: Ameena
Ottawa, Ontario
Hi I need to know the whole procedure for entering the keys in the dish.As I entered the keys but still didnot get the oicture
Username: Jowhar
Post Number: 89
Amina mike sure you put the wright keys. abaayo.
Username: Muzz
Toronto, Ontario
anyone have new key i tried to put in active key
but did not work help me please
Username: Lklives
Post Number: 9863
what a group here...lmao...
1 guy, amina, wants to be spoon fed the entire hobby in 1 post...and the other "muzz" cannot enter keys correctly..bunch of lazy non reading newbies...U ONLY get out of this hobby what U put into it!
Username: Tonytoy
Post Number: 23
LK: Good for you, because of these newbies, you get some mud to throw upon. That is the real food for a person like you.
But it is also good for people like NALIN NYDA, because she wants to help new people whole heartedly and respectfully.
BTW, learn to be respectful and you will see that your life will be very easy for you.
Username: Cacalad
new keys please anyone
Username: Johnkapo
New Keys pls. for 7th June
Username: Bertoro
Toronto, Ontario
Post Number: 561
38 8A 36 42 7A 92 AF 15 4F A3 CB 1F 69 73 99 44
active 00
Username: Johnkapo
Thanks ferenck massella have nice day
Username: Bertoro
Toronto, Ontario
Post Number: 563
np
Username: Orangesmoothee
are these keys for key 0 or key 1, and are they for dish?
Username: Achilles
Where do you put that? Dish 0101. Key 0 or Key 1?
Or Bev 0901. Key 0 or Key 1?
Username: Achilles
Nevermind, it's Dish 0101 for Key 0
Username: Sukhi_brampton
thanks melissa
oops masssella
Username: Bertoro
Toronto, Ontario
Post Number: 566
np mas...
oopss sam.....
just kidding...np
im still not following, which line has changed for the dish
Username: Tamak
Torrance, CA
U.S.A.
hi guys
can someone please advise all the code
i mess it up.
Thanks
Username: Tamak
Torrance, CA
U.S.A.
for D NET
can someone post up the keys for the dishes
Username: Vhd
this key not working: bad or scramble
Username: Lklives
Post Number: 9864
TJ...go fukck yourself, if U don't like what I say or constructive critisism..U don't come to my neighborhood and start bashing me dude!...I will eat u up!...try me if U want!...either STFU or don't post azzhole!...your life will be short here!
Username: Hoosier_daddy
Post Number: 91
more rhetoric from the wee man....your song gets old....get a life or at least some help....
Now you bash me make some threats etc..etc...etc...but I won't respond....
have a nice day!
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through June 07, 2007 [ « Previous ] [ Next » ]
