Home > Message Board > Home Video > HDTV Reception > I need a MM or LM antenna
Author Thread: I need a MM or LM antenna
Username: Pukka
Post Number: 161
i need to buy a medium multidirectional or large multidirectional antenna and would like to hear some suggestion on where to buy, and model/brand suggestions too, if somebody could recommend a site or store.
thnx
Relevant Product Info
Username: John_s
Columbus, Ohio
US
Post Number: 1625
Start with
http://www.antennaweb.org/aw/welcome.aspx
Username: Mvanmeter
KY
Post Number: 118
once you get to "medium" or "large" TV antennas they are rarely multi-directional (regardless of what the advertising hype may be). To get the gain and range a medium/large antenna needs they are all uni-directional with all their gain forward. There are some cases with side-lopes where there is some gain at certain angles to the main antenna, but that can rarely be counted on. If you truly need a high gain antenna and the stations are in multiple directions, you need a rotor.
as mentioned, please post your zip code so folks on the forum can respond with good suggestions.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > HDTV Reception > I need a MM or LM antenna [ « Previous ] [ Next » ]
