Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through May 25, 2007 > Sony 40" LCD making snapping, clickin...
Author Thread: Sony 40" LCD making snapping, clicking sounds
Username: Gm1217
Bought a KDL-V402500 about two months ago. Since then, I have noticed a series of clicking sounds that come from the rear of the unit which seem to lessen in recurrence after the tv is on for an extended period.
Does anyone know if this is normal?
Username: God_11
Post Number: 11
My Samsung makes clicking sounds from back. I had a tech come out and said the tv was fine. I think it's from condensing from hot/cold weather. It seems to have lessen.
Username: John_s
Columbus, Ohio
US
Post Number: 1585
I don't know if this applies to LCDs, but with plasmas as the barometric pressure decreases there is less pressure against the two outer glass plates which can result in audible vibration.
Username: Rysa3
Houston, Texas
Post Number: 167
Its just the plastic adjusting to a temperature change most of the time.
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through May 25, 2007 > Sony 40" LCD making snapping, clickin... [ « Previous ] [ Next » ]
