Home > Message Board > Home Video > DVD Players > Archive through July 23, 2007 > Techical Help
Author Thread: Techical Help
Username: Tmac57
Sorry if this has been asked somewhere else. I recently purchased a DVD/VCR combo. When I went to install it, I realized there is no coxial cable connector on it. There are plenty of ports, but no cable connection- at least I don't see it. I want to run my cable through my DVD/VCR then into my TV so I can tape things on the VCR as well as use the DVD player. I'm lost. Anyone with any insight/help is much appreciated.
Username: Sunlover331
how do i hook up a dvd recorder/player to a tv with a built in dvd player only, all i want to do is record to dvd unit as the player is built into tv/ i have no cable box, only direct cable to tv
Username: Christad
Try to make a triple connection: DVD recorder --> your PC --> TV.
And find any useful recording softwares that could be found on google :-) Good Luck
Free Download
http://www.vdownload.org/
Username: Tapeman
New York City in-HD, NY
Post Number: 1180
Trey
What brand is your combo?
DVD players don't use Coaxial output, it should have RCA (Yellow/White/Red)
But they should have Coaxial input
Mary
Yo won't be able to record from DVD player if it doesn't have RCA (Y/W/R) output cables
But you can only record from coaxial cable to DVD recorder. can't use PC
Home > Message Board > Home Video > DVD Players > Archive through July 23, 2007 > Techical Help [ « Previous ] [ Next » ]
