Thread: My HDTV not displaying High Definition for my XBox! |
New member Username: Gregquinn
Post Number: 1 Registered: Apr-07
| Posted on Friday, April 27, 2007 - 06:31 am: |
I've just gone out and bought an XBox 360 premium. I have plugged it in and selected the HDTV option switch on the cable. However when I try to change the settings to 720p or 1080i, my screen just goes blank and then returns back to the default 480. My TV is a Samsung 42" Rear Projection that is "1080i Ready". So why does it go blank when I change the setting? Help, this is very frustrating! Thanks |
New member Username: Angie8220
Post Number: 2 Registered: Nov-07
| Posted on Sunday, November 11, 2007 - 05:08 am: |
we are having the same problem with the samung and xbox 360 except know the tv dosent work |
Post Number: 2 Registered: Apr-07
| Posted on Monday, November 12, 2007 - 11:43 am: |
Hi Angela, It looks like the problem was the Samsung TV could display 1080i and 720p, but only at a refresh rate of 50hz. The Xbox outputs to those resolutions at 60hz, thus the TV can't display it. Only thing you can do is try doing all the updates for the Xbox and hope something there gives you more options. |
Gold Member Username: Donnie1973
Post Number: 1843 Registered: May-06
| Posted on Sunday, November 18, 2007 - 12:55 am: |
i think u have to set it up in the control panel of the xbox |
Silver Member Username: Mrbass
Long beach,
California
United state
Post Number: 147 Registered: Feb-06
| Posted on Friday, January 11, 2008 - 09:37 am: |
ya because your not using component nor hdmi, |
New member Username: Hotmilk22
Post Number: 2 Registered: Jul-09
| Posted on Friday, July 24, 2009 - 06:18 am: |
I tried Aiseesoft iPhone Ringtone Maker, it is really very easy to use and powerful, and it also have a Mac version, which is Aiseesoft iPhone Ringtone Maker for Mac. |
