Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through May 25, 2007 > Digital Music on Cable
Author Thread: Digital Music on Cable
Username: Dscrobe
Reading, PA
Post Number: 28
I have a plasma tv with a tuner card and recently discovered that there are around 50 channels of various commercial free music. I believe these are digital channels. I was wondering how I could take advantage of this music and route it to my home audio system which is in a different area of the house and there is a cable jack nearby. Do I have to buy a whole new TV for the sake of switching these channels?
Username: John_s
Columbus, Ohio
US
Post Number: 1522
Daniel, you have three choices:
1) Buy another QAM tuner equipped TV.
2) Rent a digital cable box (HD not necessary) and use its digital audio output if your music system has a digital audio input. Otherwise you can use the R/L analog output from the cable box to feed into your audio system.
3) Buy a separate QAM equipped tuner, run your cable into it and use its audio outputs into your music system.
http://cgi.ebay.com/Samsung-SIR-T451-High-Definition-Terrestrial-Tuner_W0QQitemZ 260102179656QQcmdZViewItem
Username: Dscrobe
Reading, PA
Post Number: 30
Thanks John!
Home > Message Board > Home Video > Plasma & LCD Flat Panel TVs > Archive through May 25, 2007 > Digital Music on Cable [ « Previous ] [ Next » ]
