Thread: Plasma TV (VIZIO 42" Plasma) HUMS, how to reduce/eliminate? |
New member Username: Adam315
Raleigh,
NC
Post Number: 1 Registered: Apr-07
| Posted on Sunday, April 15, 2007 - 08:24 pm: |
I recently purcahsed a Vizio 42" Plasma YV from costco for $1000.00 . When there is no volume or low volume you can hear a humming noise coming from the center of the screen. The noise can be heard from about 15 feet away, so its more then a whisper.The humming sound can not be heard when the TV is at normal volume levels except when there is silence or a pause in the action.I am not sure sure if this is the fan location or not, but can I elminate or reduce the sound? The noise drives me crazy! Do the LCDs screen also have the fans,,,do they hum? Does your plasma produce a humming noise? Will a power conditoner help to elminate the sound? Thanks for any help. Any suggestions are welcome! |
Bronze Member Username: Frank1203
Philadelphia, PA
Post Number: 71 Registered: Mar-06
| Posted on Monday, April 16, 2007 - 06:28 am: |
Adam - I have a 1 year old LG Plasma with pretty much the same issue that you are experiencing. I also posted in this forum, but received no replies. One thing I can tell you is that I also have the Plasma plugged into a Furman Power conditioner that is located behind the mounted Plasma and I still get the humming / buzzing sound. Actually, I thought the humming was coming from the Furman, but I am now pretty certain its coming from the TV. If you get any ideas about how to correct this - let me know! |
New member Username: Techme
MIAMI,
FL
Post Number: 2 Registered: May-07
| Posted on Wednesday, May 09, 2007 - 12:38 am: |
YOU NEED TO REPLACE THE DIGITAL NOISE FILTER |
MIAMI,
FL
Post Number: 3 Registered: May-07
| Posted on Wednesday, May 09, 2007 - 11:43 am: |
YOU NEED TO CHANGE SOUND BOARD ON UNIT. |
