Thread: Solid lock-up on DMR-E85H |
New member Username: M_zenner
CA
Post Number: 1 Registered: Apr-07
| Posted on Saturday, April 14, 2007 - 05:00 pm: |
Any help would be appreciated. Record late show last night on 61 (sci-fi), but this morning, only the channel displayed, and can’t access any other commands, other than power off, which it doesn’t. Did the holding down power button on unit for the 10 seconds, does the self-check, but still ignores remote, other than power. Tried to determine if hard drive is dead, but when I switched to a DVD-RAM I had, it’s stuck looking for a disk, after I removed it from the drive, and fails to switch back to the hard drive. I have no back-up unit, to switch hard drives, other than try it on a PC. Any ideas what I can do? |
Relevant Product Info
Silver Member Username: Formerly_fx
Dallas,
Tx
Post Number: 272 Registered: Mar-06
| Posted on Tuesday, April 17, 2007 - 05:32 pm: |
Somewhere at home I have all the reset procedures for this unit. I will try to find them and post back an alternative to holding down the power button. IIRC, there is one where you hold the eject disc buitton and the power button at the same time, you might try this for now. xvxvxvx |
New member Username: Fondren
Shady Shores,
Tx
Usa
Post Number: 6 Registered: Dec-06
| Posted on Tuesday, April 01, 2008 - 07:29 pm: |
I also have a DMR E85H and mine also locked up last night. It says "Please Wait", and I have tried to turn it off using the power button for 10 sec. and also tried to unplug and let set for a while. No luck. Still come back up with same message. I don't hear the hard drive running, but I don't know if I could have heard it before. I have had really good service from this unit until now. Any help on how to clear up this problem would be appreciated. Does anyone have the master reset sequence? |
