Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2004 > Diplexers and HDTV
Author Thread: Diplexers and HDTV
Can you use a diplexer with a triple LNB dish on an HDTV system?
Carlton
Yes you can.
But you need a high bandwidth diplexer. I bought mine from Comp USA believe it or not and it works great. Do not buy the cheap ones fron Radio Shack they will be a waste of time. The signal will be lost.
Home > Message Board > Home Video > Satellite TV > Archive through June 14, 2004 > Diplexers and HDTV [ « Previous ] [ Next » ]
