Home > Message Board > Home Video > DVD Players > Archive through July 23, 2007 > I made a DVD disc, but canĄ¯t be play...
Author Thread: I made a DVD disc, but canĄ¯t be played in my Sumsung player
Username: Kendybech
I made a DVD using Xilisoft DVD Creator, it plays very well in my computer, but failed when inserted in my Samsung player. At the very start, I thought itĄ¯s the problem with burning, and I made a DVD Folder using Xilisoft DVD Creator, and then burn into Video-DVD using Nero7, but the problem still occurs. What I use is DVD+RW disc, who can let me know whatĄ¯s up. Thanks
Username: Alright_boy
Post Number: 154
Check the specs on the Samsung. Not all DVD players will play DVD+R/RW. In my experience, DVD-R is the most compatible format.
Username: Itsu
it's not the problem of your software.
As I know, some Samsung player doesnĄ¯t support DVD+RW disc, u can visit http://www.videohelp.com/dvdplayers.php to find out the disc type your player supported.
Username: Kendybech
Thanks very much!
Indeed, I found that my Samsung DVD-V8500 doesnĄ¯t support DVD+RW disc. This time I got a DVD+R disc, and made a DVD using Xilisoft DVD Creator again, it can work now.
Home > Message Board > Home Video > DVD Players > Archive through July 23, 2007 > I made a DVD disc, but canĄ¯t be play... [ « Previous ] [ Next » ]
