Thread: DVD player thru RF modulator is B/W w/ green/purple. |
New member Username: Sunnyb
Post Number: 1 Registered: Apr-07
| Posted on Monday, April 09, 2007 - 09:07 pm: |
I have an older TV that I like. To hook up a DVD player, I got an RF modulator and hooked up the connections per instructions today. The picture from any played DVD shows mostly black/white with bands of overlaying purple and green. Any suggestions? Thanks a lot, Sunny |
New member Username: Zipidachimp
Surrey,
B.c.
Post Number: 3 Registered: Apr-07
| Posted on Thursday, April 12, 2007 - 02:21 pm: |
I had the same problem and solved it (?) by using a different modulator. radio shack didn't work, philips worked ok. walmart has philips. good luck. |
| Posted on Thursday, April 12, 2007 - 03:03 pm: |
Thanks for this insight, Zipi. That possibility had not occurred to me. The one I have hooked up is indeed a Radio Shack model. Thanks, Sunny |
Surrey,
B.c.
Post Number: 4 Registered: Apr-07
| Posted on Thursday, April 12, 2007 - 03:19 pm: |
philips make more than one model. the one I use is the same general shape as the radio shack, but they also have a fancier model. the results are not always perfect, but watchable. I'll be the last guy to buy a new crt tv. lol looking at a 26" widescreen toshiba crt. |
Surrey,
B.c.
Post Number: 5 Registered: Apr-07
| Posted on Thursday, April 12, 2007 - 05:23 pm: |
addenda: fyi: rca and electrohome also have rf modulators. |
