Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through March 29, 2007
Author Thread: Archive through March 29, 2007
Username: Michelle27272
Post Number: 18
any new keys for dish?
Username: 310011515
Scarborough, Ontario
I NEED KEYS FOR DISH!!!!!!!!!}
Username: Baluja
Post Number: 162
Dish Provider 0101: Last Updated (March 22 3:30pm EST)
Key 0: B8 46 82 2D 29 B6 25 87 8C B1 63 15 24 65 0D 8A (Active)
Key 1: B3 88 CD 60 95 96 2C 11 C0 B1 15 D0 78 65 9A 10
Username: Too_tall
any new keys for DN yet?
Post Number: 19
whats up with the keys for dish the key ripper not working?
Username: Baluja
Post Number: 163
Username: K98
Post Number: 24
thanks rakesh ---cotton coots -k98
Username: K98
Post Number: 25
Username: Too_tall
thanks for the keys.
Username: K98
Post Number: 26
hey jeff rakesh has the numbers 4 d.n.
Username: Canndy
Www.livefta.com, Www.livefta.com
Www.livefta.com
Post Number: 356
www.fta123.blogspot.com
Username: Srpskkisiin
I was out for 3 months, since December. What bins work on 2700a? Any changes?
I was out for 3 months, since December. What bins work on 2700a? Any changes? Does anybody have keys for Globecast?
Username: 310011515
Thanks for the keys Rakesh
Username: Yahelwe
thanks a lot for the keys
Username: Saqeeb90
Post Number: 41
keys doesn't work fwko so no thanks
Username: Jerkisland
Guys help needed.
I have Pansat 3500SD.I have two dishes, one pointing east and another one west.
When I connect directly from the Dish1 to receiever I get all the channels from 119 and 110. When I connect directly from Dish2 I get all the channels from 61.5.
Problem: In order to get all the channels from Dish1 and Dish2 together,I connected through a switch in the following way, I connect the dish1 output to LNB1 on the switch and output of dish2 to LNB 2 on the switch and output of the switch to the receiver. Changed the DISEQ to 1 in antenna settings for 119 and 110 and changed the DISEQ to 2 for 61.5.
Now I get the channels for 119 and 61.5 but not for 110. Can someone please tell me what I am doing wrong here.
Thanks in Advance
Username: Le74nguyen
Perris, Ca
Usa
Post Number: 112
NEED NEW KEY PLEASE!!!!
ALL THESE KEY Dish Provider 0101: NOT WORKING
Key 0: B8 46 82 2D 29 B6 25 87 8C B1 63 15 24 65 0D 8A AGAIN NOT WORKING
Key 1: B3 88 CD 60 95 96 2C 11 C0 B1 15 D0 78 65 9A 10---------IS NOT WORK:
Username: Asharfi
Post Number: 630
Linda,
Those keys are working. Turn OFF your receiver from the back switch and wait 10 seconds. Then, turn it back ON and check if that solves your problem.
Username: Batbuzz
Katy, Texas
Post Number: 8
Nalin TY for the links, the only problem I know have is that I save the zip files to my desktop in a folder, but they will not list a BIN to load???? Still looking to get this thing working.
Username: Rated08
Post Number: 10
These keys aren't working for me either?
Username: Nydas
Post Number: 2201
Batbuzz: Zip file containing a loader will unzip to be a .exe file when extracted using Winzip available from
http://www. winzip.com
A BIN file will unzip and the extracted file will be a .bin or .api file.
Using "my computer" or Window explorer on your computer, create a folder with a name you would like such as "current". Unzip the files in that folder using winzip software.
Double click on the .exe loader file to start the process.
It seems you may not have sufficient knowledge of fiel names and execution and you should get computer expertise help. The current new BIN for 2700A is a complicated process.
New Keys!
Username: Outback901
Post Number: 7
thank you keys works
Username: Linkherself
HELLO EVERYONE,
I AM VERY NEW TO THIS SAT SET-UP. I HAVE THE KEYS AS FOLLOWS:
D!SH
00: B8 46 82 2D 29 B6 25 87 8C B1 63 15 24 65 0D 8A
01: B3 88 CD 60 95 96 2C 11 C0 B1 15 D0 78 65 9A 10
HOWEVER, WHEN ENTERING THE CODES THERE ARE NOT ENOUGH SPACES TO FIT ALL THE DIGITS.
I'VE ALSO SEEN THE CODES SHOWN AS A SET OF TWO LIKE THIS:
00:B8 46 82 2D 29 B6 25 87
01:8C B1 63 15 24 65 0D 8A
00: B3 88 CD 60 95 96 2C 11
01: C0 B1 15 D0 78 65 9A 10
ALSO, SOME PEOPLE SAY TO USE PROVIDER CODE 0101 AND SOME SAY TO JUST SCROLL UNTIL IT SHOW DN AT THE TOP, BUT IT SAYS 00 01. DOES THIS MATTER?
I AM DEFINTIELY A NEWBIE AND HAVE YET TO PICK UP THE BASICS AND LINGO. I MANAGED TO GET INSTRUCTIONS ON WHERE, HOW TO ENTER THE CODES, AND THE CODES THEMSELVES, BUT I AM STILL PREPLEXED AS THIS IS ALL LIKE READING A FOREIGN LANGUAGE.
ANY HELP WOULD BE MORE THAN APPRECIATED. I USE A FORTEC IF THAT MAKES A DIFFERENCE. THANK YOU SO MUCH.
Username: Nydas
Post Number: 2202
When people mention Keys in this forum, they usually mean Nagaravision 2 keys - a form of encryption amongst a dozen or so encryption techniques.
Under Nagravision 2 you can have Provider IDs
0101 for DN
0901 for BEV
0905 for BEV - some special events
0906 for BEV - some special events
C101 for Globecast.
Each of the above providers have two sets of Keys. They are usually mentioned as
Key 00 or 86 (16 two digit hex numbers)
Key 01 or 96 (16 two digit hex numbers)
Key 00 is split up into two sections of 8 two digit numbers. In some computers these two sections are called 10 and 11
Same with Key 01 and named in some computers as 20 and 21.
The ID 0001 probably refers to old DN ID of Nagravision 1, but I am not sure of this. Nagravision 1 is no longer used for encryption having been replaced by Nagravision 2.
Username: Curler
Post Number: 25
new keys anyone??
Username: Lklives
Post Number: 8382
right here ALWAYS!
http://www.tvkeyz.com/
Username: Sirroy
Edmonton, Alberta
Post Number: 21
Hello! Does anyone have the new Bev keys. Thank you.
Username: Lklives
Post Number: 8383
Direct links to current Dishnet and Bev keys:
www.tvkeyz.com/
www.dss-keys.com/
www.filez.us/km3/keys.shtml
Username: Curler
Post Number: 26
Bell ExpressVu (Last Update: 2007/03/23 8:06 AM PDT)
00: 32 3E B6 B9 51 9A 97 A2 0E 9C C6 C3 E1 D9 62 FE
01: 83 C5 FC 87 4F 48 2E E6 FF AA 86 DD 9C 84 06 71
Username: Lklives
Post Number: 8386
Nagra2 Keys...For ALL receivers!
Bev Provider 0901: Last Updated (March 23 11:04am EST)
Key 0: 32 3E B6 B9 51 9A 97 A2 0E 9C C6 C3 E1 D9 62 FE (Active)
Key 1: 83 C5 FC 87 4F 48 2E E6 FF AA 86 DD 9C 84 06 71
Username: Bizman
new keys please
Username: 310011515
HI! how are you people?
Username: Rated08
Post Number: 11
hey LK, these aren't working for me?
Username: Rated08
Post Number: 12
the keys
Username: Rated08
Post Number: 13
The last row in my dn keys(nagra) are the same as the 01 row is this correct?
these* co b1 15 do 78 65 9a 10
Username: Bizman
Can anybody send me link for fortecstar lifetime ultra loader & bin file
Username: Ustaad_hc
Post Number: 191
try this for fortec.......
www*dsstester * com/files.php?cat=16
Username: Lklives
Post Number: 8391
Blacklist updater loader v1.4 and bin 292T (keys will autoroll, but may have freezing , rebooting etc issues) or 290T (shut off autoroll & manually input keys)..
http://www.dsscommunity.c*om/forums/viewforum.php?f=31
Username: Bizman
thank you!!!!
Username: Tupas1
Post Number: 18
New keys for nagra 2???
because this is not working " Nagra2 Keys...For ALL receivers!
Username: Lklives
Post Number: 8397
Pilot error....crash and burn...those keys are fine and work for the rest of the world..
Username: Tupas1
Post Number: 19
what's a problem LK?? i hve lifetime ultra receiver and getting error with above keys since yesterday night around 10PM.
Username: Andreasmith
Post Number: 9
Can any of you let me know where i can get the channel master list for 110 & 119
Rg
Andy
Username: Lklives
Post Number: 8408
All these sites ALWAYS have the latest files,CHANNEL LISTS, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released..
Many of these specialize in particular FTA receivers as noted next to their links..USE those for your particular receiver manufacturer..
If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community for many years now...
Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information
So again I highly recommend using ANY of these sites in this first post!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from a reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby!
Final Solution Free To Air:
http://www.fsfta.com/index.php (All receivers)
Future FTA - Blacklist's Site:
http://www.future-fta.info/forum/index.php (Pansat)
Curious Contraptions Community:
http://www.curious-contraptions.com/forums/ (All receivers)
FTA Tech - Free To Air Community:
http://www.ftatech.net/forums/ (All receivers)
DVB Spider - Free To Air Technology:
http://dvbspider.tk/ (Spacestar)
Free To Air:
http://www.f2atv.com/ (C00LSAT and All receivers)
DSS Newbies:
http://www.dss-newbies.net/forums/ (All receivers)
DSS Evolution:
http://www.dssevolution.com/ (All receivers)
DSS Rookie:
http://www.dssrookie.com/forums/ (All receivers)
Global Airway Technology Specialists:
http://www.gat-s.biz/forum/index.php (All Receivers)
Total FTA
http://www.totalfta.com (VIEWSAT and All receivers)
FTA Bins
www.ftabins.net (VORTEX and All receivers)
Cut and Paste these into your browser:
REMOVE the * in links below: These are the largest sites,and therefore Ecoustics has blocked their names and active links..
http://forums.dsstester.c*om/ (All receivers)
http://www.dsscommunity.c*om/forums/ (All Receivers)
http://www.al7bar.t*k/ (All receivers)
http://www.dsscentral.n*et/ (All Receivers)
This site was free but now has a small fee for files, but is the best site for Clone receivers in general..
http://www.pantecf2a.com/support (Pantecs,all clones and all receivers)
File Share Site - No Registration Required:
Good for gettting Original factory firmware:
http://www.ftacentral.c*om/ (All receivers)
Satellite Finders (Look Angle Calculators)
http://www.arachnoid.com/satfinder (Dish 500 support)
http://www.satellitenut.com/calculators/SatelliteHeading.html
http://www.hollsco.com/Products/SatCalc/
http://www3.telus.net/rampage/skew.htm (Dish 500 support)
http://www.remotesat.com/lookangle.htm
Satellite Charts
For information on all satellites and channels they offer
http://www.lyngsat.c*om/america.html
http://www.satcodx.com/
Best site for DISHNET info, channels, transponders and changes etc..
http://ekb.dbstalk.com/dishlist.htm
www.tvkeyz.com/
www.dss-keys.com/
Username: Rajhans
Post Number: 26
Hey LK,
Is Cricket coming on BVU? or not ....please help I want to see Cricket..Thanks
Username: Rajhans
Post Number: 27
Username: Vaderpapp
bev keys plz
Username: Lklives
Post Number: 8411
look up ^...and read them
Username: Khowell
new nagra2 keys plz? went out at 4:30ish... need leafs game haha
Username: Gophone
Post Number: 10
I am in South Florida. My dish is pointing at 110 and 119. What other birds can I pickup without moving the dish?
Username: Lklives
Post Number: 8418
spice...NOTHING!...U must always move the dish to get new satellites....LMAO...and U must have a LNB on the dish for EACH satellite U want too!...s
kevin...can't U see the links above directly to the latest keys?...use them!...and the keys haven't changed today!
All U people need to start READING right in front of U or U will never learn this!
Username: Gophone
Post Number: 11
my dish has a free LNB on it. That's why I was asking. I have another dish doing collecting dust. Any interesting birds I should point it to?
Username: Nehal_3278
C, D
C
Post Number: 13
bev keys
Username: Nydas
Post Number: 2209
The following information was obtained from TVKEYZ.com
Dish Network (Last Update: 2007/03/22 12:27 PM PDT)
86: B8 46 82 2D 29 B6 25 87 8C B1 63 15 24 65 0D 8A
96: B3 88 CD 60 95 96 2C 11 C0 B1 15 D0 78 65 9A 10
Bell ExpressVu (Last Update: 2007/03/24 7:18 PM PDT)
86: 32 3E B6 B9 51 9A 97 A2 0E 9C C6 C3 E1 D9 62 FE
96: 10 23 E2 85 66 3D 07 47 DF 70 4B BD BF E5 C5 69
Bell ExpressVu 0905 (Last Update: 2007/03/15 1:01 AM PST)
06: B7 2F 03 35 70 4A CD B0 6D 43 33 59 92 E2 1D F3
46: D5 51 BA FE 58 50 BE 61 A4 BD 09 F3 54 4F C5 FC
Bell ExpressVu 0906 (Last Update: 2007/03/17 1:32 PM PST)
06: 8D 1A 1C F4 2C B9 7F 85 38 65 D6 7A 5D 59 5D 88
46: 11 FE 27 1D 89 9E D3 B4 DB 8E CB C8 10 D3 E7 F7
Username: Anelie2006
Saint luuu, Mo
Us
hey .. im having some weird problems with my bev.. this is whats going on im watching t.v then the pic frezzes and it says scrambeld or bad chanel i restart my reciver it comes back sometimes but on other times i have to wait few minutes its sucks expesily when you watching a movie and it just goes away plzz helpppp ..nd one more question how can i get epg on bev like all the time sometimes it comes but not ofton 8) thanxxxx in advance}
Saint luuu, Mo
Us
Post Number: 7
Raj Hans criket is on bev i seen it few chanels if i fix my ill let you know the chanels
Username: Dude123
Post Number: 968
well can you tell us more about your receiver and the bin fiile that is loaded onto it? you might be using an autoroll bin file which downloads the key on the receiver automatically, thats probably why you have to wait for the picture to come while its downloading the key on it.
Saint luuu, Mo
Us
Post Number: 8
no sir the bin i use is from september it does not have a autoroll on it i have a pansat2700 i got it last year when the bin file was missing the problem is only on bev but on dish network it seems to work fine ... plz help 8-)
Username: Dude123
Post Number: 969
well, you have an old bin installed on to you receiver. i would suggest you go ahead and download the B-75 upgrade, and then flash it with bin 201, it seems to have got rid of most of the bugs.
Saint luuu, Mo
Us
Post Number: 9
eheh yes sir but i dont know how my computer does suport the cable and i dont know any one who can help me and what do you mean by flash it with bin 201 ...
Username: Dude123
Post Number: 970
Well i think you need to do alot of reading first. go to future-fta.com which is the official site for Pansat supported by Black List (pansat coder) so i would read first and you need null cable to attach your receiver to the computer, easily found in any electronic shops, i would try radio shack first. and download the upgrade kit from the site and it has step by step instructions on how to upgrade and download the new files.
Good Luck!!!
P.S by flashing i meant to download the new bin file on to the receiver
Username: Nydas
Post Number: 2219
ANELIE: You have a receiver which has a very old piece of essential software. Fortunately it is upgradable. Go to the Pansat semi-official site and read up on it. For Pansat 2700A, the lastest is B75 boot and 201 BIN.
I guess you have about 2-3 hours of reading to do, before you can start doing the right thing to get going.
Best of luck.
Username: Nydas
Post Number: 2220
Sorry, The ONE. I didn't know you were about to post.
Saint luuu, Mo
Us
Post Number: 10
thanx the one you G like a husseler on the corner selling you upgrades
Saint luuu, Mo
Us
Post Number: 11
P.S that means you helpt me allot
Username: Dude123
Post Number: 973
lol, my pleasure Anelie
Username: Dude123
Post Number: 974
No probs Nalin, as long as new users and getting helped.
Username: Rated08
Post Number: 14
my friend just uploaded a new bin with auto roll, most channels are breaking up real bad. Some are ok, what's wrong? thanks
Username: Lklives
Post Number: 8440
weather....
cable/connections...
too long of cable run..
no clear line of sight...
switch going bad....
LNB going bad...
poor dish alignment...
bad bin...
corrupted memory in receiver...
lack of FTA knowlege
U pick one...anybody else would be guessing!
Username: Dude123
Post Number: 978
bump!
Username: Nydas
Post Number: 2225
Johnny Knoxville: For a start, can you post the details of his receiver, and the current BIN he has loaded?
Username: Curler
Post Number: 27
Bell ExpressVu (Last Update: 2007/03/26 7:02 AM PDT)
00: DE 79 1D 1C EF 25 3C 84 D6 04 F1 DC 6D 3F 4C 41
01: 10 23 E2 85 66 3D 07 47 DF 70 4B BD BF E5 C5 69
Username: Jpz
MTL, QC
CAnada
Post Number: 185
thanks for the keys !!!!
Here you will find the NEW KEYS as of today!
Username: Rated08
Post Number: 15
i have a platinum view sat, not sure on the bin?
Username: Darkk
Post Number: 11
New keys please?
Username: Lklives
Post Number: 8458
shazil...U need to READ before U ask!...this is posted here 1000 times!
www.tvkeyz.com/
www.dss-keys.com/
Username: Curler
Post Number: 28
Bell ExpressVu (Last Update: 2007/03/27 7:48 AM PDT)
86: DE 79 1D 1C EF 25 3C 84 D6 04 F1 DC 6D 3F 4C 41
96: A7 2F 59 29 B1 9C 3F 14 71 92 8A 94 84 FB 0C C2
Username: Nydas
Post Number: 2250
LK: STOP YOUR BULLYING.
This is a Keys thread and BEV keys have changed today. If you can't reply properly, do not reply.
D F: Thanks for the keys. Please keep it up.
Username: Lklives
Post Number: 8468
nalin go fukc yourself!...U cheap ignorant hoar!
Username: Rated08
Post Number: 16
LK i think it's my cable from the sat. to the back of my receiver. The part that goes into the receiver looks all jacked up!
Username: Nydas
Post Number: 2252
LK: STOP YOUR FOUL LANGUAGE AND GO AND SEE A PSYCHIATRIST.
YOU ARE NOT WANTED IN THIS THREAD.
Username: Nydas
Post Number: 2253
Johnny Knoxville : The following are the currently active Viewsat threads. I would request you to go there and get your help from LK and others.
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/340310
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/338728
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?2/338799
Username: Lklives
Post Number: 8469
nalin...myself, Johnny and everybody else here can use this thread anytime they want...U don't have exclusive rights to anything here, except being the biggest azzhole here!
BTW...I'm beginning to believe that U are really not just a ignorant hoar here but have other motives here..especially when U aligned with every troublemaker thats ever been here..are U a DN, Bev, or law official?...that is a direct question to you!
Username: Nydas
Post Number: 2254
LK: You WILL NOT come to highjack this thread.
NOW GET OUT OF THIS THREAD.
You have insulted hundreds of posters when they seek help in the wrong thread. Now take your own advice and start a new thread to give this person whatever advice you may want to give him. I have already pointed out three thread appropriate to his needs.
So, YOU LK - YOU STAY OUT OF THIS THREAD.
Username: Rith
Post Number: 15
Lk, Do you have any information on a Bin for the Coolsat8000HD
Thanks in advance
Username: Lklives
Post Number: 8477
nalin...I asked U a direct question which U refused to answer ( I probabaly hit the nail on the head!)...she's with the "authorities" and refuses to answer...and again , U have NO exclusive rights or powers here! ...U are NOTHING here!
Coo*lsat 8000 bins, softcam, loader etc..
http://www.dsstester. com/files.php?cat=18
nalin is a hoar!...LMAO
Username: Lklives
Post Number: 8478
Best place for Coo*lsat info and files..
http://forums.f2atv.com/forumdisplay.php?f=638
and there is a new Cool*sat 8000 full package kit released today..
http://forums.f2atv.com/showthread.php?t=109912
CS8000HD Full package fix 03-28-2007
-. CS8000HD-11160F.sgn : patch sw
-. CS8000HD-11169A.sgn : factory sw
-. Clear_SW : Clean Software
From now on if you wants to upload the factory bin file to your receivers which has a loaded patch software on it or vice versa, we recommend you load this "Clean_sw" using upgrade loader.
Warning: Use at your own risk
clear_sw_hd_.zip (147 Bytes, 8 views)
Username: Thechiz2
Mars, Ur anis
Mine
Post Number: 176
u go LK
Username: Jpz
MTL, QC
CAnada
Post Number: 186
hi all
Newest keys of today here!
Username: Lklives
Post Number: 8483
Bell ExpressVu (Last Update: 28Mar07 10:01 AM EST)
Key0: 91 9D 87 14 27 3E 28 EA 41 47 BE 82 E8 15 9A 60 (Active)
Key1: A7 2F 59 29 B1 9C 3F 14 71 92 8A 94 84 FB 0C C2
Username: Dzejlana
new keys please those dont work i have those in and it still says waiting for picture
Username: Lklives
Post Number: 8497
then wait for picture (sometimes may take 1 hr but NOT usually)...or shut off autoroll and manually enter the keys!
Saint luuu, Mo
Us
Post Number: 12
hows evreybody doinggg noww?}}}
Username: Jpz
MTL, QC
CAnada
Post Number: 187
hi to all
NEW KEYS , 3-29!
Username: Yahelwe
Hi guys, is everybody's dish network FTA working? I've had no picture for an hour now. I've shut down the receiver a few times and still no picture.Are there any new keys? thanks
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through March 29, 2007 [ « Previous ] [ Next » ]
