Home > Message Board > Home Video > TV Basics > Archive through May 15, 2006 > Sanyo TV service menu
Author Thread: Sanyo TV service menu
Username: Moonlord
Need access to a Sanyo 32FWH1F-C tv set. Can anyone help? Thanks.
i want the list of all old model of Sanyo Television of 26 inch and also their diagrams the most important model is just like CXM-2609 please give me some instructions . I will be thank ful to you. If you provide me my problem solution.
I have a avm 1904 20inch television. the other day it fell off the tv unit and stopped working, when you push the power botton it turns on but no picture and it makes a funny high pitched noise. I waswondering if it was worth fixing or if i should just get a new tv. Thanks
I want to connect toshiba laptop satellite to sanyo 32 inch TV. can anybody help?
i have a sanyo model ds19500 serial number b1370356410166 i lost the remote and the tv when pressing menu only jumps between the pic and sound functions is there any way that i can get access to the tv part of it again if you have any sugestions please email me at billy_vance2003@yahoo.com thanks
I HAVE A SANYO CHIPSET TV, AND THE COLOR BALANCE AND VERTICAL SHIFT ARE WRONG, I NEED ACCESS CODE FOR IT Can anyone help? Thanks.
alstgo@yahoo.com
I have Sanyo Dynamite 20 inch TV model 10240 and serial number 13709673. My son accidentally splashed water on the Set which affected the Channels and the volume. I sent it to a repairer who managed to get it back working except that the volume is locked at 12. I need help to go to the menu part where I can set the volume lock to off. If you have any sugestions please email me at cparker@bog.gov.gh
I have Sanyo Dynamite 20 inch TV model CM20KX8SA with Service Ref no: CM20KX8SA-00 and serial number 13709673. My son accidentally splashed water on the Set which affected the Channels and the volume. I sent it to a repairer who managed to get it back working except that the volume is locked at 12. I need help to go to the menu part where I can set the volume lock to off. If you have any sugestions please email me at cparker@bog.gov.gh
I need the code of a tv Sanyo model:DS19530 and the serial number is=>B6080394176889. I lost accidentally the original remote control and I buy a new control, but I don't have the codes for this tv. thanks for all my e-mail is black_zarathos@fastmail.fm THANKS !!
i am looking for the diagram of sanyo tv model cep6016v 21inch if you could please send me the diagram
need to find a horizontal sweep transistor # TT2168 or a cross reference # any help will be appreciated...TV model DS20930..1 year old
I have a sanyo CE28WN3-B, have no sound just a shoooshing noise. Can watch through Sky only with sound. Cannot play video or DVD through tv cos of sound ....... anyone got any idea please. email if you can help.
0-110010111
I need help ...... My Sanyo DS19530 has a problem ........ the picture is messeupt ...... very narrow .... like the crt is messed up ....... what is it .......
i have a Sanyo Ck29F86P 29 inch tv. There is no any integreation between sound and picture. There is a clear picture in PAL or Auto but there is no sound In this two frequencies. But the sound exists In NTSC. Is there any one who can help to integrate the sound and thepicture?
sanyo tv blackout square on some channels. not always same channel not all the time commmercials are ok and hitting volme or other keys on remotr square diappeard momentarily.. Is this a vchip setting problem? my nephew was playing with the remote previously. also I cannot accesss all menu features setup etc.
I have Sanyo C20-VE96K 21" tv which I took to a tehnician and I suspect he must have changed some specifications, is it possible to access its circuit diagram for purposes of trouble shooting.There are no sanyo specialists where I live.
PLEASE ADVICE ON HOW I CAN GET DIAGRAM FOR SANYO TV MODEL C20-VE96K am available at paulomeno@yahoo.co.uk
I have a Sanyo tv (model no. ds 27780) at the repair shop for months now. And each time it is returned to me the same parts keep burning-up (D614 Zener Diode & R617 Resistor). The tech. is saying he does not know the values on each part. Please, can you tell me the values on each of them. And maybe you should tell me the value on the fuse as well.
Have yourself a good day!
Thanks
Danny
I have a Sanyo ST-21C18M and i cant figure out the trouble. The screen is color blue then it has a white vertical deflection. at the beginning you can see a litlle bit picture but after a few seconds it becomes blue.Pls help me!!!!
we have Sanyo AVM-2503 model. now we want to connect the CD Player to TV. but yellow video and the Red and white audio conneting components are not available in the back side of TV. Then how do i connect the CD player to TV?
Anybody have an idea about this?
Thanks
saravana
PLEASE ADVICE ON HOW I CAN GET DIAGRAM or SERVICE MANUAL FOR SANYO TV MODEL AVM 201M. I´m available at
montejo66@yahoo.com
i have a sanyo tv. we were watching it and all of a sudden it just went out. we pushed the power button and it wont turn back on. the tv was not making any sounds are anything different it just went off and wont turn back on. PLEASE HELP!!!
The sanyo tv I have has recently had a habit of turning off after being on for about 10-30 sec. Now it won't stay on for more than 2 sec if at all.
I was alerted that it could be the voltage regulator being defective... How can I fix this problem?
Thank You
Username: Carlye
I have a Sanyo TV ( only 2 years old, 27in. sorry no specs. it is at work, home on sick leave.) It is froze on Video 1. Is there any way to reset for manual? the remote does not work. I had it in a classroom not sure what might have happened . Any suggestions welcomed. reach me at
ne_cstewart@mveca.org
I just bought a wide screen 30" sanyo HDTV. The picture in picture will not work. HELP!!!!
Username: Joeruble
I have a 27in sanyo avm2587 but lost the remote and the closed captioning is on. how do I change that using the tv menu button? Thanks.
Username: Joeruble
Username: Joeruble
I have a 27in sanyo avm2587 but lost the remote and the closed captioning is on. how do I change that using the tv menu button? Thanks. herecomethehawks@hotmail.com
I have a 28" Sanyo CE28WN3-B TV and I want to know how to put it into service mode. Thanks If you can help.
I have a Sanyo Tv model no. cpt8812.The parts
D471/R483(on the same point),R451,R492&R488 have totally failed and not available,especially the first part listed here.Can you please advise how to have fixed and if possible,may I know to get the full service manual for the same.
Username: Jesterhagus
I am looking for an owners manuel for a Sanyo TV Model C21EF27. If anyone can help please e-mail to jrv89@hotmail.com.
Thank you
Username: Crnjak
I need help! I have sanyo CE28DN9F-C and I need a SERVICE MENU for this tv. Horizontal position is 10cm in the left side. Thanks.
my tv is messed up model DS19230. The sceen is only one thin line in the middle of the sceen,But if you walk over to it it will go full then go back.can you tell me how to fix it and i need a service manual or diagram
samuelo
my 41 inch samsung projection tv has problems with red convergence I cannot adjust it manually using the remote any ideas if I can play around with the red tube?
i HAVE A SANYO model number DS19500 SERIAL NUMBER B2040361026999 MANUFACTURED IN jAN. OF 2002 WE CANT GET THE SAP to work on it we go through the menu and it says it is turned on but not available it has never worked is there a sevice menu or service mode i can use for troubleshooting and where can i get an owners manual and service manual
Username: Samijubal
Post Number: 872
Are you sure the channel you are trying to watch has SAP? Some channels do and some don't. Press display on the remote and see if it says SAP.
I have a sanyo tv model # DS25030 serial # V0480427376. I have no remote to this and I got cable to hooked up and The channels go from channel 2 to channel 47 then skip to channel 98 and thats all i get i dont get channels 48-97. what do I need to do to add these channels.(and how do I add or get them) anyone with any help would be GREAT, GREAT, GREAT!!!
Gevaudansbeast
I need the service menu for the Sanyo CP29AF2X..the screen is stretched and shifted to the right..thanks for the help
Username: Smilan
I am using C-14VT50 SANYO television and has a remote with Japanese language. My TV has a problem with color adjustment. The color changes into black/white and again into color in every 30 or 40 minutes. Please tell me the solution on how to adjust the color. Please email me at minpun@teacher.com
thear are tv has been cloesed on nembers servies we want slouation
Need an ownwer's manual for a 28" Sanyo TV Model ce28wn3-B
Can any one tell me how 2 get into the service menu for a sanyo ce32fwh4-b please?
simonnewton86@hotmail.com
thanks.
I need the service menu for the Sanyo CP29AF2X [A]-65 ..the screen is slightly distorted and slightly bowed inwards top and bottem
i have a sanyo television that isnt even a year old and i turned it off the other day and it wont turn back on. if it is left plugged in the back gets warm. its model DS25204. is this a common problem? what is the problem? and is it worth getting repaired?
PLEASE HELP!
mogrrl615@excite.com
pepe luis
i need diagram for tv sanyo ds25380 lost signal antena
Username: Agal
My 35 inch Sanyo TV model DS35580 has a problem. The sceen went black with only one thin line in the middle of the screen.I called customer support but they were closed for the weekend. This TV is at least 7 yrs old. Don't know if it is fixable, but am trying to get any information on what may have caused this...."my husband thinks it was caused from being left on too long". I don't tend to think so becuase it had only been on for about an hour when it happened. Anyhow, any information on how to fix it, a service manual, or diagram would be awesome.
Thanks.
Email: alygalli@sbcglobal.net
I need the service menu for the Sanyo CP21KX2.
Chassis AC5-A21.
Thanks all.
Yosip.
I have a DS20424 TV
I have the original remote. The TV was bought less than a year ago. The Tv does not respond to the remote or any other remote. I can't believe the TV's remote sensor is gone. did you ever run up against this problem with such a new TV and how did you fix it?
filipinoboy0385
My Sanyo displays a white vertical line, displaying the picture, but only one line, anyone know how to fix this?
My CBP2866 Sanyo Television is now not working, it is 12 years old and has been a great TV. I have a DVD player connected by SCART and this has been working till this week but now the TV displays AV all the time even though there is no sound or picture with either a DVD (AV) playing or for any channel chosen. Is this a serious fault?
i just got a used sanyo DS19500 i have no remote and i pluged my xbox into the plugin thing on the front but i cant find it on the t.v. does anyone know how to get it to come up?
I have a SANYO 13inch TV which I purchased recently. Set works good except for the interference on my radio when the radio is turned on. IT IS FULL OF STATIC ON ALL AM STATIONS.
Both the TV and Radio are plugged in the same receptacle as it was with my old TV. NEED HELP!
Username: Pryor02785
Laurens, Sc
Us
I just baught a used sanyo don't know molde or anything and don't have remote. it is on veido and I can not get it change from that to tv .The menue part of it is in red and the other is inyellow it will let change in yellow but jumps past the red on menue. How can I get to tv to change all.
My sanyo 36" tv model avm 3689 just stoped working after being on for about 2 hours.TV is 5 years old and is now dead.Nothing is working,wouldnt come on, no sound or enything-its dead.It is not a fuse I checked that and it doesnt have any visible burned or discolored parts or so.Since I dont have a schematic diagram I am lost.Any help would be apreciated.Thankyou.
Username: Jenaty
I have a Sanyo 32" TV. It is stuck in Video1 mode and I cant get it out. Any suggestions would be greatly Appreciated :-)
I have a Sanyo C20DN4AVN and when unplugged in the Power button, in the TV, when I turn it on, there is no image, just this weird sound (like an old motorcycle).
I've send it to repair, but the guy said it was too expensive to repair it, and that he had changed the power source, but the problem persists.
Somehow,he managed to turn it on (after trying 20 -30 times), and said not to turn it off in the tv only in the remote (leave it in standby).
Does someone know what the problem may be?Because I think he's ripping me off, I shouldn't pay for a temporary solution, especially if I think that he didn't do a thing.
Any help is aprecciated.
my sanyo ds27590 we hit the tv/video button on the dvd remote and it is now stuck in video mode dvd remote wont work i dont have the tv original remote any help would be greatly apprecieated e mail me back with any fixes
Username: Jenaty
Hi,
My Sanyo TV was also stuck in Video 1.
I also lost the remote. I went out and bought a Zenith Remote, Model # ZN311 for about $8.00 and programed it with the code 506 and hit the input button and it worked ! :-)
Jeff
Username: Malibu
I have a Sanyo tv 1990 model avm-302u,
this set has low audio, sound is clear but vol level has to be maxed out in order to get any sound out of it....
Please help
i have a sanyo 30 hdtv widescreen, and the color turns green alot...its brand new, if i shake the coax cable it goes back to normal...what is the deal?
Have Sanyo model DS35520 TV Does not turn on with remote or front power button pluging power cord into outlet draws arc, ie current flows. Does the remote and or the power switch activate a relay which may have burnt contacts?
Hi I just bought a 32" Sanyo TV. The problem is that when I play a black and white movie I sort of see a yellowish stain or shadow on the right side of the screen. Has anyone come across this problem. I tried different black and white movies with the same result. Color movies not a problem. Thanks.
Username: Ruthless02
My TV is only two years old and is Stuck in Video Mode. The screen is blue with the word Video in the upper right hand corner.
Menu on the TV is in RED. Does anyone know how I fix this problem?
I bought two new remotes and programed them, but the input but doesn't correct the problem.
Username: Cinwitch033
Waterville, Me.
United States
Hi I have a 27" Sanyo tv model #DS25204. Only had it about a yr. when it turned off by it self and won't turn back on. Does make a noise when you try to turn it on, but not sound or picture. Can it be fixed? or should we just junk it? Thanks any help would be Greatly appreciated.
CinWitch033@aol.com
I have a 36" AVM3680G. It is a 2001 model. When I turned it on it worked fine but then all the red colours left making for a blue green yellowish colour. When I tried to adjust this in the manual tint mode,the G for green was lit up but the R for red came on for a few seconds and the picture was great but soon went back to the blue-green colour. Can I get a service manual or schematic for this model or can anyone help diagnose the problem from this description? Please help...
I have a Sanyo TV, 'bout 2 years old with one RCA hookup in the front. I have just been given 5 very nice Pioneer speakers for surround sound...is there any way to hook these up to the TV? Went to Radio Shack and those guys were stumped.
I have a 27" Sanyo TV and one day I was trying to change channels and my TV display was getting bigger and smaller. Now you can not see the forehead or the feet of the people. Does anyone know how to fix this? The aspect ratio is red on the menu and does not work for the TV only for Video. My email address is arellane@yahoo.com
CE28WN3-B Sanyo TV
When the temperature drops outside my house to below zero my TV cannot cope with Sky. I always thought this was the fault of the dish but we are now running SKY+ and have the old sky box linked up to another tv in another room and that runs fine, no matter what temperature, so that knocks the 'dish' theory on the head. It was -5 outside last night and we have really good heating in the house so can anyone shed any light on this. We could not see any picture at all on any Sky channel last night but we did record on sky plus and when that recording was replayed this morning it had recorded perfectly. This all leads me now to believe it is a fault of the TV. Any suggestions?
TV only 5/6 years old and it is now 18:14pm Tuesday 31st Jan. and the temperature has fallen rapidly outside and the interference on Sky has started again. It begins with a few vertical lines which eventually take over the whole screen and the sound goes too. Sorry for the essay but any help would be great. email joyciejo@hotmail.com
sa
I have a 14" sanyo TV (for some 5 years now). The model on the back says C 14 PTX, which is weird because i can't find anything about it anywhere. I've tried searching for anything in it resembling a number format like the ones i normally see posted - to no avail. Thing is, now i need to center the screen for it, so i need to access the service menu. The body only has the power button, channel -and+ and volume -and+ buttons. The remote is kinda similar to the 14AT2-C model (sanyo fisher sales europe website). I tried to search for the service menu code out there but no luck whatsoever. I know it's not much to go on in terms of specification. If anyone would happen to know the code for this one please email blarggh@hotmail.com
thank you
My input or whatever u call it on the back of my tv that my cable wire runs into got yanked out of the TV is there a way to fix this easily. PLEASE SOMEONE HELP ME OUT. It is a very expensive tv and i need some help please.
Turtlehawk
how would i change my SANYO DS27530 to video/game mode?
email @ seth_hall80@yahoo.com
Turtlehawk
I have a 27" sanyo tv and all i get is a thin whit line in the middle. Can anyone help? Thanks
Username: Jld
I have sanyo television and it`s stuck in video 1 mode i`ve tried unplugging it to see if i could get the t.v to reset it`s self but that did`nt work. i`ve tried the menu and found my channel search selection was in the red and won`t let me in to it. what`s your solutions.
sanyo tv blackout square on some channels. not always same channel not all the time hitting volume or other keys on remote, square diappears momentarily. Is this a vchip setting problem?
torrrystrong
I lost my sanyo tv remote. Now I don't have access to the menu option that was on my remote. I mostly used it to access the dvd or vcr mode. The menu button on the tv doesn't have this option- it's just for picture adjust etc. What can I do? Help!!!
I have a Sanyo 27" mod no. 27780. I have only the thin horizontal line in the middle. I think it may be the vertical IC. Can anyone give me any test tips to make sure or to check for another problem that may cause this?
Username: Bru
We have a Sanyo CE28WN3-B which started sound problems last night. The power protection light flashes randomly , the speakers crackle like a dirty volume switch and ultimately the crackle stops . We now have to use the sky box to get the sound. . The TV red power light still flashes . I've tried switching off , pulling mains plugs out etc - no change - Can any one help / advise .Bruce
Home > Message Board > Home Video > TV Basics > Archive through May 15, 2006 > Sanyo TV service menu [ « Previous ] [ Next » ]
