Thread: DVD to VHS w/combo |
New member Username: Markb4
Post Number: 1 Registered: Mar-07
| Posted on Saturday, March 24, 2007 - 11:40 am: |
Hi! I have a TV/DVD/VCR combo and I was wondering how I can record from a DVD to a VHS with the combo. (I know how to record using a separate DVD player and separate VCR, but if it is all in one combo, how do I do it)? Thanks! |
New member Username: Christy
| Posted on Saturday, March 24, 2007 - 09:24 pm: |
I HAVE A SANYO DVD VCR COMBO AND I CAN NOT GET IT TO RECORD. I DO NOT HAVE A MANNUAL. I SET THE TIMER . I SET IT TO RECORD AND IT WILL NOT RECORD. EVERY VCR I HAVE HAD BEFORE HAS WORK AND IT WAS AS SIMPLE AS SETTING IT TO RECORD THEN TURNING OFF THE VCR. BUT I HAVE TRIED TURNING IT OFF AND LEAVING IT ON IT STILL WILL NOT RECORD. PLEASE LET ME KNOW IF YOU KNOW WHAT IT IS I NEED TO DO TO GET IT TO RECORD? |
Gold Member Username: Illuminator
Post Number: 4998 Registered: Apr-05
| Posted on Tuesday, April 03, 2007 - 06:44 pm: |
quote:Hi! I have a TV/DVD/VCR combo and I was wondering how I can record from a DVD to a VHS with the combo. (I know how to record using a separate DVD player and separate VCR, but if it is all in one combo, how do I do it)? Thanks!
Can't you just hook up the DVD output to the VCR input? You might have trouble with the copyright management system. Also, why? |
