Home > Message Board > Home Video > VCR > SV2000 Help
Author Thread: SV2000 Help
Username: Saclon
I own a Sv2000 4head-hi-fi and it has a tape in it but wont eject. on power up it will light up for a few seconds and make a very quiet noise then turn off. please help?
Relevant Product Info
Username: Jonewix
Minneapolis, Minnesota
Is this a Sony SVO-2000 VCR? If so, disconnect the VCR from power. Take the 4 screws from the cover's side & remove cover. You can access the opening for the tape. inside, on the right side of the opening is a white plastic hinge. The hinge wears out and sticks. Use a small screw driver to adjust it back into operating order. Don't break it! Good luck!
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > VCR > SV2000 Help [ « Previous ] [ Next » ]
