Home > Message Board > Home Video > TV Basics > Archive through April 02, 2007 > Mitsubishi power ON then OFF with a m...
Author Thread: Mitsubishi power ON then OFF with a message "No Air Flow"
Username: Tadon
Dover, NJ
Usa
Post Number: 134
I have a Mitsubishi model WD65371 when I turn on power and the green power light comes on for about 2 seconds and then goes off. No picture, no sound . With a message "No air flow" . Any suggestion & help please . Thx
Username: Boshears
hey bui le just wondering if anyone had told you how to fix that got the same problem on a different model was tipped to resolder the f9a05 and f9a02 pico fuse and it came on and then i turned it off and it didnt come back on again if you can help please thanks
Home > Message Board > Home Video > TV Basics > Archive through April 02, 2007 > Mitsubishi power ON then OFF with a m... [ « Previous ] [ Next » ]
