Thread: Sanyo Service Mode |
New member Username: Dickmarellan
Post Number: 1 Registered: Mar-07
| Posted on Sunday, March 11, 2007 - 04:19 pm: |
Hi I've been having major problems since new with a Sanyo CE28WN7. Awful colour, and now the picture has slipped so the bottom right corner is lower than the left. The picture is also too large for the screen (on screen graphics are off the bottom of the screen). The service people from the company I bought it from inist there is no problem even though it is still under warranty! My last resort is an old friend who is a TV tech, but has been retired for several years now. He won't open it up so as not to invalidate the warranty (for what that's worth), but has said he'll put it on the bench if I can get into the service menu. Any help greatly appreciated, before I write this terrible TV off. Thanks |
Gold Member Username: Samijubal
Post Number: 3366 Registered: Jul-04
| Posted on Friday, March 16, 2007 - 11:32 am: |
Unplug the TV and press the volume down button on the TV while you plug it back in. Be sure to write down any adjustments you plan to change first. Adjustments are specific to each TV, if you mess something up, they'll be the only way back to where it was. |
Post Number: 2 Registered: Mar-07
| Posted on Sunday, March 18, 2007 - 06:22 pm: |
Thanks will give it a go. |
Post Number: 3 Registered: Mar-07
| Posted on Friday, March 30, 2007 - 10:21 am: |
Thanks. But this doesn't seem to work. |
Post Number: 3382 Registered: Jul-04
| Posted on Saturday, March 31, 2007 - 05:04 pm: |
It works on mine. There's not much you can do in the service menus without a service manual. Adjustments aren't clearly labeled. |
Post Number: 4 Registered: Mar-07
| Posted on Tuesday, April 10, 2007 - 12:14 pm: |
Cheers. I'll try again, and keep my fingers crossed. |
Post Number: 5 Registered: Mar-07
| Posted on Tuesday, April 10, 2007 - 12:57 pm: |
How do you find the TV by the way? The skin tone on ours is awful. |
Post Number: 3386 Registered: Jul-04
| Posted on Tuesday, April 10, 2007 - 05:12 pm: |
Mine isn't that model, so the service menu is probably different on yours. Unless you can find something on the net to describe what adjustments do what, I doubt you can find the right one. On mine there must be 100 or more adjustments that aren't clearly labeled. The adjustments are letters and numbers, not actual names like tint, color, etc. If your TV is like mine, you'll need a service manual or some info on the net to find the right adjustments. You might try AVS forum, that's where I found how to get into the service menus on mine and the pincushion adjustments. |
Post Number: 6 Registered: Mar-07
| Posted on Thursday, April 12, 2007 - 05:29 am: |
Cheers. Still no luck with that method. I'll root around for more info then give the bandits at Currys a try again. Thanks for the help. |
