Thread: Scart to composite no Sound |
New member Username: Chelsieandnic
Post Number: 1 Registered: Mar-07
| Posted on Sunday, March 11, 2007 - 07:44 am: |
I have just purchased a Philips LCD TV and amd connecting it to a cable box using a Scart to composite cable. I get picture but no sound. I have tried plugging the red and white audio cables into the one digital audio in spot (a big stretch from the rbg spot) but no sound. I have also tried plugging the audio cables into the H and V connections right below the RBG spot, but still no sound. Any help greatly appreciated. |
Silver Member Username: Rysa3
Houston, Texas
Post Number: 129 Registered: Nov-06
| Posted on Sunday, March 11, 2007 - 11:39 am: |
Red and White are analog. They wont work in a digital input or output. |
Post Number: 2 Registered: Mar-07
| Posted on Sunday, March 11, 2007 - 04:30 pm: |
Thanks for the response Marc, does that mean I need another lead, or should the sound come through the 3 RB&G plugs? Because the RBG plugs seem to be in the correct spots. |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 1405 Registered: Feb-04
| Posted on Monday, March 12, 2007 - 01:06 am: |
Chelsie, I'm a bit confused here. The thread title is "scart to composite" which would imply a scart®yellow/white/red for video and R/L audio. But later you are talking scart®RGB, which would carry no audio at all. |
Post Number: 3 Registered: Mar-07
| Posted on Tuesday, March 13, 2007 - 07:16 am: |
G'day John. THe packaging Says Scart to composite., but it is a Scart from one end and then has 5 leads off it RBG and Audio (Red and White)? |
Columbus,
Ohio
US
Post Number: 1411 Registered: Feb-04
| Posted on Tuesday, March 13, 2007 - 11:30 am: |
OK now I get it. So you have a cable like this one: http://www.hometheatre.net.au/foxtelcable.htm Obviously, I can't check out all modern displays on the market, but I have never seen a TV with component (red/green/blue) inputs that didn't have companion audio (red/white) inputs to go with that input. |
