Thread: Digital better than analog? |
New member Username: Alex_from_lansing
Post Number: 5 Registered: Feb-07
| Posted on Saturday, March 10, 2007 - 11:04 am: |
I recently got a 542i from a Olevia, a 42" HDTV with a QAM tuner. The QAM tuner picks up a ton of extra digital channels from my standard Comcast cable. However, most of these are only 480i SD, and most of the extra channels are the same channels that I already got in analog. I want to know if there is any advantage to the digital channels compared to just watching the analog channels, because if not, I just want to set them all to skip because there's so many and they just make channel surfing a hassle. If it makes any difference, I'm just using the basic speakers (2 x 20W) that came on the TV. |
Relevant Product Info
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 1407 Registered: Feb-04
| Posted on Monday, March 12, 2007 - 09:31 am: |
Alex, the only reason to keep those extra QAM-generated channels around is if the video is noticeably better then those channels on their original numbers. I would do a scan every 6 months or so because things can change on the cable. New (good) channels can be added without your knowledge unless you do regular scans. What about the HD channels? Did you get any? |
Post Number: 6 Registered: Feb-07
| Posted on Monday, March 12, 2007 - 07:14 pm: |
Ok, thanks. I can't notice much of a difference for any of them, and that's why I was wondering. I guess I'll just skip all the repeats. I got all the local HD channels I was hoping for (Fox, ABC, CBS, and NBC), plus WKAR DT and a channel that periodically switches between broadcasting VS Sports and the Golf Channel. |
Silver Member Username: Tapeman
Post Number: 734 Registered: Oct-06
| Posted on Wednesday, March 14, 2007 - 11:19 am: |
What do you mean you got all locals but you were hoping for Fox, ABC, CBS and NBC? I thought those were locals for any town. If you are looking for Local I do have a great section on HD OTA antenna that is totally free post# 614 and 716-721 http://forum.ecoustics.com/bbs/messages/2/330353.html |
