Home > Message Board > Home Video > HDTV Programming > RCA 56"
Author Thread: RCA 56"
Username: Scrunchy
I have a RCA 56" widescreen projection HDTV with built in digital tuner. This is the item Description:
The RCA 56" HDTV widescreen projection television is equipped with a built-in HDTV tuner for access to high-definition programming. No need for a separate set-top box to clutter up your home theater area. This giant-screen TV also features a digital comb filter that helps create an ultra-sharp picture. Connections include DVI, component and composite inputs.
Technical Information
# Actual Screen Size56"
# Compatible TechnologyHDTV
# Aspect Ratio16:9
# Parental ControlV-chip
# Sleep/Wakeup TimerSleep
# FeaturesAuto Program
# Auto Power On
Video
# Video SystemATSC
# NTSC
# Comb Filter3-lines Digital
# Color TemperatureWarm
Audio
# Speakers2 x 10W Front
# Sound System - SAP
Interfaces/Ports
Ports
# Composite Video Input
# S-Video In
# Component Video Input
# 1 x DVI
# 2 x RF
# 2 x Video Out
# Stereo Audio Line Out
# S-Video Front
# Headphone Jack
# 2 x Stereo Audio Line In
Controls/Indicators
# Language SupportedEnglish
# French
# Spanish
Power Description
# Input Voltage110V AC
# Input Voltage Range90 V AC to 130 V AC
# Frequency60Hz
How to I tune my HD Channels? Do I need an antenna or s-video cable?
Please help.
Relevant Product Info
Username: Tapeman
Post Number: 638
If you want local get an amplified HD antenna
Or cable/satellite
Check post#614
http://forum.ecoustics.com/bbs/messages/2/330353.html
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Video > HDTV Programming > RCA 56" [ « Previous ] [ Next » ]
