Home > Message Board > Home Video > Rear Projection TVs > Archive through March 23, 2007 > Samsung HLR6168 problem - Vertical st...
Author Thread: Samsung HLR6168 problem - Vertical stripe on screen
Username: The_audioguy
My 18 month old HLR6168 just started displaying a grey vertical strip on the far right of the screen. It is semi-transparent and is wider at the top. It shows on all inputs and the tuner so it is a TV problem. It looks like something has partially covered the light path. Any ideas? Attached is a good photo to illustrate the problem.
Relevant Product Info
Home > Message Board > Home Video > Rear Projection TVs > Archive through March 23, 2007 > Samsung HLR6168 problem - Vertical st... [ « Previous ] [ Next » ]
