Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through February 14, 2007
Author Thread: Archive through February 14, 2007
Username: Rekman
Mntl-Quebec-...
Post Number: 184
Two months Ago it read as follows
CAS------------ DISNET WORK
INDENT------------ (dont remember the numer)
NOW I Am Confused.,... because I cannot see the Dishnet work... There are other other names example VIacess- CONAX--Nagravision etccccccc......
PLEASE HELP Me..
Username: Asharfi
Post Number: 563
Latst bin for Magnum XV3300 receiver is at www.dssworld.co.nr. The bin works well and it's safe. Here are the bin features:
02-11-07
Bin version 144
Team Reliable / Team Magnum
Magnum Users,
In the on going effort to meet our goal of zero downtime, Team Reliable is proud to announce MagnumV144.bin for XV300.
Improvements
* CPU Clock returned to 200mhz for stability
* Video gliching improved via Fast MAP3B and MAP57 Processing
* Audio drop out improved
* Freezing Issue improved
* Channel and EPG Scrolling improved
* Improved Channel Scanning
* Improved Switching
* Better Signal Quality
* Bev/Dish key roll updates and enhancements
(For best results wait for AutoRoll on DN/Channel HBO-E and BeV/Channel SPEED)
* Closed Captions now functioning properly
* Auto TP functioning properly
* Misc Picture and sound improvements
This file can be loaded right on top of any of the V140-143b releases.
However, If you are loading on a box with a V138 or earlier file on it
then please use your remote control and do a factory default prior to
loading this file. Also, if you experience any problems with channel
lists or signal reception it may be best to factory default also.
C/P from DssWorld.
Username: Albino_midget
Post Number: 418
MKM, i don't have the c00lsat but i believe the dn ident is 0001
You may want to start a new thread to get proper help.
http://forum.ecoustics.com/bbs/messages/2/184799.html
Username: Rekman
Mntl-Quebec-...
Post Number: 185
thanks again Albino... I have been able to see the 8282 as it was before... with the
CAS nagravision
indent Dieshnet
etccc....
Thanks indeed for this part....
Now I still not having my channels...
I set sattelite Echostar 3
and did a Blind and all other Scan which exist on the receiver...
But no channels have appear while scanning.......
The quality is 80 % RED and Level 10% RED...
What should I do.. please help... THANKS
Username: Marveg27
how do i get the new bin for the viewsat 2000 plat? How do i download it? i need step by step, i am new to this.thanks!!
Username: Nydas
Post Number: 1854
Mario: Go tothe following site, and look at the Viewsat section. You have to download
1) The latest BIN - it will be about 4-5 days old.
2) the loader
3) The instructions.
4) You will need a DB9 F/F null cable - it probably came with your receiver.
Follow the instructions very precisely.
Good luck.
http://www.totalfta.com
http://future-fta.info
http://dssrookie.com
Username: Rekman
Mntl-Quebec-...
Post Number: 186
Yes Mario Vega... get urself registered there on DSSRookies Forum... and you will be very well guided ...
http://www.dssrookie.com/forums/img-src-images-viewsat-png-border-0-b-font-color -0000ee-viewsat-font-discussion/
Username: Marveg27
i went but no luck. please assist
Username: Nydas
Post Number: 1855
Mario. You need files. This forum does not have files. Nobody here can help you unless you go and get the files.
Username: Marveg27
Post Number: 7
i found the files. after i extract what do i do ?
Username: Rekman
Mntl-Quebec-...
Post Number: 188
Nalini Lyda.... u too online.... Hoooooo.... please Help me....
I have been able to load the new Bin and update the keys.... Cools*t 5000
But no channels scanning.... what should I do ????... and Quality is 80% RED and Level 10% RED.... how to bring the to Green..... please Advice.... Thanks as usual...
Username: Nydas
Post Number: 1856
Did you not get the instructions? And the loader?
FOLLOW THE INSTRUCTIONS CLOSELY.
Username: Marveg27
Post Number: 8
no. dont know how or where. please bare with me. i am new.
Username: Marveg27
Post Number: 9
i found the loader and the file. what do i do now? extract file?
Username: Jessy87
wat can i do to make the rest of my channels to work.... anyone
Username: Way2smart
CANADA
Moderator ®
Post Number: 172
ANY 1 HAS THE NEW Microyal Bin PLZ
THX
Username: Dude123
Post Number: 922
mario vega
Ok extract the file first...
Connect your receiver to your PC using null cable (not straight through) turn your receiver ON once its hooked up. then open the loader, select the bin file and download it. and donot interept the receiver when downloading. after downloading has finished unhook your receiver from PC and hook it up to the TV then go and do set default key, and let it autoroll... then enjoy free TV.
Make sure you are using the right bin file and the loader, downloading wrong bin file onto your receiver will cause your box to fry, and you will have to jtag it, and its pain, believe me...
GOOD LUCK!!!!!!
Username: Yashmatharu
Brampton, Ont
Post Number: 16
I have pansat 2500 and all the channels are blank. Can anybody suggest me as to what to do?
Brampton, Ont
Post Number: 17
and there is no quality in TP Scan.......
Username: Jpz
MTL, QC
CAnada
Post Number: 161
hi guys
Brampton, Ont
Post Number: 18
Hi Folks,
I have pansat clone working on bin 289T. I don't see any settlite signals.
plz help
Username: Eatfish111
Post Number: 111
Yash check your diseq switch settings and set them accordingly. usually 1 for 110 and 2 for 119
Brampton, Ont
Post Number: 19
i uploaded 290T. I can see my signals and everything is fine.
thanks eatfish. Iam using 61.5
Username: Desi_babu
Hi U all
I am new to this so help me if you can
I have eagle star model 153-2500a
how can see some sports channel specially cricket one. i can view almost every channel execpt B4U, B4U music
Thank you
Username: Justeen_rawr_x
heyy guys does anyone have any keys? i need them xD like from the 12th
JUS!teen
Username: Pepaws11
Pendleton, SC
Hello Everybody,
Need new keys for today the 13th, please help
Username: Dragunov
As per today 13th 4pm:
DN:
96: D2 3E 75 E3 02 22 A8 FB FA DF B0 F4 E9 2D 1C D2
Username: Dragunov
Forgot the other one, here it goes:
Para la Mara de MTL:
86: E4 BA E1 1B 9B 92 09 E9 D7 46 CF A9 45 B6 D0 4E
Username: Canndy
Www.livefta.com, Www.livefta.com
Www.livefta.com
Post Number: 309
http://www.livefta.com/forums/t1939-latest-keysspan.html
DN: Last: Feb 13 19:24PM
00, 86: E4 BA E1 1B 9B 92 09 E9 D7 46 CF A9 45 B6 D0 4E
00: E4 BA E1 1B 9B 92 09 E9
01: D7 46 CF A9 45 B6 D0 4E
01, 96: D2 3E 75 E3 02 22 A8 FB FA DF B0 F4 E9 2D 1C D2
00: D2 3E 75 E3 02 22 A8 FB
01: FA DF B0 F4 E9 2D 1C D2
Username: Shahrokhi_2008
Toronto, Toronto ON
Post Number: 40
13/02/2007 At 7:31 PM
Key_86___E4 BA E1 1B 9B 92 09 E9 D7 46 CF A9 45 B6 D0 4E
KEY 96___D2 3E 75 E3 02 22 A8 FB FA DF B0 F4 E9 2D 1C D2
12/02/2007 At 1:45 Pm
Aux 86__E4 A3 E0 9F F9 24 EA D0 DF 62 38 80 A1 09 23 C8
Aux 96___3F AC 96 3A 4B 2A B2 6D 0B AF DF 52 81 80 85 0D
Username: Theghost
Post Number: 21
00: E4 BA E1 1B 9B 92 09 E9 D7 46 CF A9 45 B6 D0 4E
01: D2 3E 75 E3 02 22 A8 FB FA DF B0 F4 E9 2D 1C D2
Bev: Last: Feb 12 17:25 PM
00: E4 A3 E0 9F F9 24 EA D0 DF 62 38 80 A1 09 23 C8
01: 3F AC 96 3A 4B 2A B2 6D 0B AF DF 52 81 80 85 0D
Username: Walidsm
Post Number: 11
Hi, the posted (above)Dish Network key doesn't work in my Pansat 2500. Need help please
Username: Daniel61
Mississauga, ON
Post Number: 19
This keys doesn't work in my fortec life time ultra.
Something smell bad.
Username: Walidsm
Post Number: 12
Nalin or the one, can you help me please if you are there?
The DN key doesn't work in my Pansat 2500. I use the bin 289T. I made the autoroll off but I still have nothing.
Username: Mc_sunny
Post Number: 1120
Make sure u have the current keys double check wutever u enter..Also Make sure u have ur AutoRoll OFF and KeyCODE ON !!!!
Username: Canndy
Www.livefta.com
Post Number: 311
Keys changed again .... http://www.livefta.com/forums/t1939-latest-keysspan.html
Username: Canndy
Www.livefta.com
Post Number: 313
DN: Last: Feb 13 20:00PM Note: Keys change fast so you maybe looking for older keys...
00, 86: F6 31 BA 56 AD E0 ED 3B 8F 4D 7C 95 5A 0F 64 BB
00: F6 31 BA 56 AD E0 ED 3B
01: 8F 4D 7C 95 5A 0F 64 BB
Brampton, Ont
Post Number: 20
I have 290T bin on pansat clone. many hindi channels are showing scrambled error. Can anybody advise what needs to be done to get these back?
Username: Will_d
Post Number: 21
dn keys r down,new keys pls
Username: Theghost
Post Number: 22
"Yash Martharu" look at the post above you, the keys have changed again.
Username: Canndy
Www.livefta.com
Post Number: 314
Username: Kingbro
Montreal, QUEBEC
CANADA
ANYONE HAS NEW KEYS FOR DISNETWORK.PLS WRITE THANKS
Username: Asharfi
Post Number: 564
here u go...
00: F6 31 BA 56 AD E0 ED 3B 8F 4D 7C 95 5A 0F 64 BB (Active)
enjoy :-)
C/P from DssWorld
Brampton, Ont
Post Number: 22
K.THEGHOST
But my other channels were coming. My problem is not relevant to keys.
Username: Lilmeli
Toronto, Ontario
I got question my echostar chanel dont work what to I do to get them work
thanks
Brampton, Ont
Post Number: 23
what receiver do you have?
Username: Lilmeli
Toronto, Ontario
I have dishnetwork my satelite box is fortec
Brampton, Ont
Post Number: 27
try to upload the latest bin....
Username: Lilmeli
Toronto, Ontario
what the lastest bin i dont know what a bin is
Username: Crazy416
Post Number: 34
471 is working for me with 289t, you just have to put the latest keys. but for some reason, DN is showing the match on 472 right now, the 3rd ODI. also if you have nimiq 2, you can watch it on jaya tv and pak vs sf on cbn.
Username: Crazy416
Post Number: 35
sorry wrong thread, just ignore my previous post lol
Username: Aksma
Post Number: 39
thats fine dani, can you please tell me on which satillite is 472 on 110??
Username: Jpz
MTL, QC
CAnada
Post Number: 162
HI GUYS
Username: Shanti142305
Brampton, Ontraio
hi guys tyey have new key 00 f6 31 ba 56 ad e0 ed 3b 8f 4d 74 95 5a 0f 64 bb 01 d2,3e ,75,e3,02,22,a8,fb,fa,df,b0,f4,e9,2d,1c,d2
Username: Dude123
Post Number: 924
melissa martin
You need to do a lot of reading, here is a quick start. Bin File is a bios flash file that has to be downloaded onto your receiver in order to receive signals from the satellite to your box. Also to download the bin file you need a cable (to connect your box to computer) either null cable or straight though cable depends on what kind of receiver you have, in your case its a straight through cable, purchase that if you don't have one. and to download a bin file onto your receiver you also need to download a loader. You can get all the files from the following website but make sure you study before you take any action, because a little mistake can cause alot of hassle and disappointment. If you are not sure what I am talking about, i suggest you get some professional help. that would be easier.
here are the sites:
www.dssevolution dot com
www.totalfta dot com
www.dsscommunity dot com
GoodLuck!!!
Brampton, Ontraio
sorry that one new key
dn 00 F6 31 BA 56 AD E0 ED 3B 8F
4D 7C 95 5A 0F 64 BB 01it works}}
Brampton, Ontraio
any bady now how get down loader i dont that plz tel me that
Username: Ayesha
Toronto, ON
i need a key
can someone plz post tht new key thanks
Username: Lklives
Post Number: 7739
Current Working Nagra2 Keys...FOR ALL RECEIVERS..
Dish Provider 0101: Last Updated (Feb13 10:30pm EST)
Key0:F6 31 BA 56 AD E0 ED 3B 8F 4D 7C 95 5A 0F 64 BB (Active)
Key1: D2 3E 75 E3 02 22 A8 FB FA DF B0 F4 E9 2D 1C D2
Bev Provider 0901: Last Updated (Feb12 2:00pm EST)
Key0: E4 A3 E0 9F F9 24 EA D0 DF 62 38 80 A1 09 23 C8
Key1: 3F AC 96 3A 4B 2A B2 6D 0B AF DF 52 81 80 85 0D (Active)
Username: Shefic
Hi,
I have reciever pansat 2300A. I can watch programs only on satelite 110.Only partial programs are available. What I need to do to get
all programs?
Username: Ayesha
Toronto, ON
thanks for the key
i have a question am just getting 2 channels sahara one and geo wht should i do to get other channels
is there any new file out tht i have to install or is it coz of the match
Username: Mkvl1490
Post Number: 92
hi to everybody
i put tha 290 bin on 2500 and i have scrambled problems and tha thing IS DELETIN MY CHANNELS
Post Number: 124
turn tp autoupdate to off and rescan sats
Username: Mkvl1490
Post Number: 93
u kno i did do dat and when i rescanned my channels not all of them came up
Username: Ayesha
Toronto, ON
ya i did the same thing but i didnt get those channel
Username: Larry1
Dawson creek, Bc
Post Number: 19
is there any new keys for bev on feb 14 thanks
Username: Dude123
Post Number: 925
Nagra2 Keys
Bev Provider 0901: Last Updated (Feb14 1:30pm EST)
Key0: 92 F6 52 B5 15 39 19 C9 73 64 59 AE 3A DD AD D3 (Active)
Username: Sirroy
Edmonton, Alberta
Hi guys and gals - make my Valentine's Day
New Bev keys please.
Username: Sirroy
Edmonton, Alberta
Sorry nice people - they were right in front of me.
Username: Rekman
Mntl-Quebec-...
Post Number: 189
Hi The ONE.... how r u ??... as always u r Helpful....
I have a problem with my Receiver setting... Cools*t 5000.... I think the Time is not set properly...
My receiver plays only as from 18.00 hr till 23.30... after that it says BAD or NO SIGNAL....
How can it be Bad or NO Signal .. since all channels plays very well between 18.00-23.30...
Can You please find out exactly .. and give me here how to set it properly...
I live in quebec montreal.... I set time on the receiver 14-Feb 2007 Canada Atlantic...
Thanks...
Username: Ars88
P.I.M.P , Pakistani/In...
United States
Post Number: 529
ayesha...start another thread..u might get more responses there as well or if u have aim hit me up and i will help u out....
arslani2k <---ayesha dat is the aim address
(plz no idiots im me lol)
Username: Wariat
Post Number: 21
is there new keys??
Username: Shaitan
Post Number: 13
I have CoolSt5k with bin 141. My ZeeTV, ZeeCinema and B4UMovie does not display properly. All boxes on screen and garbage. Rest all Indian channels are okay. Signal Strength on Satelite is 82%. I have rescanned but its the same. Please advice
Username: Skz720
Post Number: 23
Echostar DishNetwork (Last Update: 2007/02/13 7:26 PM PST)
Key 0: F6 31 BA 56 AD E0 ED 3B 8F 4D 7C 95 5A 0F 64 BB
Key 1: D2 3E 75 E3 02 22 A8 FB FA DF B0 F4 E9 2D 1C D2 Active
Username: Wariat
Post Number: 22
i have those keys.. no picture
Username: Shaitan
Post Number: 14
Any CoolSt 5K specialist who can help me on my previous request
Username: Lanxer
Hey, On DSS world they have the New
290 and 290T bins but they have individual ones for BEV and DN. Is there anyway I can run both on one system?
Username: Lanxer
Hey, On DSS world they have the New 290 and 290T bins but they have individual ones for BEV and DN. Is there anyway I can run both on one system?
Username: Mezeus
hello, I have been on the stellite world for about 2 years now. an i currently have an FLU and a viewsat Lite. both working farily good till last week. and though my FLU works ok when I change the keys manually my viewsat has developed aproblem since I installed the new -020607 bin. the problem is like this. sometime it autorolls. some times it does not.. but when it does not I put the key in manually ( have done it many many time before.) but then it keeps sayign autoroll procesing. if I turn the auto roll off it says no video or audio menaing wrong keys but the keys are correct. any ideas? what might be the problem. one more pecular thing a few times it has rolled withing about 2 mins and all works great. Help!! any one pls
Username: Redragon
anyone have the keys for EchoStar DishNetwork.. i tried the ones posted above and its not working
Username: Canndy
Www.livefta.com
Post Number: 318
Syed Faizi, the new keys are posted live at
Username: Canndy
Www.livefta.com
Post Number: 319
LiveFTA - always LIVE keys:::
DN: Last: Feb 14 16:00PM Note: Keys change fast so you maybe looking for older keys...
www.livefta.com
01, 96: 49 63 CD 44 1C C9 CE FE C6 79 47 91 DE 35 8B 5D
00: 49 63 CD 44 1C C9 CE FE
01: C6 79 47 91 DE 35 8B 5D
Check to see which one is active by visiting:
Username: Lilmeli
Toronto, Ontario
Post Number: 7
are those the lastest key they when down at 8:30
Username: Flashman
Post Number: 29
00: F631BA56ADE0ED3B8F4D7C955A0F64BB
01: 4963CD441CC9CEFEC6794791DE358B5D ACTIVE
Username: Canndy
Www.livefta.com
Post Number: 322
www.livefta.com
Username: K98
dn keys on candy message board
Username: Jattsober
Post Number: 7
these keys are not working man, gotta find the working ones
Username: Senators
Post Number: 83
Bell ExpressVu (Last Update: 2007/02/14 10:13 AM PST)
Key 0: 92 F6 52 B5 15 39 19 C9 73 64 59 AE 3A DD AD D3
Key 1: 3F AC 96 3A 4B 2A B2 6D 0B AF DF 52 81 80 85 0D Active
Echostar DishNetwork (Last Update: 2007/02/14 4:57 PM PST)
Key 1: 49 63 CD 44 1C C9 CE FE C6 79 47 91 DE 35 8B 5D Active
Username: K98
01 keys are working on dn -4963cd441cc9cefec6794791de358b5d
Username: Canndy
Www.livefta.com
Post Number: 323
www.livefta.com
01 is working
Username: Milogone
Under the radar, Cant say
Post Number: 8
Don't want to go there to see keys ,
that's why I'm here duh
whats the matter with you?
Username: Jattsober
Post Number: 8
www.livefta.com
01 is working
THESE KEYS ARE NOT WORKING MY FRIEND}
Username: Milogone
Post Number: 9
01: 49 63 CD 44 1C C9 CE FE C6 79 47 91 DE 35 8B 5D
Username: Dude123
Post Number: 927
These are the current keys people, make sure you are entering them correctly...One letter does make a difference!!!
Nagra2 Keys
Dish Provider 0101: Last Updated (Feb14 8:00pm EST)
Key0: F6 31 BA 56 AD E0 ED 3B 8F 4D 7C 95 5A 0F 64 BB
Key1: 49 63 CD 44 1C C9 CE FE C6 79 47 91 DE 35 8B 5D (Active)
Username: Dude123
Post Number: 929
MKM,
was your receiver having the same problem since you downloaded the bin file, or is it something new that it started to do recently???
Username: Pu_da_munda
I have PANSAT 2500, and after loading 289T all the movie channels are gone. Can anyone tell me how to get Indian movie channels back?
After loading new keys
it works for few mintues, now it showing scrummbled or bad view? What to do?
sorry , keys for Dish network was
it works for few mintues, now it showing scrummbled or bad channel? What to do?
Username: Milogone
Post Number: 10
Turn off your autoroll option...
don't go to livefta.con , you'll get a bunch of spam mail shortly after, i guess they give out your email addy
Username: Canndy
Www.livefta.com
Post Number: 325
00, 86: 28 CD 34 D4 8F 5C 8B 5D EB AA F2 86 18 72 B5 24
00: 28 CD 34 D4 8F 5C 8B 5D
01: EB AA F2 86 18 72 B5 24
00 is working
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through February 14, 2007 [ « Previous ] [ Next » ]
