Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through February 08, 2007
Author Thread: Archive through February 08, 2007
Username: Nydas
Post Number: 1736
C/P Authored by Chancysand on releasing the latest 290T BIN for Pansat 2500A, pansat 2500 clones, and Fortec Ultra
X-85BL_DN_Bev_070203_290T_api.zip
Moded with Tivo / Hughes ir codes . Good For ALL
It has been my distinct pleasure to have been able help keep our Fortecs alive for the past Year. As it seems that the Pansat 2500A files will soon come to an end I will no longer be able to support the Fortec Lifetime Ultra in the future. As long as there is still a release for the Pansat 2500A unit I will continue to do my best and make a safe file for use. At this time I would like to urge all to upgrade to another receiver while prices are still competitive. We have had a long run and I feel it is best to just move on. Newer boxes are what you should be looking for as they have so many new features that you have not been able to enjoy with your older units. I urge you not to buy another clone because of price because you will be constantly struggling with the same issues……
http://www.hostclip.com/dl/31359e914b585184534bf1deed0294e4
Once you have downloaded the zip file, extract the file relevant to your needs. There are two types of files.
1 file for BEV for serial load, you use this to upload to your receiver if you are scanning BEV.
1 file for BEV for jtag. Same as above but for jtagging
1 file DN for serial load, you use this to upload to your receiver if you are scanning DN.
1 file for DN for jtag. Same as above but for jtagging.
You will need Blacklist updater 1.4 for uploading to your receiver.
It is available at many sites.
You may also find the BINs and instructions there.
http://www.totalfta.com
http://www.dssrookie.com
http://www.al7bar*tk
http://www.dsstester*com
http://www.dssevolution.com
Username: Manthedent
Post Number: 14
Nalin Nyda
this is my reciever pansat 2300 info i added the new keys and i have just few of the arabic chanels
x-75BL
APl: 261c-E
Boot Ver: 1.1
27 oct 2006
is that the right info?
Username: Mc_sunny
Post Number: 1106
Bev New Keys:02/05/07
key0: DBFC753C305793E6407373A8FA94B836 <-Active
Key1: 9E2ECEDC60151296C7D4383D0D2A2374
Username: Nydas
Post Number: 1743
ma: You have the latest BIN that is available for your receiver Pansat 2300. There is no likelyhood of a new BIN.
You can't flog a dead horse to life.
Username: Dena_86
Nalin Nyda : I have a FORTEC lifetime Ultra and it has been recently updated with the new Bin. The keys work just fine. But what do you mean by your message that we need to buy a new reciever. FORTEC lifetime Ultra will no longer work in the future??!!! please advice
Username: Wwolf
Chatham, On.
Post Number: 49
Bell Keys
Key0: DB FC 75 3C 30 57 93 E6 40 73 73 A8 FA 94 B8 36
(Active)
Key1: 9E 2E CE DC 60 15 12 96 C7 D4 38 3D 0D 2A 23 74
Dish Keys
Key0: E3 A6 6B C6 26 65 82 85 61 C4 BA 8D 1C 62 EF 45 (Active)
Key1: EF 6F 7D 06 20 3C B4 17 77 42 47 35 2A AB 39 71
Username: Donnysbaby
what is going on with the fortecs and pansat i got both are there any new dn keys
Username: Asharfi
Post Number: 529
Today, Viewsat team released new bins for all the 4 Viewsat receivers:
Viewsat PLatinum, Xtreme, PVR 7000, and Ultra
All the latest bins are available at www.dssworld.co.nr!
Enjoy and thanks to Viewsat Coding Team!
Username: Hrrysoni
IL
U.S.A
Post Number: 19
Nalin Nyda: i'm trying to download b-80 for my pansat 3500 which currently has b-70. when i download there is an error message that says "flash update fail". I have followed all the instruction from pansatusa.com for upgrading but nothing seems to work. Plsssssssss help me!! Thanks in advance.
Username: 1_tv_fan
Post Number: 12
}Can someone please help me with this problem? THANKS!!}
After losing service Saturday I manually entered the new keys in my Multistar 2500 clone. Still no signal on anything except the DN info channel. After doing alot of reading here I thought I needed to install the 289T bin (was using 286T since November) Now when I power on the receiver I just have a dash that flashes back and forth accross the receiver. I went back and reloaded the 286T bin and still have the same flashing dash, I left it on both times for hours and it did not change.
What should I do to correct the problem?
I used Blacklist Updater V 1.4 to load both files.
Username: Hrrysoni
IL
U.S.A
Post Number: 20
If there is ne1, not only Nalin, that can help me w/ my "flash update fail problem" i would really appreciate it....Thanks
Username: Nydas
Post Number: 1744
harry: There is detailed information at other sites, particularly addressing b70 to b80 migration. Read there first and act accordingly. Please report success or otherwise
http://www.future-fta.info
http://www.future-fta.info/Forums/showthread.php?t=44121
Username: Nydas
Post Number: 1745
one TV fan: Recheck if you really installed 289T or 289. The 289 would have a clone killer and you would need to jtag.
If you did not kill your receiver, you could try the following.
1. do a factory reset. Switch off at back Disconnect receiver from satellite.
2. Install something like 280T using BL updater 1.4.
3. Install by turning on the receiver and immediately clicking on the mouse to start the upload.
4. If 280T installs succssfully, do user settings and then install 290T (this is the latest.) You will have downloaded this and unzipped the appropriate DN or BEV file and have it ready for upload.
5. If keys don't roll in, do a manual key entry after turning autoroll off.
6. Do a switch off at back and on again.
Username: Nydas
Post Number: 1746
Dena : BL who writes the Pansat BINs and Chancynand who writes the clone BINs based on these BINs have both stated that they are reaching the memory limit.
In the latest version they could not publish one BIN that would work on both DN and BEV. They have advised that you upgrade to a more powerwul receiver with more memory.
My own suggestion is to try out the latest 290 BIN and see if more memory has been released to make the receiver response smooth. There may be more life left in the Pansat clones and fortec ultra. If so we are talking of about 6 more months. It might be prudent to sell off a working receiver for a small price and buy a new receiver.
Username: Nydas
Post Number: 1747
tori lynn: There is a new BIN just out - 290T for Fortecs and Pansat 2500A and Pansat 2500 clones.
You may want to upgrade. do not upgrade if you are scanning both BEV and DN at the same receiver. Please see posts above.
Username: Destine0429
Quebec
Post Number: 139
Ok, I've been waiting for 2 hours now, does anyone have the new keys for BEV?
Username: Leon_kookie
Post Number: 250
Julie White
Go find a key grabber then you can find em when you need them. Freedom..
Quebec
Post Number: 141
I have Key ripper, but they are soo slow. The new keys still aren't there.
Post Number: 252
okay then.. buired in here the last few days someone made claim to having a site with real time key updates. I say hit the bricks and search the forum while you waiting for the key grabber or the keys to be posted.
Username: Big_fat_j
POTTSVILLE, STONEYTOWN
GREEN-LAND
Post Number: 316
Julie White
Use your mouse wheel and scroll up and youll find them not to far up.
If you dont have a mouse wheel drag that little thing on the right up a little.
Sure hope that helps.
Quebec
Post Number: 142
These keys do not work.
Username: Big_fat_j
GREEN-LAND
Post Number: 318
COPY PASTE
BEV KEYS
00: DB FC 75 3C 30 57 93 E6 40 73 73 A8 FA 94 B8 36
01: 9E 2E CE DC 60 15 12 96 C7 D4 38 3D 0D 2A 23 74
Username: Nehal_3278
C, D
C
Post Number: 7
I will waiting for the BEV keys.
Username: Canndy
Www.livefta.com, Www.livefta.com
Www.livefta.com
Post Number: 266
NEW KEY CHANGES:
http://www.livefta.com/forums/t1939-latest-keysspan.html
Username: Jpz
MTL, QC
CAnada
Post Number: 154
hi guys
Username: Zigzag1
are these the latest keys?
Username: Angie_wedgewood
Post Number: 12
Ok so I'm not trying to promote sites or take sides, but I'm guessing a lot of people on here don't know that you can actually just download the keys on your own instead of having to check a forum, that way you have them pretty much instantaneously. I was new to this too and found this out, and it's been REALLY helpful instead of relying on people to post the new keys all the time. So for all you new users out there like myself, it's easier to just go to http://www.dssevolution.com/forums/index.php? and download new keyripper v3.1. Again, I am NOT trying to promote this site, I just know this is the place to get it, I'm sure there's other places to download it too, this is just where I got it. Hopefully it helps a few people!
Username: Ligiuta
Post Number: 8
Nalin, if you are on line please help. I Have the latest bin for Pansat 2700, (295) but the keys are not working.
Thank you
Ligia
Username: Nydas
Post Number: 1750
ligia girboan:
Maake sure you have correct date, time and time zone.
1. Try switch off at back and turn on after 40 seconds.
2. If not working, turn autoroll off (Menu/Parental control/second pin/0000) for DN and for bev. Then enter Keys for DN (provider 0101) or BEV (Provider 0901) Make sure you enter Key 00 and and Key 01 completely and SAVE.
Exit several times. excute item 1 again.
3. If still not working, do "set default keys" then repeat 2 and 1.
Username: Ajlean
Toronto, Ontario
HI GUYS ,CAN ANYONE HELP ME OUT, I HAVE VSEXTREME JUST LOADED THE BIN FIX ,AND IT SHOWING AUTOROLL PROCESSING ,PLEASE CAN ANYBODY HELP,PLEASSSSSS,THANKS IN ADVANCE, IS THERE A NEW BIN TO LOAD? OR WHAT SHOULD I DO?
Username: Wingate
Toronto, On
hi the key's are working bat you have to save each row separate; ex
DB FC 75 3C 30 57 93 E6 ..save
40 73 73 A8 FA 94 B8 36 ..save
etc
Username: Sirbeepy
Where are the new dn keys reciver quit 1hr past
Username: Nydas
Post Number: 1753
DN Keys have not changed for past 2-3 days. If your receiver was working and stopped, try switching off at back and turn it on after 30-40 seconds.
Username: Lizwakefield
Post Number: 10
HI
Can someone pls help me..I have some channels missing on my sat. and i want to rescan all the chanels again can someone tell me how to do that...(Fortec star lifetime)
Thanks a lot
Username: Dude123
Post Number: 910
well first of all try and do the blind scan from Menu->sattelite-->blind scan and see if that helps bring back the channels. If not then post again.
Username: Prfrmnj
Post Number: 1963
Jose - if you are trying aimed at Bev I can tell you right now you will need to imput keys manually. They are still having problems with teh Xtreme rolling Bev.
Liz
First - What bin did you load DN or Bev?
This may be the reason you are missing channels. You an only receive from one provider with the new bins and not both.
Username: Lklives
Post Number: 7537
ExtremeView Magnum on sale at www.EFTA.us
Nagra2 Keys...FOR ALL RECEIVERS...extracted from Keymaster 3.0, which is available; and hosted and created by www.dsscommunity.c*om
Dish Provider 0101: Last Updated (Feb04 10:48pm EST)
Bev Provider 0901: Last Updated (Feb06 01:18pm EST)
Key1: 1D 86 56 7E 5C 4B 25 FE FB F7 DD 30 FD 10 55 4A (Active)
ALL LINKED BELOW ON KEYMASTER 3.0
Dish Install Tips - need helping getting that dish mounted and aligned? Read these tips!
Sat Angle Calculator - Find your correct azimuth and elevation by using longitude and latitude
Username: Canndy
Www.livefta.com
Post Number: 272
Always live keys: http://www.livefta.com/forums/t1939-latest-keysspan.html
DN keys updated.
Username: Canndy
Www.livefta.com
Post Number: 275
DN keys updated.
DN: Last: Feb 6 20:45PM
00, 86: E3 A6 6B C6 26 65 82 85 61 C4 BA 8D 1C 62 EF 45
00: E3 A6 6B C6 26 65 82 85
01: 61 C4 BA 8D 1C 62 EF 45
01, 96: D5 15 77 7C 12 9D 81 06 58 59 46 33 FE 2D 7D C6
00: D5 15 77 7C 12 9D 81 06
01: 58 59 46 33 FE 2D 7D C6
DN keys updated.
Username: Nydas
Post Number: 1756
AV, who is keen on Fortec Ultra has reported problems with Indian channels using DN. I am confirming that I tested the DN version of 290T on a clone and I lost ZCINE, ZEETV, SET SETMX etc. I reverted to 289T.
Username: Dghumman
Ontario
Post Number: 68
nalin can u confirm whether the dish is gone or its the keys that just rolled i put in the keys givaen by fta but they dont work
Username: Canndy
Www.livefta.com
Post Number: 276
Damindar bhai wo kam karde hai...
DN keys updated.
DN keys updated.
Username: Dghumman
Ontario
Post Number: 69
thanks live fta, i had to unplug my receiver and plug it back and it worked fine thanks
Username: Nydas
Post Number: 1757
DN keys changed about half hour ago - they have been posted above.
Switch off receiver at back and switch on again after 30-40 seconds. It might work. Otherwise, set autoroll off, do "set default keys" and reenter both key 00 and key 01.
Username: Jpz
MTL, QC
CAnada
Post Number: 155
thanks for the keys
Username: Burkan
Post Number: 65
Could you please explain the keys 00 and 01? What is the diff since both load at the same locations 00 and 01?
Username: Dude123
Post Number: 913
Burkan
There is no difference between the two sets of keys, some times 00 is active and some times 01 is active. Just make sure you uupdate the active keys and you should be able to watch TV.
Username: 1_tv_fan
Post Number: 13
Nalin
Thanks I did what you said and it worked. Reciever now powers up normally. However I still only recieve a few channels DN info, adult lock out and PPV confirmation and 1 or 2 more. Others get "scrambled or bad" channel. Level is at 90% Quality 99%. I updated keys last night as they changed, have tried a blind scan and powered down the unit, still no change.
What should I try next while I still have some hair left.
I have a multistar (pansat 2500) clone
Dishnetwork
290T bin
THANKS
Username: Vijayveena
Thanks for the keys. Hopefully DN will be working non-stop for tonight's cricket match.
Username: Pathfinder191
Post Number: 168
Could someone please tell me how set default key in SV1000?
Username: Nydas
Post Number: 1759
one TV fan: Since I wrote to you last, I have tried the 290t myself, and am disappointed with it. I found that some international channels are missing on 61.5W and I have seen reports of the same problem on 148W. I then went back to 289T, and had to first install 281T and then 289T.
The other problem is that there is no uniformity. some clones respond better than others.
If you feel strong, try 289T again (280T or 281T first and then 289T).
Both BL and Chancysand have advised that you should get another receiver.
Username: Nydas
Post Number: 1760
Sonicview 1000/4000. Key entry
1. menu>entertainment
2. You will not see word "code". You will only see some names of games. DO NOT PRESS OK.
3. Enter 7890 and you will see the word "Code"
4. Press OK. You will now see key entry screen
5. scroll to nagravision then down one
6. Right scroll to DN 0001 and enter keys.
10/11 for Key 00 and 20/21 for Key 01
7. Save.
8. Go up and select provider ID 0101 and repeat step 6 and 7.
9. If you are entering BEV keys scroll to provider ID 0800, do step 6 & 7, then scroll to 0901 and do the same.
10 Exit
Which receiver do you guys recommend to replace my existing Pansat 2500 clone? It seems, the end is near for these types of recievers.
Username: Nvs
Hi Nalin,
can you please tell me what would be the right key for the receiver Eagle Star? i beleve its a clone of pansat but not 100% sure. If you'r online please help me get this receiver working ;) thank you.
Username: Jpz
MTL, QC
CAnada
Post Number: 156
hi guys
Username: Baalbecki
Hi guys DN went down again ..... Plz Can anyone post the new keys...
Thx
Username: Dude123
Post Number: 914
Bujju Singh
The best one out there is Viewsat xtreme with the best support. so I would spend my money on that...
Username: Sherif_911
Oshawa, Ontario
Post Number: 9
heyy ppl I m back for somereason I fixed my viewsat extreme last sunday, it had the autoroll problem but now it came back would any one help me pls asoon as possible thnx alot
Username: Amrit187
Post Number: 32
what site can i get the 289 T bin and if i want to downgrade from 290T do i need to load 281T first?
Username: Enanita
Aguada
Puerto Rico
Post Number: 17
hi there, how do you enter the keys in C*sat 5000 is it thru the remote control? if so, what channel
thanks
Username: Larry1
Dawson creek, Bc
Post Number: 8
anybody got bev keys fore feb 07 any new keys thanks
Username: Amrit187
Post Number: 33
i tried loading the 289T bin on my pansat 2500 and it did not work...i was downgrading from 290 becuase alot of the indian channel do not work...any ideas on why it doesnt work ?
Username: Rauf
Hi
I have viewsat extreme vs 2000 platinum i have manually input the new keys into my reciever and its up and running but as soon as i change couple of channels the screen gives me signal searching message . when i turn off the reciever and turn if on again every thing is ok. can someone please tell me what is wrong with my reciever
Thanks
Username: Molari
Post Number: 17
Updated Bell ExpressVu Keys
Key 0:
62 A8 43 CE FB 28 0B 81
6D 0B 4D 8F 54 17 AB 9D
<- Active
Key 1:
Username: Canndy
Www.livefta.com
Post Number: 280
http://www.livefta.com/forums/showthread.php?p=4484
Bev: Last: Feb 7 17:00PM
00, 86: 62 A8 43 CE FB 28 0B 81 6D 0B 4D 8F 54 17 AB 9D
00: 62 A8 43 CE FB 28 0B 81
01: 6D 0B 4D 8F 54 17 AB 9D
01, 96: 1D 86 56 7E 5C 4B 25 FE FB F7 DD 30 FD 10 55 4A
00: 1D 86 56 7E 5C 4B 25 FE
01: FB F7 DD 30 FD 10 55 4A
0905 00: 76 9E 38 43 12 8D 8B 95 46 C8 16 F0 83 28 E5 AC ;11:44 02-04-07
0905 01: C9 57 64 42 94 E1 33 98 F9 90 68 6B 34 3C 95 B2 ;11:44 02-04-07
0906 00: F7 59 26 70 29 6A DD B7 00 69 BB 31 3E 41 33 1C ;11:44 02-04-07
0906 01: EE 23 A4 46 C5 36 6A 22 20 63 AB 89 0E E7 5A 56 ;11:44 02-04-07
Username: Balbalj
Post Number: 17
Anyone please tell DN keys
Username: Sting77
Post Number: 20
can anyone give me the sattelite details (DN) for adult channels
Username: Nydas
Post Number: 1764
Bujju Singh: Viewsat ultra or Sonicview 4000 is a slightly better buy to the one recommended by The One. They have usb stick for uploading new BINs in future. Mainly a matter of convenience, if you have been taking your receiver to your computer for uploading. It is a bit more money.
Username: Nydas
Post Number: 1765
Ricky S: The latest bIN for Eagle Star is 290T. If you need all internationals then use 289T bin. Make sure it has a T at the end. Whatever you use, be prepared for glitches and freezes. A change to a new receiver is highly recommended.
Keys are the same for all receivers and are posted here often enough as they change.
Username: Nydas
Post Number: 1766
aa:
Try truning the autoroll off and manual key entry.
Try using a much older BIN for the upload (280T or 281T) and then install 289T. If you still have problems start afresh with System reset. If you have to do a reset, you will have to scan afresh. It would be best to note down user settings and the antenna and DiseqC settings before doing a reset.
Turning receiver off at back and on again, also helps.
Username: Trinity
Post Number: 29
DN new keys anyone?
Username: Sting77
Post Number: 23
hi Nalin can you plz tell me how can i put keys for BEV for pansat 2500, what is the provider and how to put keys
thanks
Username: Bobo34
hey guys, anyone have the new DN keys, i tried the ones from yesterday and they did not work. Thanks in advance.
Username: Nydas
Post Number: 1769
Menu/Parental control/second pin.
Enter 0000.
Go to bottom, and in autoroll menu, set autoroll off for BEV.
Exit.
Enter Nagravision 2.
Find provider ID 0901 by right scrolling in the appropriate area.
Go down past the 00, and enter the BEV key 00 - two lines of 8 two digit numbers.
Save.
Go up and change key 00 to key 01 with right arrow. Go down and enter key 01. Save
Exit, Exit, Exit, Exit
If things do not work, turn receiver off at the back and 30-40 seconds later turn it on.
Username: Shn
Post Number: 8
what are the new keys for viewsat extreme nagra?
Username: Jokerisback
Post Number: 26
Does anybody have new dish network keys for pansat2700a
Username: Canndy
Www.livefta.com
Post Number: 282
DISH KEYS UPDATED@ http://www.livefta.com/forums/t1939-latest-keysspan.html
always live keys!!
Username: Canndy
Www.livefta.com
Post Number: 284
always live keys!!
DN: Last: Feb 7 20:50PM
00, 86: 50 57 D2 64 CC 4B 8B 15 22 15 E4 65 07 5E 2C 66
00: 50 57 D2 64 CC 4B 8B 15
01: 22 15 E4 65 07 5E 2C 66
Username: Jowhar
Post Number: 81
Username: Jowhar
Post Number: 82
Sorry these are Dish keys
Username: Canndy
Www.livefta.com
Post Number: 285
always live keys!!
Username: Kissalive
Hi Nalin how a can avoid changing keys every time that they are change I have a 2500 p
Thank you
Username: Nydas
Post Number: 1771
genne simons: Use 290T BIN.
With 290T you may lose some International channels if you are scanning 61.5W or 148w. You will have to decide what you want - all channels or ease of autoroll? If you want both, change to a new a faster receiver such as a Viewsat.
Username: Hshakarchi
Post Number: 99
latest Keys For DN as you see them on Viewsat:
08: 50 57 D2 64 CC 4B 8B 15
09: 22 15 E4 65 07 5E 2C 66
Username: Vasuram
Post Number: 7
can anybody send me Viewsat extreme keys , as i am not getting any channels
Username: Odyn
Guatemala, Guatemala
Guatemala
HI guys I am new at this so I'll apprecieted if someone help me out to understend this I have a viewsat that is freezing when i change chanels?
Username: Prrincess_fisuy
Bridgetown, West indies
Barbados
Thanks Hanibal53 for the keys.
Nalin and The One, Thanks a lot for your suggestions. I'll see how much does each one cost.
Username: Pizza_dude
Post Number: 11
hi guys ! i have a question. I have viewsat platinium receiver. I've downloaded the new autoroll fix but its not working , when i turn the autorol off and enter keys channels strt freezing up. Besides , sometimes it gives an error "no audio or video" . any suggestions?
Username: Ksr
is there new keys for DN?
Username: Sirroy
Edmonton, Alberta
Hi nice people I'm SirRoy the novice.
I'm looling for the latest Bev keys.
Thank you.
Username: Mc_sunny
Post Number: 1108
Bev New Keys:02/08/07
key00: 62A843CEFB280B816D0B4D8F5417AB9D
Key01: 88DDA14E5455FCC46CAC78D263FEA644 <-Active
Post Number: 16
Thanks Mc Sunny!
Username: Polo69
thx Mc-sunny
my keyripper V3.1 is not updated yet,is there another version,or another way to get new keys
Username: Sirroy
Edmonton, Alberta
Thank you very much Mc-sunny
Username: Chinny
thanks for the keys guys!
work like a charm!
feb 08, 2007 1:45pm
Username: Sirroy
Edmonton, Alberta
Mc Sunny - your a winner
Thanks again
Username: Shahrokhi_2008
Toronto, Toronto ON
Post Number: 38
Dish Network (Last Update: 2007/02/07 6:12 PM PST)
Bell ExpressVu (Last Update: 2007/02/08 8:40 AM PST)
96: 88 DD A1 4E 54 55 FC C4 6C AC 78 D2 63 FE A6 44
Username: Jaz06
Post Number: 23
guys i'm missing some of the international channels,like set,b4u,zee. as of this afternoon,anyone have the same problem is there anyway to get them back yet.
Username: Nydas
Post Number: 1775
Jaz: The problem you have reported has been reported with BIN 290T for Pansat clones, Fortec Ultra and Pansat 2500A. You go back to 289T and continue using manual key entry.
The same may apply to Pansat 2700A BIN 295 and IF So, go back to BIN 292
Home > Message Board > Home Video > Satellite TV > Archive through November 02, 2007 > New Keys > Archive through February 08, 2007 [ « Previous ] [ Next » ]
